E body - tire and wheel size #3105353
12/24/22 11:26 PM
12/24/22 11:26 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
I am putting the Dr diff 1" offset spring hangers and 67 Dana60 in my Barracuda this winter. What size DOT drag radial or bias ply slick is a good fit?
Re: E body - tire and wheel size [Re: GomangoCuda] #3105364
12/25/22 03:17 AM
12/25/22 03:17 AM
29.5x10.5x15 bias ply on a ten inch wide rim work scope up
What year Cuda and are the leaf springs in the stock location still?
Re: E body - tire and wheel size [Re: GomangoCuda] #3105377
12/25/22 07:46 AM
12/25/22 07:46 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We used to run a 10 x 15 with a 5" back spacing with the old mopar offset kit and a 29.5 x 10.5 bias ply. The tyres would stick out of the bodywork 1/2" and we'd have 3/8" clearance (min) to the leafs, this was with an E body width Dana. Street tyres were ok but the slicks would rub sometimes when turning, mainly catching on the spring.
We then moved the front spring mounts to the frame rails and put spacers and longer bolts in the shackles to give everything another 1 1/4" clearance, we also narrowed the axle 1" per side to b body width.
With the same size and back spacing wheels, the tyres tuck nicely under the arch, which was good since we lowered the rear 1 1/2" at the same time. We now use a radial slick which is narrower than its bias ply counter part of the same designated size.
Tyre is still close to the body work (outset) but doesn't rub since the car has plenty of rise in the rear, no rubbing on the springs either.
This on a '74 Dodge Challenger (European Export model if that makes any difference) Anyway, HTH's up
Re: E body - tire and wheel size [Re: GomangoCuda] #3105405
12/25/22 11:17 AM
12/25/22 11:17 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I have a 68-70 B body Dana under my challenger and run a 295 65-15 drag radial on an 8" wheel with 4.5" of bs.
I run -1 ride height caltracs with no issues. I don't know how to post pics from my phone on here or I'd share some pics
shruggy
Re: E body - tire and wheel size [Re: Tig] #3105406
12/25/22 11:20 AM
12/25/22 11:20 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We mini tubbed mine and relocated the springs to the frame rails. I have Caltracs with -1" split mono leafs. I have 15x12 wheels with 315/60/15 Drag Radials and also run 29.5x10.5W slicks as well.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: E body - tire and wheel size [Re: Cab_Burge] #3105412
12/25/22 11:36 AM
12/25/22 11:36 AM
70 Barracuda. Stock location springs, Caltracs, 275-60 dot drag radials for the last 20 years. Next time it's back sitting on tires it will have the springs 1" inboard per side and a 67 Dana. I think it will fit 295-65 when done.
Re: E body - tire and wheel size [Re: GomangoCuda] #3105417
12/25/22 12:03 PM
12/25/22 12:03 PM
central il.
second 70 Offline
second 70  Offline
central il.
Ask Dr Diff. I believe he says you can fit 325 x 15 on 10" rims under an ebody with his offset kit and a b-body dana.
Re: E body - tire and wheel size [Re: second 70] #3105503
12/25/22 04:52 PM
12/25/22 04:52 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I run a 295/65/15 drag radial with a 68-70 b-body rear 15x8 wheels with 4.5 bs. They fit perfectly and lots of room. I also run a 29x11.5 quick time pro. I could have went bigger but wasn’t sure how much a bias grows and moves around.
Re: E body - tire and wheel size [Re: viperblue72] #3105524
12/25/22 07:26 PM
12/25/22 07:26 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I have the old school MP offset hangers on this beast. I can run 325x50x15 Drag Radials, 30x12.5 ET Streets or 28x13.5 ET Streets on this combo.
Re: E body - tire and wheel size [Re: Uncle Barry] #3105813
12/26/22 10:23 PM
12/26/22 10:23 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
A 295/65/15 on a 15x8 w/ 4.5 backspace fits really nice with no rubbing, even with 5 people in the car. A 69 B-Body Dana and Dr. Diff offset hangers/shackles makes it all possible.
The 2nd pic is with 275/60 ET Streets using the same size wheel. They are rather small in comparison.
Re: E body - tire and wheel size [Re: GomangoCuda] #3105861
12/27/22 10:06 AM
12/27/22 10:06 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How good is the 67 Dana? I’m looking for one to change over from my 69 Dana axel in my 66 car
Re: E body - tire and wheel size [Re: cudaman1969] #3106088
12/28/22 10:51 AM
12/28/22 10:51 AM
NY
challenger451ci Offline
NY
This is a 29 x 10.0 slick on a 10in wheel with a 5.5in backspace. I also built my Dana to B-body width and have the springs relocated in the rear with offset hangers. Anything with a 13.5in section width is about the limit IMO.
Re: E body - tire and wheel size [Re: GomangoCuda] #3106105
12/28/22 12:42 PM
12/28/22 12:42 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'm running that same DrDiff set-up on my '70 with 325/50-15's. I did clearance the fender lip slightly just in case. I also used steel 1/4" spacers that I double checked fitment on the rim's mounting flange to fine tune the tire location within the wheel well. I also had to grind the leaf spring on the side slightly to add more clearance. They don't rub anywhere.
Re: E body - tire and wheel size [Re: jbc426] #3106298
12/29/22 10:07 AM
12/29/22 10:07 AM
an8sec70cuda Offline
I use a stock width E body Dana, 3/4" offset rear shackles, stock front spring hangers.
15x8 rim, 4.5" backspace, 295-65 radial.
Had to trim the top inside of the wheel lip for clearance, but otherwise it fits good.
Using the B body rear and the Dr Diff kit is the way to go though.
Eventally I'll narrow my Dana and use that kit to fit a 10" wheel.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: E body - tire and wheel size [Re: cudaman1969] #3106425
12/29/22 03:40 PM
12/29/22 03:40 PM
The 1967 Dana 60 had course spline axles that are not as good as the later,1970,1971 35 splined axles. They may also be one inch narrower than the 1968 and 1969 B body Dana 60 are confused scope
Re: E body - tire and wheel size [Re: an8sec70cuda] #3106441
12/29/22 05:24 PM
12/29/22 05:24 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
First of all, I love this thread. Just what I needed to know / confirm. I'll be using a B body width Dana 60 with disc brakes and a 1" off-set system.
I dig your car 8sec70Cuda. Mr. Porter used your engine / cam & car in our conversations to help me dial in the cam specs for my 540ci Hemi. I'm not shooting for 8's though, definitely a milder combo for mostly street and some strip use. If I run a low 10s or high 9s I'll be super happy.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: E body - tire and wheel size [Re: cudaman1969] #3107002
12/31/22 03:44 PM
12/31/22 03:44 PM
Cudaman - PM sent
Re: E body - tire and wheel size [Re: GomangoCuda] #3107341
01/01/23 08:55 PM
01/01/23 08:55 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I like the looks of the 275/60/15 drag radial. I use a 15x9 wheel, my leaf springs are in stock location.
