Re: 5.2 Magnum and 727
[Re: moparx]
#3112096
01/15/23 11:48 AM
01/15/23 11:48 AM
Posts: 12 lyon
fdax
lyon
I consider ONE the things that is required is a PCM from a manual 318. Kodi nox
[Re: fdax]
#3112098
01/15/23 11:51 AM
01/15/23 11:51 AM
Posts: 15,879 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I went from LA 318 to Magnum 360 crate and correct, just remember 360 externally balanced so weighted converter or scalloped flex plate.
Facts are stubborn things.
[Re: elmor353]
#3112159
01/15/23 03:37 PM
01/15/23 03:37 PM
Guitar Jones
I want to swap out the 440 in my truck for a later model 5.2 and would like to use a small block 727. What if any problems might I encounter doing this? Balance issues? You probably won't see an appreciable gain in fuel milage, but for sure a tremendous drop in performance.
[Re: Guitar Jones]
#3112197
01/15/23 06:02 PM
01/15/23 06:02 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I want to swap out the 440 in my truck for a later model 5.2 and would like to use a small block 727. What if any problems might I encounter doing this? Balance issues? You probably won't see an appreciable gain in fuel milage, but for sure a tremendous drop in performance. I assumed something wrong with the 440 for someone to take that drop in cubes
[Re: larrymopar360]
#3112624
01/16/23 06:55 PM
01/16/23 06:55 PM
Posts: 870 Keizer, Oregon U.S.A.
elmor353
Nothing wrong with the 440. I'm just tired of getting 6 mpg. I should be able to at least double that with the 5.2. I haven't bought the transmission yet, but I have everything else I need. I can't seem to locate an A518 where I live, so I figured a 727 would have to do for now. The truck is a 77 D100, short /wide box, 3.23 gears and 28 inch tires. The 440 runs good, stock 77 engine, RV cam of some sort, was in it when I bought it, 750 Holley, headers and dual exhaust. I can't get by a gas station with it. It was okay when gas was cheap, but not anymore.
[Re: Fat_Mike]
#3112808
01/17/23 08:45 AM
01/17/23 08:45 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Sequential fuel injection reduces the variation between the cylinders, with a ballpark fuel economy improvement of 8% just with that mod.
Running a “lean” air to fuel ratio of 20 to 1 dependably improves fuel economy by 25% compared to 14.7, but without sequential fuel injection to keep all cylinders even when running very lean the worst 3 to 4 cylinders will begin misfiring.
How lean can you go? The Australian sold Honda Insight with one sparkplug per cylinder leaned out to 25 to 1 at highway cruise.
If you have a big cubic inch engine like a 440 and you want it to get nearer the highway fuel economy of a 318 you can get partway there by slowing down the RPM at highway cruise by the usual tricks: 2.76 versus 3.23 diff gears, Gear Venders overdrive, taller tires, transmission with 0.5 top gear, etc.
If you get the manifold vacuum at highway cruise to 6 inches of mercury on both the 440 and 318 fuel will be converted to power at about the same. Smaller cube engines have no “magic” . Big cube and small cube V8 follow the same laws.
Is the engine size the only “ticket” to better fuel economy?
No.
Switching to newer design “low rolling resistance” tires is the fastest and easiest single mod.
Aerodynamic tweaks of the truck body can be achieved at surprisingly low cost, and a D100 is way worse shape than any modern truck, but a D100 has a smaller “frontal area” and lighter weight.
The 440 does suffer from its high piston ring friction, lack of “squish & tumble” in the combustion chamber design, and slightly lower compression ratio, compared to the Magnum 5.2 V8 under swap consideration.
A 5.7 Hemi with its twin sparkplugs and other tweaks is officially 6% better than a Magnum 5.9 V8, according to Chrysler.
[Re: elmor353]
#3112844
01/17/23 11:24 AM
01/17/23 11:24 AM
Posts: 12,092 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
There are probably a lot of small (and maybe large) things that you could do to your 440 that might improve the economy. Have you thought about trying to optimize what you have rather than change it out? Might be cheaper and easier than a swap.
Master, again and still
[Re: elmor353]
#3114099
01/18/23 09:23 AM
01/18/23 09:23 AM
Posts: 8,162 USA
360view
USA
Buying a fuel injection set up for the 440 will cost more than I want to spend right now. I have the good running 5.2 for free, already have new headers, an RPM intake and a 625 Carter carb. That leaves me with a great running 440 and 727 to trade, sell or keep for another project. I'm an old ba$tard and live on Social Security, I just need a transmission. The “right” transmission might be the easiest swap that yields the greatest MPG gain. Consider selling some of the stuff you have to get a manual transmission with a low (0.5 or 0.6) top gear.
[Re: 360view]
#3114208
01/18/23 03:25 PM
01/18/23 03:25 PM
Posts: 19,408 north of coder
moparx
back in my junkyard days, i had a 73 4x4 that had 3.91 gears, 32" tires, and a 318/727 combo. when i replaced the bed, i built one from 1/8" plate with a 2x12 oak floor. this bed was to be indestructible when hauling parts and scrap. [it turned out to be, as 40yrs later, the buyer of my truck still owns it, and the bed is still as i built it. ] when it was done and installed, along with a "basher bumper" and bed roll bar made from 3" gas line piping, [not the cheapo thin items you buy on the market today, as well as back then] the truck weighed over 7000lbs. the 318 never got any gas mileage as it was, and after the mods, it got around 5mpg. i grabbed a 440/727 out of a chrysler station wagon, tore the 318's 727 apart for the short tailshaft stuff [the truck had a divorced transfer case] and stuffed it in my truck. the only mods to the station wagon engine was an rv cam, and an 850cfm T-quad with an adapter to the square bore intake the station wagon engine came with. [i think the wagon was a 69 or 70 model.] the gas mileage went instantly from 5 to 14 or so empty, to 10-12 when loaded with parts or scrap. the owner today [who bought my truck all those years ago] still says the truck gets amazing gas mileage ! i think the reason was the 440 just loafs along pulling that weight, while the 318 was foot to the floor most of the time. just my personal experience with a 440 in a truck. your mileage will vary.
[Re: Moparite]
#3114420
01/19/23 09:54 AM
01/19/23 09:54 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
There are a few things you can do to the 440 to get better mileage but it's not going to beat 5.2 or 5.9. The 5.2 in my 1998 1500 2WD was a sweet package that got mid teens city and would almost touch 20 if I was nice on the highway. It was a porky truck at 5000 lbs! Been to the scrap yard more than a few times and it would tip the scale empty at 5k It was still had very acceptable performance and I had no issues towing with it. My '14 with hemi 2wd currently is averaging 18.7 and will get 23-25 on the highway if not driving like a lunatic. 2012 or 2013 and up Chrysler went through the trucks and improved the MPG with active radiator shutters, roller bearing rears, transmission pre-heat, etc which make a big difference.
"I think its got a hemi"
