M/T et street radials #309413
05/05/09 11:41 PM
05/05/09 11:41 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
anybody have a section width on a 295/65/15 on a 10" rim??????? and or a picture on a A body
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: M/T et street radials [Re: Stroker Scamp] #309414
05/06/09 04:55 AM
05/06/09 04:55 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i will try to measure mine later today for you.
Re: M/T et street radials [Re: blownzoom440] #309415
05/06/09 06:49 AM
05/06/09 06:49 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
i have a set of MT 29.5/10.5 stiff side wall slicks on now and would like to change to the 295/65-15 ET street drag radials.will these hook for a 10 teen car?will they work with a trans brake?
WAXER
Re: M/T et street radials [Re: Stroker Scamp] #309416
05/06/09 07:44 AM
05/06/09 07:44 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
12.875" on a 10" rim @ 17 psi.
photo's of E body
Re: M/T et street radials [Re: QWK_ENUF] #309417
05/06/09 07:46 AM
05/06/09 07:46 AM
an8sec70cuda Offline
They hook on mine goin 9.50s. Not sure about the transbrake. I've asked the same question and get mixed results. I can hopefully let you know in a week or so if the doctor clears me to get back to normal when I see him in about 30 minutes. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: M/T et street radials [Re: ToddP] #309418
05/06/09 08:57 AM
05/06/09 08:57 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Are you sure its 12.875 and not 11.875? The MT website shows the section width as 11.9?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: M/T et street radials [Re: Von] #309419
05/06/09 09:57 AM
05/06/09 09:57 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The set I had measured right about 12" when mounted on an 8" rim, so being closer to 13" section on a 10" rim sounds right to me.
I've found M/T's specs have been "in the ballpark" on a couple of occasions, this being one of them. Another is that my 275/60R15s are actually shorter than 28" tall.
