Transmission line routing to cooler #3109061
01/05/23 05:43 PM
01/05/23 05:43 PM
BDW Offline OP
BDW  Offline OP
Is there a preference where to connect the pressure and return lines for an aftermarket transmission cooler?
The trans cooler has top and bottom connections, both coming out the side.
Re: Transmission line routing to cooler [Re: BDW] #3109115
01/05/23 08:10 PM
01/05/23 08:10 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe they suggest the inlet be at the top. Could be an issue keeping hoses on it if the trans has to push the fluid up through all those "U" turns on a cold morning.
Re: Transmission line routing to cooler [Re: poorboy] #3109148
01/05/23 08:43 PM
01/05/23 08:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I usually orient mine so both inlet & outlet are at the bottom.
Makes for a tidier installation most of the time.
Never had an issue.
Re: Transmission line routing to cooler [Re: BDW] #3109211
01/05/23 10:36 PM
01/05/23 10:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you don't have a tranny temp gauge now make sure and buy and install a good one so you don't run the tranny to cool, ATF needs to be at least 160F to work properly, not below that tsk scope up
Domnic, Thumper Dart, found that out when he installed one that looks like the one in your post in front of his radiator mounted flush to it, he ended up mountiing it sideways behind his front bumper to get it to run 160F+ in the summer in the Mojave Desert in the middle of the day work shruggy
Most stock tranny coolers in the bottom of the radiators are tranny heaters, not coolers scope
Re: Transmission line routing to cooler [Re: Cab_Burge] #3109244
01/06/23 12:54 AM
01/06/23 12:54 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Is that because it needs to be thinner so as to have all the valves work smoothly?
Re: Transmission line routing to cooler [Re: PhillyRag] #3109254
01/06/23 02:38 AM
01/06/23 02:38 AM
I have no idea why it would need to be thinner than 10w to work properly confused
Re: Transmission line routing to cooler [Re: poorboy] #3109376
01/06/23 01:24 PM
01/06/23 01:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Transmission line routing to cooler [Re: John_Kunkel] #3109401
01/06/23 02:14 PM
01/06/23 02:14 PM
BDW Offline OP
BDW  Offline OP
Thx,
Hard to trace those lines, but it looks like it goes through the radiator and to upper inlet, then back to tranny.
I'm not going through radiator, front line on trans is pressure, back line is return.
So it I'll be routing the front line (pressure) to the top of cooler, and routing the lower line (return) to the back of the trans.
Never heard the trans fluid could be too cool, I'm in Central FL, so that shouldn't be a problem.
Re: Transmission line routing to cooler [Re: BDW] #3109554
01/06/23 09:11 PM
01/06/23 09:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
In Florida, your probably OK, but up here in northern IL where we can get cold weather in the winters, anything driven year around needs to run through the bottom of the radiator. Even with just the cooler in the bottom of the rad, the RE46 in my truck doesn't like to shift well until it runs enough to get the fluid temp up some when its cold like it was around Christmas this year. Once it got warmed up a bit, it worked great.
Re: Transmission line routing to cooler [Re: poorboy] #3109624
01/07/23 12:39 AM
01/07/23 12:39 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Same as the A833 with gear oil in: hard shifting until that oil gets heated a little in cold temps.
Re: Transmission line routing to cooler [Re: PhillyRag] #3109636
01/07/23 02:56 AM
01/07/23 02:56 AM
A lot of the NP833 sold in the colder climate states came with ATF in them, that helps a lot for shifting them no matter where you live or drive scope up
Re: Transmission line routing to cooler [Re: Cab_Burge] #3109873
01/07/23 07:25 PM
01/07/23 07:25 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Well aware of that. Chrysler made that change because of customer complaints.
ATF not the best for gear box longevity if transmitting heavy loads.
But chrysler wasn't concerned about longevity, only complaints.
If AFT is OK for gear boxes, why not place in rear axles also?
They're similar in design & usage.
Re: Transmission line routing to cooler [Re: PhillyRag] #3109919
01/07/23 09:23 PM
01/07/23 09:23 PM
[quote=Cab_Burge][quote=PhillyRag][quote=poorboy]
Not alike at all in my opinion tsk The cluster gear acts as a reducer in all gears but direct and then in high gear, the sliders are handling the power in conjunction with the input shaft and output shafts.
