Re: Milodon Oil Pan swap... pleas help
[Re: StandOnIt]
#310757
05/07/09 10:33 AM
05/07/09 10:33 AM
Posts: 21,087 Niles , Ohio
therocks
Niles , Ohio
I can install my 8 qt Moroso in the 65 in the car.Just lift motor some disconnect the idler and pitman and move them out of the way.Rocky
Chrysler Firepower
[Re: topside]
#310760
05/07/09 11:46 AM
05/07/09 11:46 AM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
BigBlock E Body? Just drop the centerlink. No need to raise engine. As mentioned in an earlier post you might need to rotate the crank slightly to clear the pan.
[Re: GomangoCuda]
#310761
05/07/09 02:33 PM
05/07/09 02:33 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
I just went from a deep sump with external to a circle track type in a 69 B body, so should be the same deal.
Drop c-link and I had to jack up the engine an inch or so to get at some bolts. you might be able to get by without that deal but I have big hands and arms and I can't reach stuff sometimes.
I want my fair share
[Re: StandOnIt]
#310762
05/07/09 05:50 PM
05/07/09 05:50 PM
Posts: 913 Lafayette, IN
challengerman71
super street
super street
Lafayette, IN
In that Chally in your sig? You would at least need to lift the engine a bit and remove some steering gear to be able to slide it out and back in. I have never tried it but I'm sure you could do it with a few more inches of clearance.. I would try it anyway..
yes, the chally in my sig. It has a stroker so i do not know if that makes a difference..
