Milodon Oil Pan swap... pleas help #310755
05/07/09 07:41 AM
05/07/09 07:41 AM
Lafayette, IN
challengerman71 Offline OP
super street
super street
Lafayette, IN
Is is possible to swap out an old milodon low profile 7 qt. oil pan with a new one, without removing the engine? Thanks.
Re: Milodon Oil Pan swap... pleas help [Re: challengerman71] #310756
05/07/09 07:58 AM
05/07/09 07:58 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
In that Chally in your sig? You would at least need to lift the engine a bit and remove some steering gear to be able to slide it out and back in. I have never tried it but I'm sure you could do it with a few more inches of clearance.. I would try it anyway..
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Milodon Oil Pan swap... pleas help [Re: StandOnIt] #310757
05/07/09 10:33 AM
05/07/09 10:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I can install my 8 qt Moroso in the 65 in the car.Just lift motor some disconnect the idler and pitman and move them out of the way.Rocky
Chrysler Firepower
Re: Milodon Oil Pan swap... pleas help [Re: challengerman71] #310758
05/07/09 10:44 AM
05/07/09 10:44 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I swapped one on a 67 b body, only had to drop centerlink. (440)
Re: Milodon Oil Pan swap... pleas help [Re: buildanother] #310759
05/07/09 11:06 AM
05/07/09 11:06 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sometimes you may need to turn the crank so the counterweights clear the edge of the sump or flange; pretty sure you'll have to raise the motor a bit on a BB.
I can have the big drag-race pan out & back into my SB Duster in 20 minutes by pulling the drag link (passes through the pan) & rotating the crank to a position I marked on the balancer, without raising the motor, but obviously that's a different setup than yours.
Re: Milodon Oil Pan swap... pleas help [Re: topside] #310760
05/07/09 11:46 AM
05/07/09 11:46 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
BigBlock E Body? Just drop the centerlink. No need to raise engine. As mentioned in an earlier post you might need to rotate the crank slightly to clear the pan.
Re: Milodon Oil Pan swap... pleas help [Re: GomangoCuda] #310761
05/07/09 02:33 PM
05/07/09 02:33 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I just went from a deep sump with external to a circle track type in a 69 B body, so should be the same deal.
Drop c-link and I had to jack up the engine an inch or so to get at some bolts. you might be able to get by without that deal but I have big hands and arms and I can't reach stuff sometimes.
I want my fair share
Re: Milodon Oil Pan swap... pleas help [Re: StandOnIt] #310762
05/07/09 05:50 PM
05/07/09 05:50 PM
Lafayette, IN
super street
super street
Lafayette, IN
yes, the chally in my sig. It has a stroker so i do not know if that makes a difference..
Re: Milodon Oil Pan swap... pleas help [Re: challengerman71] #310763
05/08/09 12:38 AM
05/08/09 12:38 AM
SomeCarGuy Offline
SomeCarGuy  Offline
It could be I kinda doubt it. The pickup would be the real concern i would have. Mine was easy to remove sine it was external.
I jacked it up using the pan, did the front bolts, then let it down. Did the opposite to replace the new pan. Worked great. Could have used the cherry picker but I didn't want to dig it out of the corner.
