If your happy with what you have now and don't plan on adding more power later use what you got
Are you aware that when MSD brought out the digital 6 boxes, they had a lot of failures do to some of the internal components failing
I have bought and raced with the bigger MSD race boxes starting with the 404 series boxes back in 1974 or so and then switching to the 7 boxes later, I had one MSD7C box fail at the race's years ago
I did kill one race box mounted on the Iner fenderwell in the engine compartment by flooding it with water while cleaning up the engine compartment
MSD fix it with no charge
As far as the MSD grid and ignition box needed to go with it I have heard they are awesome
I bought one, MSD grid, years ago and haven't use it yet
I did call MSD to see which MSD ignition boxes it would work with and which boxes it wouldn't work on, they said it would work on all the 7 series race boxes I own back then
