Re: Hemi head CCs
[Re: cudaman1969]
#3098085
11/29/22 01:51 PM
11/29/22 01:51 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Mopar gave NHRA a spec of 168.5 CC for the iron 426 heads, they were never anywhere close to that stock. Always bigger by 10 to 20 CC. I raced a street hemi in NHRA stock for several years back in the mid 1970, none of the stock used heads I bought were close to that , all of them at 180.0 CC+, I also saw around 4.0 CC variance in the combustion chambers on all of stock those heads I did have one set of the Mopar aluminum heads to build a motor for a customer and they were supposed to be 175.00 CC blueprinted
Re: Hemi head CCs
[Re: Cab_Burge]
#3098088
11/29/22 02:03 PM
11/29/22 02:03 PM
fast68plymouth
So. Burlington, Vt.
In my limited Hemi experience, most G2 heads are about 170cc ootb.
Re: Hemi head CCs
[Re: cudaman1969]
#3098379
11/30/22 01:27 PM
11/30/22 01:27 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
If your gonna try and make any power get them CC'd, if jsut a street motor guessing will work...most of the time
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hemi head CCs
[Re: W.I.N. Racing]
#3098607
12/01/22 10:08 AM
12/01/22 10:08 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Pretty sure my aluminum MP heads were 170 cc when new. Don't have my logbook here w/ me, but I'll try to remember to check it when I get home.
Re: Hemi head CCs
[Re: dragon slayer]
#3098630
12/01/22 11:26 AM
12/01/22 11:26 AM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
I've only measured two sets, one -M and one Victor Jr, and I must admit my tools are backyard quality at best*, but I came up with 170cc on one set and 172 on the other.
*ML syringe, an old beat up piece of plexiglass with a couple holes drilled in it, water, and some chassis grease.... because I'd rather measure best as I can rather than not.
Rich H.
Esse Quam Videri
