Originally Posted by racerx
If you want to add data logging, and you want to eventually add boost. Buy an EFI system and use just the ignition side of it. Data logging like crazy built in, precise ignition control etc. I would do that and run 8 coils.
I know of a guy that has the Holley system in place now and he data logs though it.And he's preparing to go plug on coil setup.
All ignition boxes retard. Doesn’t matter what name is on the box. And spark intensity does matter.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