The ring and pinion gears are being fed power through the driveshaft and are loaded anytime the car is moving forcing the gear oil in and out of between the gears over and over, trust the makers to use the cheapest lube that they can that will do the job and not cause part failures and customer complaints.
A friend, and fellow stocker class drag racer, of mine tried to use 30 Wt. motor oil in his 8 3/4 for one pass at the track, it was very noisy on the return road after that single pass so he took it home and put in another new set of rear gears whiney shruggy
Re: Transmission line routing to cooler [Re: Cab_Burge] #3110227
01/09/23 12:11 AM
01/09/23 12:11 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
The ring and pinion gears are being fed power through the driveshaft and are loaded anytime the car is moving forcing the gear oil in and out of between the gears over and over, trust the makers to use the cheapest lube that they can that will do the job and not cause part failures and customer complaints. (then WHY the change from gear to atf?. Designers needed gear, customer satisfaction wanted atf)
Of course not alike, but similar. So in 1,2,3rd they both act alike. And yes I know how 4th is different.
It's still gear reduction under heavy loads, that simple.
Re: Transmission line routing to cooler [Re: PhillyRag] #3110436
01/09/23 09:12 PM
01/09/23 09:12 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The biggest difference between the 4/5 speed and the rear axle is the cold weather internal gear movement, and what powers that movement.
With the standard manual trans, cold shifting is human controlled. A person needs to be able to move the shifter from 1st gear to 2nd gear, or from 1st gear into reverse, or from reverse into 1st gear. I can promise you with 80/90 in the 4 speed box, at -20, that becomes pretty complicated. Back in my younger years, diving that 4 speed 66 Coronet in the winter was quite an experience. It sat on the street in front of my house through the winters. The winter of 78/79 was bad, lots of snow, lots of cold. Most nights the over night temps reached a real -20F to -30F, on the nights the temp was higher, we usually got blasted with snow.
When I came home from work, I would park so I could move forward out of the parking place, then I parked the car in 1st gear. In the mornings (5 am) I could shove the clutch in, and start the motor, but I couldn't move the shifter for the trans, there was no put it in neutral to let it warm up. I drove out of the parking space and onto the street. I had 3 stop signs each a block away. By the time I got to the 3rd sign, I could force the shifter into 2nd, and then could shift normally.
The car had a 3:23 Sure grip. Through those first 3 stop signs, the rear was pretty much locked, no sharp turns were going to happen. By that 3rd sign, I could at least make turns. On days the temps were above 0*, the trans shift was stiff, but doable, and the sure grip would at least allow turns if not under power. ATF in the gear box would have been great.
The rear axle is driven by the driveshaft. That motor has a lot more power then a persons arm or the shift rods, levers, and forks inside the gear box. The issue with the gear box is not the gears turning, the motor will easily overpower that, the issue is with gear changing and shifting. With the 80/90 in the rear, the worst thing that could happen would be the differential may drag on turns giving a locked rear feeling if traction on the road surface was questionable. The drive shaft will turn, the gears will mesh, and the wheels will turn (unless there is brake drag). Until the 80/90 gets a little warm, the spider gears may resist moving freely until that 80/90 warms up, so you basically have a sure grip until that happens.
It the gear box never sees cold weather, run thicker lube. If it sees cold weather, run thinner lube. I suspect back in those days with the Coronet, that 80/90 wasn't providing much lube until it got warmed up(maybe that was what warmed up the gear lube in the 1st place). I can assure you, the gear lube wasn't the biggest issue that 4 speed saw, it was the 19 year old lead foot driver. drive
Re: Transmission line routing to cooler [Re: poorboy] #3110447
01/09/23 10:04 PM
01/09/23 10:04 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Yeap: drove a 4-speed challenger year round. On real cold mornings, usually idled few minutes in neutral to get oil moving. And yes still somewhat harder to shift. But like you said, manageable after few stops/goes. Guess best thing to do back then would be to switch oils for winter/summer, but I just tolerated the cold days myself. Was always a gas to drive a stick in snowy roads.
