Shop suggestions for a Daytona conversion.
#3102808
12/16/22 11:27 AM
12/16/22 11:27 AM
Posts: 15,995 RI Deep in the rust belt
chargervert
My friend has a nice 70 Charger restomod and the parts to do a Daytona conversion. He is looking for a competent shop to do the conversion,any suggestions? This would be a nice relatively clean job on an already done car with no rot,rust or panel replacement to deal with. A great winter job for any shop. Preferably someone in the Northeast,but he won't rule out other capable shops who are versed in wingcars..
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
Re: Shop suggestions for a Daytona conversion.
[Re: moparx]
#3102842
12/16/22 01:04 PM
12/16/22 01:04 PM
chargervert
A steel window plug with a new AMD Daytona rear window.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: moparx]
#3102851
12/16/22 01:21 PM
12/16/22 01:21 PM
chargervert
The window plug is the same as one that was installed on Ted Stephens Daytona on the Chop Cut Rebuild show.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#3102895
12/16/22 02:48 PM
12/16/22 02:48 PM
chargervert
The parts are quality pieces. The nosecone is heavy mat fiberglass,as are the headlight doors and fenderscoops. The hood and fenders are mint,as the car is a done showcar. The Daytona valence pan,latch tray,headlight pivot brackets,zee bars,headlight buckets,and frame braces are all steel as original. The windshield A pillar moldings are stainless steel reproductions. The front spoiler is heavy gauge aluminum. The grille frame and grille are steel. The turn signal lights are original 69 Valiant/Daytona pieces. The rear window plug is steel.the rear window is new AMD Daytona glass. The rear window moldings are modified original Charger pieces. The underside of the trunk filler panel is from an original 69 Charger 500/ The trunk hinges are new steel reproduction pieces. The trunklid on the car is mint,plus he has a second rust free Texas trunk lid,either one can be modified to fit. The wing is a steel reproduction,with steel wing washer reinforcement plates and steel wing braces. These are all clean quality parts.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#3102908
12/16/22 04:19 PM
12/16/22 04:19 PM
Posts: 1,194 Rochester, New York
GregY
Rochester, New York
These guys are in Arkport, New York, about an hour south of Rochester in Western New York: https://www.rjcars.com/I don't have any personal experience with them, but it looks like they work on a lot of Chrysler products. Just tossing it out there for consideration, I don't know anything about them.
[Re: GregY]
#3102924
12/16/22 04:55 PM
12/16/22 04:55 PM
chargervert
Thanks we will check them out,at this point we are open to any suggestions. It seems nobody wants the work?
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: massdaytona]
#3103030
12/17/22 04:19 AM
12/17/22 04:19 AM
chargervert
prob can buy a real daytona for the $$$ it will cost you
That is highly unlikely with the current value of Daytona's these days. Projects start at 150k,if you can find one at all,and running driving Daytona's start at about 225k these days. We already have a restored showcar 70 Charger,and all the parts needed for the conversion.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: redraptor]
#3103044
12/17/22 10:01 AM
12/17/22 10:01 AM
chargervert
Anypne can just stick a wing on a Charger. We have the pieces already to do a fairly accurately replica.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: A12]
#3103046
12/17/22 10:03 AM
12/17/22 10:03 AM
chargervert
I know Mike Ross from buying parts from him,great guy to deal with.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#3103064
12/17/22 11:33 AM
12/17/22 11:33 AM
Posts: 10,707 North Dakota
6PakBee
North Dakota
I've finally (after about ten years) bought everything, EVERYTHING, to make a Daytona clone except the air shields. Right now I have about $20K in parts, not counting the donor '69 Charger. When it's done I'll probably have about half of what an original Daytona costs with the advantage that if I get in an accident, I bought everything once, I can probably buy it again.
