Re: glass tube fuses adaptor
[Re: Chal340]
#869323
12/07/10 10:51 AM
12/07/10 10:51 AM
Posts: 6,120 Valencia, España
NachoRT74
Valencia, España
I would like to buy this kind of adaptor to replace all glass tube fuses, do you know where I could buy them. Thanks
are you trying to change them for availability in Europe or for another reason ?
availability in Europe, maybe not in car parts stores, but YOU SHOULD BE ABLE TO FIND THEM at electronic shops ( kinda radioshack, or electronic parts shops where you buy integrated circuits, transistors etc... ). LOT OF Electrical devices use the same car units... big glass ones. I know mostly european electrical devices uses small ones, but still lot more use the big glass ones
[Re: NachoRT74]
#869324
12/07/10 04:44 PM
12/07/10 04:44 PM
Posts: 347 FRANCE, Paris
Chal340
FRANCE, Paris
These glass tube fuses are difficult to change, you can break them by removing from the fuse box and you know it is always in the night or when it's raining that you have to remove it. . So it's easier with this adapter.
70 Challenger, A66, 340 ci
[Re: L.R Helbling]
#2246848
02/03/17 09:27 PM
02/03/17 09:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Much cheaper at RockAuto. part numbers CBF10 - 10 amp CBF15 - 15 amp CBF20 - 20 amp CBF30 - 30 amp
[Re: BDW]
#2246882
02/03/17 10:17 PM
02/03/17 10:17 PM
Supercuda
About to go away
About to go away
up yours
Seems like a nice upgrade, but how often do you need to replace a fuse? Depends on how often you are in the bad part of town, at night, with it raining buckets and dead batteries in your flashlight.
[Re: Supercuda]
#2246934
02/03/17 11:24 PM
02/03/17 11:24 PM
Posts: 4,941 Florida
BDW
Seems like a nice upgrade, but how often do you need to replace a fuse? Depends on how often you are in the bad part of town, at night, with it raining buckets and dead batteries in your flashlight. Well if it's night and you don't have a flashlight, your not changing that ATM fuse either..... On a side note, I wonder why they only specify it for GM?
[Re: Chal340]
#2246949
02/03/17 11:59 PM
02/03/17 11:59 PM
Supercuda
About to go away
About to go away
up yours
If you have the ATM fuse that lights up when it blows you could (built in LED).
[Re: MI_Custumz]
#2769371
04/29/20 07:11 AM
04/29/20 07:11 AM
BDW
If you’re constantly changing blown fuses, breaker style. I’d prefer the mini blade adapter, but can’t find those, might be discontinued?
[Re: moparx]
#2769545
04/29/20 03:07 PM
04/29/20 03:07 PM
Posts: 2,939 Calgary, Alberta Canada
a12rag
If you’re constantly changing blown fuses, breaker style. if you are constantly blowing fuses, i would look into just WHY the fuses are constantly blowing, before the "magic smoke" escapes from the harness just before the flames appear ! X2 . . . fuses are in circuit to protect for overload and short circuit . . . typically in our cars, it is usually a short circuit that creates the problem ! (hot wire against ground) . . . fix the problem and don't blame the fuse !
[Re: moparx]
#2769638
04/29/20 07:14 PM
04/29/20 07:14 PM
Posts: 2,132 CA
crackedback
CA
If you’re constantly changing blown fuses, breaker style. if you are constantly blowing fuses, i would look into just WHY the fuses are constantly blowing, before the "magic smoke" escapes from the harness just before the flames appear ! Yep, that's the solution!
