Trick flow intake vs Torker 2 #3100372
12/07/22 12:03 PM
12/07/22 12:03 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Howdy - long time no see. Still have my 72 Challenger w 505, Trickflow 240 heads, Comp Solid FT 248 at 50 and Torker 2 intake, 1 7/8 headers, 3" exhaust, 4speed w 3.55's. Thinking of swapping intakes.
Im sure the Trick flow intake has to be worth some ponies up top, but also want to retain the factory rallye hood. What are your thoughts on this swap? Why did I wait so long, or not worth it for a car that wont see much track time and it may not even fit under the hood with an aircleaner? Ive had it to the track once just to run through the gears. One soft launch pass and 12.50 at 116mph.
2 kids and a dog
Re: Trick flow intake vs Torker 2 [Re: TonyS451] #3100401
12/07/22 01:18 PM
12/07/22 01:18 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Yes, the TF intake is going to be worth some HP over a Torker 2. But... I don't know if it'll fit under a stock R/T or Rallye hood with any reasonable size air cleaner. If it does, it's gotta be a pretty tight fit. scope
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Trick flow intake vs Torker 2 [Re: Brad_Haak] #3100420
12/07/22 02:31 PM
12/07/22 02:31 PM
NC
440Jim Offline
440Jim  Offline
NC
Manifold heights from each manf website:
Track Heat®intake manifold (part number TFS-61600113) Intake Manifold Height: 6.250 in.
Trick Flow LINK
Edelbrock Torker II intake manifold 5091. Edelbrock LINK
Front Maximum Height 4.150 in
Center Maximum Height 4.670 in
Rear Maximum Height 5.200 in
Re: Trick flow intake vs Torker 2 [Re: 440Jim] #3100444
12/07/22 03:23 PM
12/07/22 03:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Keep in mind the Ede manifold has the carb pad angled so the carb is basically level in a normal car, and the TF intake is not, so the carb would be parallel to the pan rail.
This reduces air cleaner clearance towards the front.
Re: Trick flow intake vs Torker 2 [Re: fast68plymouth] #3100462
12/07/22 04:25 PM
12/07/22 04:25 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Thanks for the feedback and dimensions. Yeah Im sure it will be super tight fit. Was hoping someone has done this already with proof that it all fits with this or that air cleaner...
2 kids and a dog
Re: Trick flow intake vs Torker 2 [Re: TonyS451] #3100463
12/07/22 04:27 PM
12/07/22 04:27 PM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Trick flow intake vs Torker 2 [Re: an8sec70cuda] #3100466
12/07/22 04:40 PM
12/07/22 04:40 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Originally Posted by an8sec70cuda
That route will give me plenty of options smile
2 kids and a dog
Re: Trick flow intake vs Torker 2 [Re: TonyS451] #3100475
12/07/22 05:18 PM
12/07/22 05:18 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I was going to suggest an AAR Fiberglass T/A replica hood, but that's just me... grin
Re: Trick flow intake vs Torker 2 [Re: Brad_Haak] #3100478
12/07/22 05:34 PM
12/07/22 05:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
Brad went for the “other” R/T hood....... as in “Real Tall”
Re: Trick flow intake vs Torker 2 [Re: fast68plymouth] #3100479
12/07/22 05:43 PM
12/07/22 05:43 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Yep, it's an R/T T/A! wink
Re: Trick flow intake vs Torker 2 [Re: fast68plymouth] #3100482
12/07/22 05:48 PM
12/07/22 05:48 PM
LOL!
Brad...you seem like you're kinda on the fence about your hood...not that my opinion matters, but I like it! up
CHIP
Re: Trick flow intake vs Torker 2 [Re: fast68plymouth] #3100521
12/07/22 08:47 PM
12/07/22 08:47 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
r
lol smile
2 kids and a dog
Re: Trick flow intake vs Torker 2 [Re: TonyS451] #3100569
12/08/22 08:22 AM
12/08/22 08:22 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Tony - a standard T/A replica hood was tall enough to let me run Stage VI heads (raised ports), a Victor intake (comparable height to TF) and a 3" drop-base air cleaner. Probably another 1/2" clearance w/ standard-location intake ports; no room for spacers or taller air cleaner w/ the Stage VIs (very tight fit).
Re: Trick flow intake vs Torker 2 [Re: Brad_Haak] #3100570
12/08/22 08:28 AM
12/08/22 08:28 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
But if you wanna have room for raised ports, spacers, and taller air cleaners, whistling
Re: Trick flow intake vs Torker 2 [Re: Brad_Haak] #3100575
12/08/22 09:10 AM
12/08/22 09:10 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
beautiful car
Re: Trick flow intake vs Torker 2 [Re: Brad_Haak] #3100579
12/08/22 09:46 AM
12/08/22 09:46 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
I like that hood a bit more than the T/A on steroids hood, but I can understand why . Glad to see you're back, Brad. Last I was here I think you were taking a vacation. You always have good info to offer. Btw, the 950 carb I bought from you is still running great. I dont think I've touched a screw in 2 years
2 kids and a dog
Re: Trick flow intake vs Torker 2 [Re: TonyS451] #3100631
12/08/22 12:47 PM
12/08/22 12:47 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
