Re: ignition overboard. [Re: jwb123] #3092305
11/07/22 01:59 PM
11/07/22 01:59 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Also many ignition boxes will retard the timing at higher RPM's and that is the reason for lost power not spark intensity.
Is this common with MSD's or you are talking about your cheaper systems Crane/Mallory boxes never herd before shruggy
Re: ignition overboard. [Re: Bad340fish] #3092307
11/07/22 02:05 PM
11/07/22 02:05 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
If you want to add data logging, and you want to eventually add boost. Buy an EFI system and use just the ignition side of it. Data logging like crazy built in, precise ignition control etc. I would do that and run 8 coils.
I know of a guy that has the Holley system in place now and he data logs though it.And he's preparing to go plug on coil setup.
Re: ignition overboard. [Re: racerx] #3092330
11/07/22 03:04 PM
11/07/22 03:04 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
It's easy enough to dial back in with a grid...IF it is an issue. I got a grid when they were fairly new (2016?) and used it with a crank trigger, 6AL using the "Legacy" connector. I upgraded to the proper grid amplifier (7 series) after about a season and have had no problems. I did rewire the car, prior to install. I hear lots of issues with ign / electronics are caused by poor and or old wiring. shruggy
Re: ignition overboard. [Re: Tig] #3092334
11/07/22 03:11 PM
11/07/22 03:11 PM
When I switch to the early MSD race boxes, 404B and 404C, my hemi car started way better and idled way better than it had with the Mopar race chrome box with the blue heat sink and the Hayes,which later became knowns as Stinger ignitions, race boxes up
Same thing later on using the 7 race boxes, I liked the MSD7AL2 races boxes the best, not the MSD7AL3 do to having one fail after 15 minutes running during a engine dyno test puke shruggy
I have two MSD7C boxes, one early and one later box, they are not the same looking confused work
They both tested good when I got them several years back, probably use them on some of my future street cars devil
Re: ignition overboard. [Re: racerx] #3092346
11/07/22 03:46 PM
11/07/22 03:46 PM
Washington
madscientist Offline
Washington
All ignition boxes retard. Doesn’t matter what name is on the box. And spark intensity does matter.
Re: ignition overboard. [Re: an8sec70cuda] #3092347
11/07/22 03:46 PM
11/07/22 03:46 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
Originally Posted by an8sec70cuda
I'll stick w/ my dinosaur 6AL. If I ever "upgrade" again, it'll be to an old 7AL-3, or something similar, just to see if the 7 is worth any power. The only time I've killed an old analog box was when I tried to crank it w/ a nearly dead battery.
x2 on this as well. I haven't ever had an issue with the analog 6AL's. I have one of those plus the start/step retard module and it works great.
If I ever get to the point where I need additional ignition features I'd do what Clark suggested, move to something like a Megasquirt, Haltech or Holley EFI just to handle the timing side. The grid system looks great but they seem finicky.
Re: ignition overboard. [Re: madscientist] #3092359
11/07/22 04:26 PM
11/07/22 04:26 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It must happen with EFI systems as well. Mine has a "spark latency" setting that can be adjusted to compensate for this problem if you happen to have it.
68 Barracuda Formula S 340
Re: ignition overboard. [Re: Bad340fish] #3092416
11/07/22 09:30 PM
11/07/22 09:30 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thanks gents ....lots of knowledge here, interesting opinion here. up
Re: ignition overboard. [Re: Al_Alguire] #3092452
11/07/22 11:03 PM
11/07/22 11:03 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Originally Posted by Al_Alguire
FWIW I have three cars with MSD Grids in them, there is also one in the heads up car. We have only had ONE fail in all the years using them and that was from some welding for a front bump steer kit hit the crank trigger pickup wire and fried it. Otherwise they have been trouble free and one of them is on its 7th year in the dragster
Same here. Last 3 cars and current car have Grids. Also have a Grid in the boxes for my son's project car. I like it, but honestly, I like the Digital 7531 box I've used in the past. I have actually considered ripping it out and going backwards....LOL....to a 7531. But have never had an issue with any of the Grids. Had one in my street car with a lot of road time.
"Any fool can know. The point is to understand"
- A. Einstein
Re: ignition overboard. [Re: Bad340fish] #3092471
11/08/22 12:06 AM
11/08/22 12:06 AM
Washington
Washington
I’m sure it does. All electronics have a slew rate.
