Hemi distributor #3099672
12/04/22 11:47 PM
12/04/22 11:47 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I bought the ATI dampener for the Hemi with the magnets for crank trigger set up. I need a distributor just to spin the rotor. 440source has some really affordable distributors. These any good and who makes them?
Re: Hemi distributor [Re: mopar dave] #3099705
12/05/22 08:21 AM
12/05/22 08:21 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Buy an MSD, and buy once...No experience with 440Source distributors, but Firecore ones like to explode on me.
Re: Hemi distributor [Re: mopar dave] #3099715
12/05/22 09:26 AM
12/05/22 09:26 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
They look similar to speedmaster.
Rich H.
Esse Quam Videri
Re: Hemi distributor [Re: Dragula] #3099719
12/05/22 09:51 AM
12/05/22 09:51 AM
Mt Morris Michigan
Mt Morris Michigan
I had a firecore melt the tip off the rotor and left me on the side of the road.
Re: Hemi distributor [Re: mopar dave] #3099752
12/05/22 11:00 AM
12/05/22 11:00 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A stock one with the weights locked down works fine. But some want a fancy dist to look cool. Depends on what type wires you’re using too.
Re: Hemi distributor [Re: cudaman1969] #3099864
12/05/22 04:07 PM
12/05/22 04:07 PM
Originally Posted by cudaman1969
A stock one with the weights locked down works fine. iagree up scope Depends on what type wires you’re using too.
I have used a bunch of stock type OEM distributors and shorten up the mechanical advance to get the total timing I want and have the idle timing between 12 BTDC up to 18 BTDC with 34 BTDC total timing revved up scope wrench up
Re: Hemi distributor [Re: Cab_Burge] #3099929
12/05/22 08:17 PM
12/05/22 08:17 PM
Mt Morris Michigan
Mt Morris Michigan
The distributor will need to be locked out for crank trigger use. I’m curious if the source distributors have the lockout provision like the MSD.
Re: Hemi distributor [Re: mopar dave] #3099943
12/05/22 09:17 PM
12/05/22 09:17 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
If you willing to use a old factory Mopar distributor, you could use an old lean burn distributor from a 440. I used one years ago and they work fine and are most likely higher quality than what's coming out of China and being sold under various brand names today. The lean burn distributor have no mechanical or vacuum advance. twocents
Re: Hemi distributor [Re: mopar dave] #3100055
12/06/22 10:31 AM
12/06/22 10:31 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
She does
2011 Drag Pak Challenger
Re: Hemi distributor [Re: rickseeman] #3100059
12/06/22 10:51 AM
12/06/22 10:51 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
LMAO she looks a little old, figured she would have been transferred to the cell phone factory by now.
Re: Hemi distributor [Re: rickseeman] #3100062
12/06/22 11:01 AM
12/06/22 11:01 AM
Mt Morris Michigan
Mt Morris Michigan
Rick, i think she might make the MSD ones too. Hard to find anything not made in China anymore thanks to our corrupt politicians. Firecore,MSD and many of the off brands are China. I like the idea of using one of the original lean burn distributors or a good used clean MSD.
Re: Hemi distributor [Re: mopar dave] #3110699
01/10/23 10:07 PM
01/10/23 10:07 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I am pretty sure all new distributors are built overseas. The Firecore Distributors have evolved to be absolutely amazing and dependable distributors. They are based on the Chrysler design, with improvements throughout. Hot forged billet, melonized shaft, stronger magnets. You will not be disappointed.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Hemi distributor [Re: sunroofgtx] #3110715
01/10/23 11:49 PM
01/10/23 11:49 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I wonder if performance Distributors would custom make you something with the minimal features you're looking for? They claim they make their distributors "to order".
https://performancedistributors.com/
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Hemi distributor [Re: BigDaddy440] #3110754
01/11/23 08:25 AM
01/11/23 08:25 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if all you want to do is spin the rotor the lean burn distributor is more than up to the task and doesn't have any internals to deal with.
Re: Hemi distributor [Re: lewtot184] #3110808
01/11/23 12:16 PM
01/11/23 12:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Any distributor will work if it’s locked down (simple to do) then drill a hole in cap to see when rotor is aligned with plug wire post, checking with timing light (I liked it at the leading edge)
Re: Hemi distributor [Re: mopar dave] #3110868
01/11/23 03:30 PM
01/11/23 03:30 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This happened to me when my rotor phasing was way off.
Re: Hemi distributor [Re: sunroofgtx] #3110886
01/11/23 04:11 PM
01/11/23 04:11 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Post a link to the Firecore site.
Old Geezer Racing
Re: Hemi distributor [Re: SCATPACK 1] #3110892
01/11/23 04:24 PM
01/11/23 04:24 PM
Dragula Offline
Dragula  Offline
Claim that all you want....Mine thru counter weights thru the side of it and the cap. Wrecked all my wires as well. Luckily, no engine damage from the thing locking up and exploding while driving it.
Re: Hemi distributor [Re: jbc426] #3111040
01/12/23 12:15 AM
01/12/23 12:15 AM
Mt Morris Michigan
Mt Morris Michigan
I will never buy another FireCore distributor ever. I have never seen this happen with the GM or MSD style rotors.
Re: Hemi distributor [Re: Dragula] #3111044
01/12/23 12:31 AM
01/12/23 12:31 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I also have had the same issue 3 times. Never again for me MSD is my go to!
