Shop suggestions for a Daytona conversion. #3102808
12/16/22 11:27 AM
12/16/22 11:27 AM
RI Deep in the rust belt
chargervert Offline OP
My friend has a nice 70 Charger restomod and the parts to do a Daytona conversion. He is looking for a competent shop to do the conversion,any suggestions? This would be a nice relatively clean job on an already done car with no rot,rust or panel replacement to deal with. A great winter job for any shop. Preferably someone in the Northeast,but he won't rule out other capable shops who are versed in wingcars..
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Shop suggestions for a Daytona conversion. [Re: chargervert] #3102840
12/16/22 12:59 PM
12/16/22 12:59 PM
moparx Offline
moparx  Offline
what is he using for the rear window ?
beer
Re: Shop suggestions for a Daytona conversion. [Re: moparx] #3102842
12/16/22 01:04 PM
12/16/22 01:04 PM
A steel window plug with a new AMD Daytona rear window.
Re: Shop suggestions for a Daytona conversion. [Re: chargervert] #3102849
12/16/22 01:19 PM
12/16/22 01:19 PM
moparx Offline
moparx  Offline
beer
Re: Shop suggestions for a Daytona conversion. [Re: moparx] #3102851
12/16/22 01:21 PM
12/16/22 01:21 PM
The window plug is the same as one that was installed on Ted Stephens Daytona on the Chop Cut Rebuild show.
Re: Shop suggestions for a Daytona conversion. [Re: chargervert] #3102895
12/16/22 02:48 PM
12/16/22 02:48 PM
The parts are quality pieces. The nosecone is heavy mat fiberglass,as are the headlight doors and fenderscoops. The hood and fenders are mint,as the car is a done showcar. The Daytona valence pan,latch tray,headlight pivot brackets,zee bars,headlight buckets,and frame braces are all steel as original. The windshield A pillar moldings are stainless steel reproductions. The front spoiler is heavy gauge aluminum. The grille frame and grille are steel. The turn signal lights are original 69 Valiant/Daytona pieces. The rear window plug is steel.the rear window is new AMD Daytona glass. The rear window moldings are modified original Charger pieces. The underside of the trunk filler panel is from an original 69 Charger 500/ The trunk hinges are new steel reproduction pieces. The trunklid on the car is mint,plus he has a second rust free Texas trunk lid,either one can be modified to fit. The wing is a steel reproduction,with steel wing washer reinforcement plates and steel wing braces. These are all clean quality parts.
Re: Shop suggestions for a Daytona conversion. [Re: chargervert] #3102908
12/16/22 04:19 PM
12/16/22 04:19 PM
Rochester, New York
GregY Offline
GregY  Offline
Rochester, New York
These guys are in Arkport, New York, about an hour south of Rochester in Western New York: https://www.rjcars.com/
I don't have any personal experience with them, but it looks like they work on a lot of Chrysler products.
Just tossing it out there for consideration, I don't know anything about them.
Re: Shop suggestions for a Daytona conversion. [Re: GregY] #3102924
12/16/22 04:55 PM
12/16/22 04:55 PM
Thanks we will check them out,at this point we are open to any suggestions. It seems nobody wants the work?
Re: Shop suggestions for a Daytona conversion. [Re: chargervert] #3102992
12/16/22 10:08 PM
12/16/22 10:08 PM
boston mass-moving to long isl...
massdaytona Offline
massdaytona  Offline
prob can buy a real daytona for the $$$ it will cost you
Re: Shop suggestions for a Daytona conversion. [Re: massdaytona] #3103030
12/17/22 04:19 AM
12/17/22 04:19 AM
That is highly unlikely with the current value of Daytona's these days. Projects start at 150k,if you can find one at all,and running driving Daytona's start at about 225k these days. We already have a restored showcar 70 Charger,and all the parts needed for the conversion.
Re: Shop suggestions for a Daytona conversion. [Re: chargervert] #3103034
12/17/22 04:57 AM
12/17/22 04:57 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I think you might know Joel Cox in the Cleveland area, he has a real Daytona and he and his brother have done some real high quality restorations in the past like Calvin Smith's A12 Super Bee for one. You can probably get a hold of Joel through Mike Ross's B/E&A in Litchfield, Ohio. Joel and Mike are good friends. Then on top of that Mike had a Wing cars gathering at his place in Litchfield a few years back and if Joel and his brother can't help you I'm sure Mike can or at least point you in the right direction.
Not sure but I think the blue Daytona is a "tribute" and also local and may have been done by Joel's brother??
Mike
Re: Shop suggestions for a Daytona conversion. [Re: chargervert] #3103037
12/17/22 08:07 AM
12/17/22 08:07 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Why put one in at all? Seems like alot of work for a tribute and the masses could care less. IMHO. Unless you have to have a shorter trunklid. shruggy
Re: Shop suggestions for a Daytona conversion. [Re: redraptor] #3103044
12/17/22 10:01 AM
12/17/22 10:01 AM
Anypne can just stick a wing on a Charger. We have the pieces already to do a fairly accurately replica.
Re: Shop suggestions for a Daytona conversion. [Re: A12] #3103046
12/17/22 10:03 AM
12/17/22 10:03 AM
I know Mike Ross from buying parts from him,great guy to deal with.
Re: Shop suggestions for a Daytona conversion. [Re: chargervert] #3103064
12/17/22 11:33 AM
12/17/22 11:33 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've finally (after about ten years) bought everything, EVERYTHING, to make a Daytona clone except the air shields. Right now I have about $20K in parts, not counting the donor '69 Charger. When it's done I'll probably have about half of what an original Daytona costs with the advantage that if I get in an accident, I bought everything once, I can probably buy it again.
