Re: 1050/4150 vs dominator on 400-2 intake?
[Re: viperblue72]
#3104649
12/22/22 06:31 PM
12/22/22 06:31 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
I know a lot of SO CA racers that insist that running the tapered 4150 to 4500 carb adapter is faster at the track than using a 4500 intake with a 4500 carb. bolted onto it Me thinks the added volume of the spacer may be worth some gain, how much I do not know I haven't done a A, B, A test at the track either so I have dyno tested a Wilson 1.5 inch thick reversion spacer on a Studka brand dyno in Madras years ago and it was worth 8 HP at 6500 RPM on my old pump gas stroker motor out of my Duster
[Re: Dragula]
#3104695
12/22/22 08:51 PM
12/22/22 08:51 PM
Posts: 5,618 long island NY
Ari440
long island NY
My 446 ci 12.1 comp 613/276 solid cam stage four heads ported and a M -1 intake manifold with a 850 carb , put a 1050 with 2 inch adapter
11.20s on the 850carb
11.00s on the 1050 Dominator
10.85 123 mph with a stop sign used as a air box to the six pack hood
1.39 9.85 - 137 mph
[Re: viperblue72]
#3104798
12/23/22 08:39 AM
12/23/22 08:39 AM
Posts: 570 UK
rb446
UK
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: viperblue72]
#3104832
12/23/22 10:58 AM
12/23/22 10:58 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Every car I put a Dommy on picked up and some more than others even with the adapter especially blended and ported into the manifold. Your combo would love it I guarantee it IF it's built and tuned right for your combo.....Do not go with an 1150 you are too heavy and will loose much needed booster signal..
[Re: Thumperdart]
#3104917
12/23/22 03:01 PM
12/23/22 03:01 PM
Posts: 2,141 junction city oregon
viperblue72
Every car I put a Dommy on picked up and some more than others even with the adapter especially blended and ported into the manifold. Your combo would love it I guarantee it IF it's built and tuned right for your combo.....Do not go with an 1150 you are too heavy and will loose much needed booster signal.. Thank you Dom. That is good to know.
