Wilson Manifolds made Christmas that much better. #3107806
01/02/23 09:02 PM
01/02/23 09:02 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
My new manifold for the 541 arrived the week before Christmas. Things were going bonkers at work so I'm just now finding the time to play with the new parts.
They port matched the intake, converted it to EFI, and added a few vacuum bungs for my EFI needs as well as the vacuum goodies the car needs. A new 4bbl throttle body was part of the package.
The guys at Wilsom complimented my port template on three different occasions. Apparently, most guys are carving "templates" out of corrugated cardboard using a dull beaver. They had some real horror stories there. Mine was made from the heavy card stock sheet that FelPro slides in the box with valley pans.
The work looks good. The port match was under $300 and a full effort job would have added $1100 to the bill. I didn't see the value for what might get me 12 hp on a highway cruiser.
I slid a pair of calipers down the runners of the RPM and my old Weiand science project. The runner height was quite similar but the width was a totally different story. The old piece has much narrower ports than even the untouched portions of the RPM.
I'm fairly certain the new intake will open up a bit better breathing. Unfortunately, it will not fit with the Indy valley pan so I will have to get creative with the gaskets.
If nothing else, it'll look purty when I open the hood. biggrin
- Stu Harmon
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3107807
01/02/23 09:04 PM
01/02/23 09:04 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Bungs and port match.
- Stu Harmon
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3107808
01/02/23 09:06 PM
01/02/23 09:06 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
New vs old.
- Stu Harmon
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3107810
01/02/23 09:12 PM
01/02/23 09:12 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Very nice.....I for one do not like converting intakes to efi cause its so permanent.....Its why I like throttle body's so much. Port the intake, and do what is needed, but converting to efi is kinda final.....I like these little units, bolt on and go...
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3107811
01/02/23 09:12 PM
01/02/23 09:12 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
If you want a good finished product you've got to give them a fighting chance.
- Stu Harmon
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3107857
01/02/23 11:01 PM
01/02/23 11:01 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Purdy welds there weld
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3107910
01/03/23 08:17 AM
01/03/23 08:17 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That looks really nice, how many CFM do they say that throttle body is?
68 Barracuda Formula S 340
Re: Wilson Manifolds made Christmas that much better. [Re: Bad340fish] #3107913
01/03/23 08:28 AM
01/03/23 08:28 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Throttle body is north of 1200 and capable of exceeding 1500 with a spacer.
- Stu Harmon
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3108016
01/03/23 02:32 PM
01/03/23 02:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
"Corrugated cardboard using a dull beaver" laugh2 - most excellent !
Re: Wilson Manifolds made Christmas that much better. [Re: topside] #3108906
01/05/23 12:36 PM
01/05/23 12:36 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
That's a nice looking piece and should pick you up considerably!
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3108947
01/05/23 01:48 PM
01/05/23 01:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Was the under 300.00 just for the port matching?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3108970
01/05/23 02:30 PM
01/05/23 02:30 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Looks great!
I'm glad somebody supports this kind of work, so those of us who wouldn't consider it can see what it's about.
Rich H.
Esse Quam Videri
Re: Wilson Manifolds made Christmas that much better. [Re: ZIPPY] #3108976
01/05/23 02:37 PM
01/05/23 02:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looks great!!
And I’m def looking forward to the results from the new manifold and the increased spring loads.
Re: Wilson Manifolds made Christmas that much better. [Re: fast68plymouth] #3108999
01/05/23 03:17 PM
01/05/23 03:17 PM
NC
440Jim Offline
440Jim  Offline
NC
Great post. Wilson does impressive looking work. But you have to pay for all that labor and love. grin
It is amazing how different the runners are on "as cast" intakes. Nice to see the Edel RPM intake had runners fairly large between the head and plenum.
Can you measure the distance across those "spreader calipers" at a few depths (head opening, 1" into the port, 2" into the port)?
It looks like the Wilson port match goes in maybe 1.5-2.0"
Re: Wilson Manifolds made Christmas that much better. [Re: feets] #3109005
01/05/23 03:27 PM
01/05/23 03:27 PM
I've been told that any dual plane intake on EFI is a big No tsk No confused
How did you decide to use your intake?
Was it EFI before with a throttle body?
Thanks in advance for your help up bow
Re: Wilson Manifolds made Christmas that much better. [Re: Cab_Burge] #3109032
01/05/23 04:10 PM
01/05/23 04:10 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Looks nice.
No problem using a dual plane with port injection.
Re: Wilson Manifolds made Christmas that much better. [Re: 440Jim] #3109069
01/05/23 06:08 PM
01/05/23 06:08 PM
NC
440Jim Offline
440Jim  Offline
NC
I figure since I asked you, I would do the same with the Mopar Performance M1 RB intake I have, which is the 4500 carb pad version.
What a nightmare. The shape of the port and angles make the WxH measurements into the port kind of difficult, so take each with a grain of salt. And to make it worse, the inner runners and the outer runners on my intake manifold are noticeably different, not just length from plenum to head, but the longer (outer) runners are larger inside...
Re: Wilson Manifolds made Christmas that much better. [Re: INTMD8] #3109092
01/05/23 07:37 PM
01/05/23 07:37 PM
Originally Posted by INTMD8
Looks nice.
I thought that the single plane intakes were needed for either the MAP or MAS sensors to be accurate for the AFR tuning for the ECU to work best in closed loop confusedshruggy
Re: Wilson Manifolds made Christmas that much better. [Re: Cab_Burge] #3109197
01/05/23 10:13 PM
01/05/23 10:13 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Looks nice.
Manifold pressures should remain fairly constant across the manifold with each runner varying that wee tiny bit with intake pulses. Those pulses should be the same values for each hole unless you've torched something important.
What screws up throttle body style injection systems are full height plenum dividers. That creates an irregular vacuum signal to the sensors in the throttle body. Cutting down the divider or using an open carb spacer stabilizes the signal, just like with a carb.
- Stu Harmon
Re: Wilson Manifolds made Christmas that much better. [Re: pittsburghracer] #3109203
01/05/23 10:17 PM
01/05/23 10:17 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
That was for the port matching. EFI conversion was a wee bit more. Think factor of 3.
- Stu Harmon
