Wilson Manifolds made Christmas that much better.
#3107806
01/02/23 09:02 PM
01/02/23 09:02 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My new manifold for the 541 arrived the week before Christmas. Things were going bonkers at work so I'm just now finding the time to play with the new parts. They port matched the intake, converted it to EFI, and added a few vacuum bungs for my EFI needs as well as the vacuum goodies the car needs. A new 4bbl throttle body was part of the package. The guys at Wilsom complimented my port template on three different occasions. Apparently, most guys are carving "templates" out of corrugated cardboard using a dull beaver. They had some real horror stories there. Mine was made from the heavy card stock sheet that FelPro slides in the box with valley pans. The work looks good. The port match was under $300 and a full effort job would have added $1100 to the bill. I didn't see the value for what might get me 12 hp on a highway cruiser. I slid a pair of calipers down the runners of the RPM and my old Weiand science project. The runner height was quite similar but the width was a totally different story. The old piece has much narrower ports than even the untouched portions of the RPM. I'm fairly certain the new intake will open up a bit better breathing. Unfortunately, it will not fit with the Indy valley pan so I will have to get creative with the gaskets. If nothing else, it'll look purty when I open the hood. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
Re: Wilson Manifolds made Christmas that much better.
[Re: feets]
#3107810
01/02/23 09:12 PM
01/02/23 09:12 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Very nice.....I for one do not like converting intakes to efi cause its so permanent.....Its why I like throttle body's so much. Port the intake, and do what is needed, but converting to efi is kinda final.....I like these little units, bolt on and go...
[Re: feets]
#3107811
01/02/23 09:12 PM
01/02/23 09:12 PM
feets
Senior Management
Senior Management
Irving, TX
If you want a good finished product you've got to give them a fighting chance.
[Re: feets]
#3107910
01/03/23 08:17 AM
01/03/23 08:17 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
That looks really nice, how many CFM do they say that throttle body is?
68 Barracuda Formula S 340
[Re: Bad340fish]
#3107913
01/03/23 08:28 AM
01/03/23 08:28 AM
feets
Senior Management
Senior Management
Irving, TX
Throttle body is north of 1200 and capable of exceeding 1500 with a spacer.
[Re: feets]
#3108947
01/05/23 01:48 PM
01/05/23 01:48 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My new manifold for the 541 arrived the week before Christmas. Things were going bonkers at work so I'm just now finding the time to play with the new parts. They port matched the intake, converted it to EFI, and added a few vacuum bungs for my EFI needs as well as the vacuum goodies the car needs. A new 4bbl throttle body was part of the package. The guys at Wilsom complimented my port template on three different occasions. Apparently, most guys are carving "templates" out of corrugated cardboard using a dull beaver. They had some real horror stories there. Mine was made from the heavy card stock sheet that FelPro slides in the box with valley pans. The work looks good. The port match was under $300 and a full effort job would have added $1100 to the bill. I didn't see the value for what might get me 12 hp on a highway cruiser. I slid a pair of calipers down the runners of the RPM and my old Weiand science project. The runner height was quite similar but the width was a totally different story. The old piece has much narrower ports than even the untouched portions of the RPM. I'm fairly certain the new intake will open up a bit better breathing. Unfortunately, it will not fit with the Indy valley pan so I will have to get creative with the gaskets. If nothing else, it'll look purty when I open the hood. Was the under 300.00 just for the port matching?
[Re: feets]
#3108970
01/05/23 02:30 PM
01/05/23 02:30 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Looks great!
I'm glad somebody supports this kind of work, so those of us who wouldn't consider it can see what it's about.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3108976
01/05/23 02:37 PM
01/05/23 02:37 PM
fast68plymouth
So. Burlington, Vt.
Looks great!! And I’m def looking forward to the results from the new manifold and the increased spring loads.
[Re: fast68plymouth]
#3108999
01/05/23 03:17 PM
01/05/23 03:17 PM
Posts: 16,932 NC
440Jim
NC
Great post. Wilson does impressive looking work. But you have to pay for all that labor and love. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) It is amazing how different the runners are on "as cast" intakes. Nice to see the Edel RPM intake had runners fairly large between the head and plenum. Can you measure the distance across those "spreader calipers" at a few depths (head opening, 1" into the port, 2" into the port)? It looks like the Wilson port match goes in maybe 1.5-2.0"
[Re: feets]
#3109005
01/05/23 03:27 PM
01/05/23 03:27 PM
Posts: 43,311 Bend,OR USA
Cab_Burge
I've been told that any dual plane intake on EFI is a big No ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) No ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) How did you decide to use your intake? Was it EFI before with a throttle body? Thanks in advance for your help ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif)
[Re: Cab_Burge]
#3109032
01/05/23 04:10 PM
01/05/23 04:10 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
Looks nice.
