Tony - a standard T/A replica hood was tall enough to let me run Stage VI heads (raised ports), a Victor intake (comparable height to TF) and a 3" drop-base air cleaner. Probably another 1/2" clearance w/ standard-location intake ports; no room for spacers or taller air cleaner w/ the Stage VIs (very tight fit).
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
