Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099697
12/05/22 03:59 AM
12/05/22 03:59 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I just sold a set of K1 rods to a member here. They're good. I like Molnar, Callies, Manley, Carillo: all good stuff. Right now, look at what you can actually get. S/F....Ken M
Re: 383... who's stroker kits would you use? [Re: EchoSixMike] #3099758
12/05/22 11:09 AM
12/05/22 11:09 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
THANKS MY FRIEND..APPR THE ADVICE..GONNA CALL AROUND TODAY AND TALK TO SOME PEOPLE
Re: 383... who's stroker kits would you use? [Re: Cab_Burge] #3101687
12/12/22 07:18 PM
12/12/22 07:18 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
TALKED TO ED AT MOLNAR TODAY....SAYS HE JUST GOT A SHIPMENT OF 383-400 3.9 CRANKS [2.2 ROD JOURNALS], 6.535 RODS ARE IN PORT AND EXPECTED IN THE NEXT FEW WEEKS
SO AFTER THE HOLIDAYS I AM ORDERING MY KIT...THANKS GUYS
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3101998
12/13/22 04:44 PM
12/13/22 04:44 PM
I bought a set of Speedmaster 7.100 long BB Chevy rods for my 3.91 stroker 383 build for my 1968 Dart GTS 4 speed car, I'll probably buy a set of Auto Tech pistons for the 383 motor after having the block rough bored to see what bore size it will clean up at luck
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3102030
12/13/22 06:38 PM
12/13/22 06:38 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Maybe you should call them now in-case I call tomorrow and order all they have stirthepot
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: 383... who's stroker kits would you use? [Re: oldiron] #3102244
12/14/22 01:03 PM
12/14/22 01:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
should work out great, I would definitely look at the 2.200 BBC rod journal for a lighter bobweight and less grinding.
My only other comment is:
If your original block will clean up at .030 or .040 over, I wouldn't go .060
WIZE
In Car:
Re: 383... who's stroker kits would you use? [Re: Streetwize] #3102301
12/14/22 03:08 PM
12/14/22 03:08 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
STD BORE STILL YES.. 3.9 STROKE W 2.2 BBC RODS YES.. 5000 RPM MAX ENGINE..HAS 3;23 GEARS AUTO W 340 CONVERTER.. SHOULD BE PEPPY AND LIVE A LONG TIME
Re: 383... who's stroker kits would you use? [Re: oldiron] #3102302
12/14/22 03:08 PM
12/14/22 03:08 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
LOL..HE HAD 25 CRANKS ANYWAY..AND RODS ARE IN PORT AND EXPECTED AT THE SHOP ANYTIME..
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3102512
12/15/22 11:30 AM
12/15/22 11:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How many miles on this ? I would at least bore it .010.
Re: 383... who's stroker kits would you use? [Re: JohnRR] #3102516
12/15/22 11:43 AM
12/15/22 11:43 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Make sure the crank you buy has knurled rear main seal area.
For a nice street car, stinks to have a dripping rear seal.
I know there's debate on that. But friend bought a 528 kit from Ray Barton... had a knurled seal area... maybe Barton knows a thing or two.
Re: 383... who's stroker kits would you use? [Re: JohnRR] #3102526
12/15/22 12:09 PM
12/15/22 12:09 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
no idea.. was out of car for like 25 yrs while it had a 440 in it.. prob go .030 unless i can get pistons readily with less overbore..but i doubt i will be able to..time will tell
