M/T et street radials
#309413
05/05/09 11:41 PM
05/05/09 11:41 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
anybody have a section width on a 295/65/15 on a 10" rim??????? and or a picture on a A body
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: M/T et street radials
[Re: blownzoom440]
#309415
05/06/09 06:49 AM
05/06/09 06:49 AM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
i have a set of MT 29.5/10.5 stiff side wall slicks on now and would like to change to the 295/65-15 ET street drag radials.will these hook for a 10 teen car?will they work with a trans brake?
WAXER
[Re: QWK_ENUF]
#309417
05/06/09 07:46 AM
05/06/09 07:46 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
They hook on mine goin 9.50s. Not sure about the transbrake. I've asked the same question and get mixed results. I can hopefully let you know in a week or so if the doctor clears me to get back to normal when I see him in about 30 minutes. CHIP
[Re: ToddP]
#309418
05/06/09 08:57 AM
05/06/09 08:57 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
12.875" on a 10" rim @ 17 psi.
Are you sure its 12.875 and not 11.875? The MT website shows the section width as 11.9?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#309419
05/06/09 09:57 AM
05/06/09 09:57 AM
BradH
The set I had measured right about 12" when mounted on an 8" rim, so being closer to 13" section on a 10" rim sounds right to me.
I've found M/T's specs have been "in the ballpark" on a couple of occasions, this being one of them. Another is that my 275/60R15s are actually shorter than 28" tall.