Re: ignition overboard. [Re: racerx] #3092530
11/08/22 11:09 AM
11/08/22 11:09 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A whole lot of people don’t know this or check this, or are capable of checking this.
Most modern EFI control boxes address this with a comp table. Usually only happens with mag sensors.
No way I would spend the money on a Digital 7 when there are much better and reliable options out there, and your current ignition is working fine.
Others opinions have merit, but I see no reason to dive in half way.
Re: ignition overboard. [Re: TRENDZ] #3092674
11/08/22 08:05 PM
11/08/22 08:05 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
iagree with this statement but I'm in a position to upgrade my box at a decent price with room for growth work( more options) right now seeing the only thing that's different from my digital 6 is hotter mj 's (130 verse 190) and the data logging etc.
Re: ignition overboard. [Re: racerx] #3092769
11/09/22 09:21 AM
11/09/22 09:21 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We picked up a little ET retarding the timing 2 degree's from 5000 to 7500RPM, from a 35 degree base, easy to do using a grid.
Theoretically, the older analogue Ignition units should have more of an issue with latency / propagation delay due to the components and the design used. Digital stuff is way quicker in this respect so intrinsically more accurate at maintaining a requested timing curve.
A hotter spark (more energy) helps at the top end as the primary / secondary coil field doesn't have time to drop to zero at high RPM (field collapse, de-saturation of the coil). In effect your spark gets weaker as the change of field is less, especially true if you have only one coil feeding multiple cylinders. it's physics, you can't get away from it, the square type coils suffer from this less than the canister types due to a more efficient design so I'm led to believe.
Just my 2 penneth, not wishing to start an argument here just a reasoned discussion up
Re: ignition overboard. [Re: Tig] #3092825
11/09/22 12:14 PM
11/09/22 12:14 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thank you up coffee
Re: ignition overboard. [Re: racerx] #3092844
11/09/22 01:32 PM
11/09/22 01:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Never seen anything gained by taking timing out in high gear on an NA car and have tried on a few different cars. The one thing I have seen that ALWAYS works is adding timing in lower gears to base in an NA car. It has always netted quicker ET's....
IMO the Grid is much more use friendly than the old 7530, 7531 and 75301 box, but otherwise the results are the same. Just sold my last two digital 7 boxes to fellow members here
Re: ignition overboard. [Re: Al_Alguire] #3092874
11/09/22 03:33 PM
11/09/22 03:33 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
It's possible had other issues, we went from a single 4 to a T/R and it wanted less timing. We had run the single 4 up to 38 Degrees max timing. Since it ran just as well / slightly better with less timing with the T/R we left it at that. Does seem to cruise better with more timing in the mid rpm range though shruggy
Re: ignition overboard. [Re: Al_Alguire] #3092892
11/09/22 04:18 PM
11/09/22 04:18 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I know many years ago, John Hagen's Pro Stock car was pulling timing out in high gear. At the time he was running a couple MPH faster then Glidden. Glidden was the only one to figure it out, and asked John how much timing he was taking out? "I don't know what you're talking about Bob?" LOL.
Years ago, I once dropped the timing from 36* to 31*, to see if I could kill some ET. The car picked up over 1 mph, and went faster...
I bought one of those boxes from you Al. I know it fires the car up...
69 GTX 68 Road Runner
Re: ignition overboard. [Re: JERICOGTX] #3092896
11/09/22 04:24 PM
11/09/22 04:24 PM
I've play with total ignition timing on iron headed BB years ago trying to slow them down as well as make them go as fast as I could, those motors like from 34 to 36 BTDC, not 33 or 37 BTDC shruggy
Re: ignition overboard. [Re: Al_Alguire] #3093048
11/10/22 08:20 AM
11/10/22 08:20 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
This is a totally valid and sensible point of view. Tested and proven. I assume based on a dyno tuned engine with an optimized timing map. It sort of proves that timing maps should be load based. A dyno is putting maximum load on the engine in determining maximum power output. It shows you only maximum load timing. Taking some of that load away (through gear selection) should require more timing.
Given a large majority of end users don’t have dyno tuned engines, or load based timing, it is easy to see how “high gear retarting” and “added timing in low gear” can be interchanged definitions based on your point of reference.
Regardless of your point of reference, load based timing is the best way of using the energy your engine is capable of making throughout the run.
This is another net positive for using efi to control timing.
