Page 3 of 4 1 2 3 4
Re: The quest for 4’s [Re: 1980volare] #3085998
10/14/22 02:02 PM
10/14/22 02:02 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by 1980volare
Well chipping away but still struggling with climbing the ring gear. Got rid of the steel rear bumper. Total weight with brackets was 70lb, used a 68-73 glass nova rear bumper, don’t tell anyone. Made this pass and then it rained unfortunately. Pedaled twice to keep the wheelie down but still managed a PB 60’ 330 and 1/8. Would have been a 5.0x if it would’ve stayed down. We will get it there. Also needs a touch more preload in the left caltrac bar
https://youtu.be/CtMvw-D3Eoc
What is the gear in your trans and the rear gear??
Also when you make a tube or "normal" front end and get rid of all that transverse T bars, Go a little heavy on the front springs to calm down all that stored energy and pitch rotation. Also when taking weight off the front , IF you can, slide the engine forward an inch or so, youll be amazed at what it does for the bias without adding weight to the car.
Good luck, you have a TON of potential in this combo up
....BAD A$$ STREET CAR.....
Re: The quest for 4’s [Re: n20mstr] #3086025
10/14/22 03:04 PM
10/14/22 03:04 PM
Dayton, OH
1980volare Offline OP
My man card has just been revoked.
Dayton, OH
1.80/4.10
Re: The quest for 4’s [Re: 1980volare] #3086041
10/14/22 04:04 PM
10/14/22 04:04 PM
N
n20mstr Offline
n20mstr  Offline
N
1.80/4.10
Theres part of your problem, get rid of the 1.80
probably need 1.49 or 1.58 depend on what trans you have.
Re: The quest for 4’s [Re: 1980volare] #3094286
11/15/22 08:52 AM
11/15/22 08:52 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Any updates on this? bump
Re: The quest for 4’s [Re: racerx] #3094648
11/16/22 01:20 PM
11/16/22 01:20 PM
Dayton, OH
Dayton, OH
Been a few busy weeks. Ended up nipping a headgasket and damaging the head. Decided to pull the engine as it’s been 3 years. Bearings and everything look so good I’d reuse them if I didn’t already have new. Got a new head from the dealer and everything is going back together this weekend. Some valve springs were a little low 100lb on the seat should be around 150lb so I’m sure there’s some power to be had there. Did manage to go 5.17 at 118 on the pass with the expired headgasket, I’d like to think it was a 5.0-4.9 pass but I don’t want to dwell on that. Sent the injectors off to be flowed and they were a touch dirty and the particular cylinder was 7% off from the rest leading to head gasket issue.
Once the engine is back together this weekend the foxbody front suspension stuff will be going down.
Re: The quest for 4’s [Re: 1980volare] #3094658
11/16/22 01:34 PM
11/16/22 01:34 PM
Dayton, OH
Dayton, OH
Racerx wanted to see under the hood, and bonus melted aluminum!
E2EA2620-652F-4C93-B9A8-FFADAA45CCE4.jpeg5BEC39DA-45B8-4903-9743-0954058180EF.jpegC15EEF78-B8F7-4841-922A-208756A4E8FE.jpeg
Re: The quest for 4’s [Re: 1980volare] #3094683
11/16/22 02:08 PM
11/16/22 02:08 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looking at how your chambers are cleaner near one plug it makes me wonder if there would be any benefit to lighting up the other 8 plugs?
That thing is moving!
68 Barracuda Formula S 340
Re: The quest for 4’s [Re: Bad340fish] #3094689
11/16/22 02:19 PM
11/16/22 02:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What exhaust manifolds ?
Re: The quest for 4’s [Re: Bad340fish] #3094694
11/16/22 02:23 PM
11/16/22 02:23 PM
Dayton, OH
Dayton, OH
There is talk around 30-40hp gain from both plugs. That’s another change I’m going to make this winter.
Stock 5.7 truck manifolds
Re: The quest for 4’s [Re: 1980volare] #3094756
11/16/22 05:25 PM
11/16/22 05:25 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thank you sir wave keep us posted popcorn
What size turbos are they? for some reason i thought you ran a single.
Re: The quest for 4’s [Re: racerx] #3094764
11/16/22 05:45 PM
11/16/22 05:45 PM
Dayton, OH
Dayton, OH
7675 cheap precisions, I had a single before but the packaging of twins makes it so much better imo.
Re: The quest for 4’s [Re: 1980volare] #3094783
11/16/22 06:29 PM
11/16/22 06:29 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thank you thumbs
Re: The quest for 4’s [Re: 1980volare] #3094800
11/16/22 07:36 PM
11/16/22 07:36 PM
ohio
dragon Offline
dragon  Offline
ohio
I have seen this car run there is a lot left in it it seems to be a hand full at times it will start lifting the wheels down track when he soft on launch.when I have seen it was test and tune the don't do a lot to the track he does a good job useing his head to stay out of to much trouble when it makes a good pass its a bear but I don't think I ever seen him make a pass that the car is capable of but it's fun to watch
Re: The quest for 4’s [Re: 1980volare] #3095029
11/17/22 04:20 PM
11/17/22 04:20 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Those match the exh ports of the BGE 6.4 heads?
I know the intakes match the flow of 426 hemi heads
Re: The quest for 4’s [Re: Dart 500] #3098588
12/01/22 08:11 AM
12/01/22 08:11 AM
Dayton, OH
Dayton, OH
Yes all 09+ heads have the same exhaust port shape.
Re: The quest for 4’s [Re: 1980volare] #3100034
12/06/22 08:36 AM
12/06/22 08:36 AM
Dayton, OH
Dayton, OH
I think I’ve decided to give it one more go with the transverse torsion bars. By my math doing foxbody front suspension, im dropping 200lb which will put me around 48% on the nose which won’t help with power wheelies. As much as I’d like to do it I think it will hurt unless I take more weight out of the rear to counteract it(which is tough)
We will see though. I may get bored in the garage and just cut it off. I think it will still go a 4 with the torsion bars:
Re: The quest for 4’s [Re: 1980volare] #3100066
12/06/22 11:12 AM
12/06/22 11:12 AM
Mo.
racerx Offline
racerx  Offline
Mo.
luck......with which ever route you take.
I know those wheelies can be hard to tame.
Re: The quest for 4’s [Re: racerx] #3136125
04/07/23 07:47 AM
04/07/23 07:47 AM
Dayton, OH
Dayton, OH
No crazy winter upgrades, swapped some custom valved afco bgx rear shocks on, and switched to the new holley smart coils for the hemi to fire both plugs. Hopefully get to the track next month, picked up another project, and I’d rather have it done first. may start another thread specifically for it. It’s getting a stock 5.7 and a 727, and holley efi, and I’m going to try and go 9s with it for as cheap as possible, hopefully under $7500 or so.
Re: The quest for 4’s [Re: 1980volare] #3136127
04/07/23 07:53 AM
04/07/23 07:53 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Don't let it get to far back on the back burners,Always like to hear your updates on that car.
Re: The quest for 4’s [Re: 1980volare] #3136134
04/07/23 08:40 AM
04/07/23 08:40 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Just need a wagon to complete the trifecta! grin
'63 Dodge 330
11.19 @ 121 mph
Page 3 of 4 1 2 3 4