No problem using a dual plane with port injection.
[Re: 440Jim]
#3109069
01/05/23 06:08 PM
01/05/23 06:08 PM
Posts: 16,932 NC
440Jim
NC
Can you measure the distance across those "spreader calipers" at a few depths (head opening, 1" into the port, 2" into the port)? It looks like the Wilson port match goes in maybe 1.5-2.0" I figure since I asked you, I would do the same with the Mopar Performance M1 RB intake I have, which is the 4500 carb pad version. What a nightmare. The shape of the port and angles make the WxH measurements into the port kind of difficult, so take each with a grain of salt. And to make it worse, the inner runners and the outer runners on my intake manifold are noticeably different, not just length from plenum to head, but the longer (outer) runners are larger inside...
[Re: Cab_Burge]
#3109197
01/05/23 10:13 PM
01/05/23 10:13 PM
feets
Senior Management
Senior Management
Irving, TX
Looks nice.
I thought that the single plane intakes were needed for either the MAP or MAS sensors to be accurate for the AFR tuning for the ECU to work best in closed loop ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) Manifold pressures should remain fairly constant across the manifold with each runner varying that wee tiny bit with intake pulses. Those pulses should be the same values for each hole unless you've torched something important. What screws up throttle body style injection systems are full height plenum dividers. That creates an irregular vacuum signal to the sensors in the throttle body. Cutting down the divider or using an open carb spacer stabilizes the signal, just like with a carb.
[Re: pittsburghracer]
#3109203
01/05/23 10:17 PM
01/05/23 10:17 PM
feets
Senior Management
Senior Management
Irving, TX
That was for the port matching. EFI conversion was a wee bit more. Think factor of 3.
[Re: 440Jim]
#3109228
01/05/23 11:46 PM
01/05/23 11:46 PM
feets
Senior Management
Senior Management
Irving, TX
It was a bit difficult to measure the ports. The hand work on the RPM went deeper than 1" and the floors of the low side ports dropped so much that the spring calipers barely fit. The injector bungs were also 1" in so I had to measure the height off to the side of the ports.
Measuring 2" in was not possible due to the curves so I stuck with the port window and 1" deep. Dividers were measured at the opening and as deep as I could sink the dial calipers jaws.
[Re: feets]
#3109239
01/06/23 12:19 AM
01/06/23 12:19 AM
Posts: 2,260 IL
furious70
IL
Looks nice.
I thought that the single plane intakes were needed for either the MAP or MAS sensors to be accurate for the AFR tuning for the ECU to work best in closed loop ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) Manifold pressures should remain fairly constant across the manifold with each runner varying that wee tiny bit with intake pulses. Those pulses should be the same values for each hole unless you've torched something important. What screws up throttle body style injection systems are full height plenum dividers. That creates an irregular vacuum signal to the sensors in the throttle body. Cutting down the divider or using an open carb spacer stabilizes the signal, just like with a carb. and I've had very good luck with an rpm performer intake on my turbo efi 383 with a sheet metal elbow and forward facing Ford style TB.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#3109429
01/06/23 03:14 PM
01/06/23 03:14 PM
feets
Senior Management
Senior Management
Irving, TX
The low divider of the RPM and that long elbow would straighten out any signal bouncing off the throttle blade. However, it would make for a train wreck if you were squinting fuel all the way up there.
[Re: Dragula]
#3109480
01/06/23 05:54 PM
01/06/23 05:54 PM
Bad340fish
Tulsa OK
Dragula usually when I see injectors like that its for supplemental fuel for a boosted application.
[Re: Dragula]
#3109620
01/07/23 12:00 AM
01/07/23 12:00 AM
feets
Senior Management
Senior Management
Irving, TX
The long curved elbows can cause problems with some intakes due to the velocity difference between the short side and long side.
[Re: feets]
#3109627
01/07/23 01:10 AM
01/07/23 01:10 AM
Posts: 2,260 IL
furious70
IL
The low divider of the RPM and that long elbow would straighten out any signal bouncing off the throttle blade. However, it would make for a train wreck if you were squinting fuel all the way up there. No fuel, but water injection ahead of the throttle blade and it seems happy enough about it. 30-40* temp drop and plugs that all look very similar to each other. If I run out of injector I will experiment with meth mixed in.
