Page 5 of 5 1 2 3 4 5
Re: Predator builds [Re: Al_Alguire] #3091516
11/03/22 10:41 PM
11/03/22 10:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That's Nice stuff.
I just got some ole -1s
Re: Predator builds [Re: FastmOp] #3091550
11/04/22 07:33 AM
11/04/22 07:33 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Beautiful!! What is the combo?
Re: Predator builds [Re: FastmOp] #3091610
11/04/22 12:42 PM
11/04/22 12:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Originally Posted by FastmOp
That's Nice stuff.
I aint got one of them spinny things though laugh2
Re: Predator builds [Re: powertrip] #3091614
11/04/22 12:50 PM
11/04/22 12:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
KB Hemi block and Predator heads, Bryant crank, Jesel belt, blah blah blah. 596" single 4 for brackets and mainly .90 racing. Should be 1130ish or so.
Also freshening our 600-13(smaller version not the X or 3X) 655" deal. Should both make similar power numbers. Be interesting to see how they fair as the combos are pretty close to each other in terms of cam numbers and compression carb and both being bracket pieces. But one with a "spread port" type head and the other with a typical BBM type head albeit with a much larger intake valve and cross section. One is 69" bigger as well. We know what the 655 made before and this time it should be a bit better with not so much piston to wall and more compression. Hope to dyno them back to back and Ill share more later when they are both done. Should be an interesting comparison.
Re: Predator builds [Re: powertrip] #3091616
11/04/22 01:08 PM
11/04/22 01:08 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
There you go, get started on building that Drag Week motor!! up
I kinda jumped the shark on that already....There was a set of those heads on here complete for $6500 and if I can find them, and if the owner might be interested in some trading parts and cash, that becomes a possibility....So I did put a post in the want ads...
In the meantime, I am working on a fix for my issue on the Hemiroid, and the new cam showed up I will post updates after the weekend. ....Meanwhile, I am nose deep in this thread.
Re: Predator builds [Re: Dragula] #3091619
11/04/22 01:22 PM
11/04/22 01:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Make sure if you are chasing used Predator parts you get the post NRC stuff, the pieces that Indy now casts after Steve Gill updated the entire casting......
Re: Predator builds [Re: Al_Alguire] #3207698
01/24/24 03:35 AM
01/24/24 03:35 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
So... does Indy still make these heads? Can't tell by their website it's straight out of the 90s...
Re: Predator builds [Re: CokeBottleKid] #3207728
01/24/24 07:19 AM
01/24/24 07:19 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Yes.
69 GTX 68 Road Runner
Re: Predator builds [Re: JERICOGTX] #3207801
01/24/24 01:32 PM
01/24/24 01:32 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I wanted to do Predator build initially. Decided I wanted to keep it more streetable for now and went HEMI.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Predator builds [Re: 6PKRTSE] #3207802
01/24/24 01:36 PM
01/24/24 01:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW they just updated their website. Not sute its better but it is new. At least you can search now.
https://www.indyheads.com/product/h-beryl-seats/
Re: Predator builds [Re: CokeBottleKid] #3208037
01/25/24 09:26 AM
01/25/24 09:26 AM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
There was a shop tour video on 'Youtu' around the time the Wheatcrafts bought Indy and I think I counted 7 or more pairs of raw new castings. Like Al said the later versions have casting improvements which may or may not be necessary for some milder builds IDK. Scott Brown is in partner with some guys which have a 'big' port cnc program for them FWIW.
Re: Predator builds [Re: HardcoreB] #3208334
01/26/24 05:19 PM
01/26/24 05:19 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Had my hands on an old predator headed engine that Chris Rini used to run, made by Muscle motors. Took the heads to a flow bench and they really weren't very spectacular. Sure, they were old,maybe million valve jobs etc. But still raised some thoughts. The exhaust was decent.
Plynouth VIP '67 TT IC EFI
