Hemi head CCs #3097967
11/29/22 12:05 AM
11/29/22 12:05 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I have the Mopar -1 aluminum head out of the box untouched, what cc is this head and what is the cc on the stock iron head?
Re: Hemi head CCs [Re: cudaman1969] #3098006
11/29/22 08:14 AM
11/29/22 08:14 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Usually in the 190cc area.
Re: Hemi head CCs [Re: cudaman1969] #3098085
11/29/22 01:51 PM
11/29/22 01:51 PM
Mopar gave NHRA a spec of 168.5 CC for the iron 426 heads, they were never anywhere close to that stock. Always bigger by 10 to 20 CC.
I raced a street hemi in NHRA stock for several years back in the mid 1970, none of the stock used heads I bought were close to that , all of them at 180.0 CC+, I also saw around 4.0 CC variance in the combustion chambers on all of stock those heads shock shruggy
I did have one set of the Mopar aluminum heads to build a motor for a customer and they were supposed to be 175.00 CC blueprinted shruggy
Re: Hemi head CCs [Re: Cab_Burge] #3098088
11/29/22 02:03 PM
11/29/22 02:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In my limited Hemi experience, most G2 heads are about 170cc ootb.
Re: Hemi head CCs [Re: fast68plymouth] #3098148
11/29/22 04:49 PM
11/29/22 04:49 PM
fredericksburg,va
fredericksburg,va
Thanks I got something to work with since I don’t have a cc contraption
Re: Hemi head CCs [Re: cudaman1969] #3098379
11/30/22 01:27 PM
11/30/22 01:27 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
If your gonna try and make any power get them CC'd, if jsut a street motor guessing will work...most of the time
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hemi head CCs [Re: W.I.N. Racing] #3098607
12/01/22 10:08 AM
12/01/22 10:08 AM
an8sec70cuda Offline
Pretty sure my aluminum MP heads were 170 cc when new. Don't have my logbook here w/ me, but I'll try to remember to check it when I get home.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi head CCs [Re: an8sec70cuda] #3098627
12/01/22 11:12 AM
12/01/22 11:12 AM
VA
dragon slayer Offline
VA
Make sure they are not already milled. If so they may be in the 168-70 range.
Re: Hemi head CCs [Re: dragon slayer] #3098630
12/01/22 11:26 AM
12/01/22 11:26 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've only measured two sets, one -M and one Victor Jr, and I must admit my tools are backyard quality at best*, but I came up with 170cc on one set and 172 on the other.
*ML syringe, an old beat up piece of plexiglass with a couple holes drilled in it, water, and some chassis grease.... because I'd rather measure best as I can rather than not.
Rich H.
Esse Quam Videri
Re: Hemi head CCs [Re: ZIPPY] #3098708
12/01/22 04:16 PM
12/01/22 04:16 PM
fredericksburg,va
fredericksburg,va
They’re new right out of the box, good to know cc. piston deal fell through, (scammer) Now looking for another set of 4.530 x 4.5 crank
Re: Hemi head CCs [Re: cudaman1969] #3098942
12/02/22 01:53 PM
12/02/22 01:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
My stage v measure 174cc.
