Transmission Problem - Converter? #3109097
01/05/23 07:46 PM
01/05/23 07:46 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
So My fresh 727 and freshly tightened converter would go forward in all gears including 1, 2, 3 neutral and reverse. This is in my race car. This is a new motor combo, and motor has no more than 20 minutes of run time in the car, most of it idling. Did drive it around the driveway for 2-3 minutes tops.
Tore the transmission apart today. Heavy contamination. All the black contamination in the pictures picked up by a magnet. All components inside the transmission looked okay. Lots of contamination in the valve body that could have locked up a shuttle valve.
My transmission guy says the torque converter failed. Does this make sense? Like I said - it never even hit the track.......
Re: Transmission Problem - Converter? [Re: markz528] #3109098
01/05/23 07:50 PM
01/05/23 07:50 PM
You know there is a problem now, take the converter out and back to the converter company, guy, and have them look at it and maybe flush it to see what they think twocents
What I have found on race parts is they either die young or live a long time shruggy work shruggy
Re: Transmission Problem - Converter? [Re: markz528] #3109099
01/05/23 07:52 PM
01/05/23 07:52 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If all your internals look good I’d say they didn’t flush the converter.
Re: Transmission Problem - Converter? [Re: Cab_Burge] #3109101
01/05/23 07:56 PM
01/05/23 07:56 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Its heading back to the converter guy but he is out of pocket this week so I can't talk to hm yet.
Its more than a flush of the converter I believe. There looks to be a piece of the converter sprag on the filter.
Re: Transmission Problem - Converter? [Re: markz528] #3109104
01/05/23 07:57 PM
01/05/23 07:57 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
My biggest issue is I don't have a smoking gun why it went forward in neutral and reverse, only suspicions - and it wasn't the converter doing that ..........
Re: Transmission Problem - Converter? [Re: markz528] #3109213
01/05/23 10:40 PM
01/05/23 10:40 PM
NC
440Jim Offline
440Jim  Offline
NC
Only a guess with limited info...
If all the steel parts in the transmission are not noticeably worn/damaged/chewed-up, then the magnetic metal on the filter must be coming from the lines or the converter.
The only way to know is to cut open the converter, and trust the shop that built it to admit they put it together wrong (tolerances, etc.)
That situation (newly rebuilt) really sucks.
Re: Transmission Problem - Converter? [Re: markz528] #3109214
01/05/23 10:45 PM
01/05/23 10:45 PM
A word of caution, in the future when it isn't right after fixing things stop and take it back to get it fixed correctly, don't drive it any longer than it takes to figure out it isn't correct twocents
I didn't focus on the moving forward in all gears on your post the first time realcrazy
It is the valve body that controls fluid flow in the tranny, not the converter work shruggy
I have seen problems occur after a tranny failure from not thoroughly cleaning the tranny cooler lines and tranny coolers and recirculating broken trash in them into the fresh tranny and converters puke realcrazy shruggy Some lessons are learned the hard way, DANG IT whiney
Re: Transmission Problem - Converter? [Re: markz528] #3109226
01/05/23 11:38 PM
01/05/23 11:38 PM
A727Tflite Offline
A727Tflite  Offline
First question, why was the trans rebuilt the first time?
Second, being a race trans, I assume it’s a manual shift valve body. If so, there is nothing in the valve body that will keep the rear clutch on in all gears. Unless the manual valve is stuck in the forward position.
As for the converter - a dirty converter or one that failed usually puts trash through the pump.
Re: Transmission Problem - Converter? [Re: A727Tflite] #3109234
01/06/23 12:07 AM
01/06/23 12:07 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Yes - it is a manual valve body. The new motor makes 1060 hp and the car is heavy. In order to give the tranny the best chance of living, the last piece of the tranny that was stock was the output shaft. The tranny was built originally by A&A with the best they had and now we added the aftermarket output shaft. So that is why the transmission was gone through. I suspect I may need to eventually do something different, but for now I hope the tranny lives for a while in the car.
The converter was tightened up by my converter guy because of the added hp, hence it was fresh.
Someone missed something.......
Re: Transmission Problem - Converter? [Re: markz528] #3109369
01/06/23 01:16 PM
01/06/23 01:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Did you actually disassemble the rear clutch? When the piston pops out of its bore and jams the clutch, a cursory look might not see it.
Re: Transmission Problem - Converter? [Re: John_Kunkel] #3109386
01/06/23 01:39 PM
01/06/23 01:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Unless it has a steel stator the converter failure would most likely be aluminum pieces. When mine killed a steel stator this summer there was WAY more magnetic particles then yours. the metal actually stuck the rooster comb detent ball. Couldn't manually move the shifter. The only thing it hurt in the trans was light pump gear damage. Gears got replaced. I agree with others this is a rear clutch issue. If it's got a cloth filter not much metal can make it into the internal valve body area.
Doug
Re: Transmission Problem - Converter? [Re: markz528] #3109404
01/06/23 02:17 PM
01/06/23 02:17 PM
NC
440Jim Offline
440Jim  Offline
NC
If you have the steel body front planetary, look carefully at the splines on the planetary and the new output shaft. See if that is the source of the metal. That much metal should be easy to see damage if it is the splines.
Yes the rear clutch needs to be disassembled and inspected. But I doubt it was the source of all the metal.
Re: Transmission Problem - Converter? [Re: John_Kunkel] #3109462
01/06/23 05:00 PM
01/06/23 05:00 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
We did fully disassemble it. We found nothing that looked incorrect to us other than all the contamination.
Jim - it is a steel planetary and we inspected it all. No evidence that the material came from within the transmission. Need to get the converter opened up ASAP.
Re: Transmission Problem - Converter? [Re: markz528] #3109568
01/06/23 09:33 PM
01/06/23 09:33 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If it’s performing throw a filter on it, fill it and run it!
Re: Transmission Problem - Converter? [Re: markz528] #3109590
01/06/23 10:30 PM
01/06/23 10:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
[quote=markz528] All components inside the transmission looked okay.
The converter isn't causing it to move in all gear selections. There is an issue in the trans.
Doug
Re: Transmission Problem - Converter? [Re: dvw] #3109804
01/07/23 03:55 PM
01/07/23 03:55 PM
moparx Offline
moparx  Offline
i wonder if the weld on the rooster comb broke ?
beer
Re: Transmission Problem - Converter? [Re: moparx] #3109912
01/07/23 09:02 PM
01/07/23 09:02 PM
A727Tflite Offline
A727Tflite  Offline
beer
Like I alluded to 8 posts above.
Re: Transmission Problem - Converter? [Re: A727Tflite] #3110102
01/08/23 04:09 PM
01/08/23 04:09 PM
moparx Offline
moparx  Offline
beer
