pinion angle #3101397
12/11/22 07:28 PM
12/11/22 07:28 PM
RapidRobert Offline OP
63 dart 360/904/7&1/4 circle track. I am raising the eng/trans so I can fit good flowing magnum ex manifolds. what is the max degrees offset I can use? I know I want the degrees pretty close but in opposite planes. I do have angled shims for the rear axle as needed. Thank you for your time. RR
Re: pinion angle [Re: RapidRobert] #3101401
12/11/22 07:35 PM
12/11/22 07:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
O boy. The pinion angle subject.
First question is - which u joint is closer to the ground, front or rear?
Re: pinion angle [Re: CMcAllister] #3101419
12/11/22 08:22 PM
12/11/22 08:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
5 degrees wouldn't scare me. Shouldn't matter which end is higher.
Doug
Re: pinion angle [Re: dvw] #3101427
12/11/22 08:48 PM
12/11/22 08:48 PM
I will check/measure further. I've definitely jacked up the eng quite a bit to try & run these manifolds. thanks guys. RR
Re: pinion angle [Re: RapidRobert] #3101501
12/12/22 04:01 AM
12/12/22 04:01 AM
gregsdart Offline
gregsdart  Offline
The motor and rearend can be offset quite a bit, as long as the pinion angle is set within reason, no more than 5* down, or less. I used a Ford 8.8 in a 65 dart i built, which was out of line side to side by 2+ inch?
But the differential and engine were parallel side to side, about three degrees down pinion angle. 500 hp 408, no problems.
Re: pinion angle [Re: gregsdart] #3101531
12/12/22 10:12 AM
12/12/22 10:12 AM
Good info, I will get after it. RR
Re: pinion angle [Re: dvw] #3101634
12/12/22 04:00 PM
12/12/22 04:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Doug
If you're trying to make the pinion and crankshaft parallel, it does. You do NOT want to run the pinion angle up (negative) in relation to the driveshaft C/L.
If the engine/trans is angled down (front u joint lower than the front of the crank C/L) that doesn't change. It just needs to be adjusted around to get the best compromise. A million backhalf cars out there like that.
Re: pinion angle [Re: CMcAllister] #3101650
12/12/22 05:26 PM
12/12/22 05:26 PM
more good info, thank you. RR
Re: pinion angle [Re: RapidRobert] #3101969
12/13/22 03:20 PM
12/13/22 03:20 PM
moparx Offline
moparx  Offline
if the pinion angle is angled up, it will wrap "up" more under acceleration, and vibrate bad.
beer
Re: pinion angle [Re: moparx] #3102107
12/13/22 10:50 PM
12/13/22 10:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
beer
Pinion can be up if it's less than the trans is down in the rear. My racecar is 1/2 degree up. But the trans is 2 degrees down.
Doug
Re: pinion angle [Re: dvw] #3102314
12/14/22 04:07 PM
12/14/22 04:07 PM
moparx Offline
moparx  Offline
you are correct Doug.
i meant that to mean if the combined angle was up, [the pinion angle up higher than the transmission output shaft down] it would wrap up more under acceleration. sorry.
beer
Re: pinion angle [Re: dvw] #3102332
12/14/22 04:51 PM
12/14/22 04:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
beer
Doug
What angle is the pinion shaft V in relations to the drive shaft?
The longer the driveshaft the less angle there is there, correct?
Re: pinion angle [Re: RapidRobert] #3102340
12/14/22 05:54 PM
12/14/22 05:54 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
The most efficient transfer of power is a zero-pinion angle. When there is no angle on the u-joints, it spins smooth, the more angle the more the driveshaft has to speed up and then slow down while rotating. Lock an older 4-wheel drive truck and turn it hard you will feel the pulsations in the steering wheel as the axle rotates.
When building a race car, you set the at rest pinion angle down a few degrees so that it comes to zero under hard acceleration. Leaf springs are hard to estimate but 5 to 7 degrees is what I use and 2 to 3 degrees for 4-link and ladder bar.
