Transsmision #3090487
10/30/22 02:42 PM
10/30/22 02:42 PM
PARAGOULD
LKB Offline OP
LKB  Offline OP
PARAGOULD
I have a 97 dodge ram 1500 4x4 I bought a transmission and put it in well it only shifts when it wants to and I got under found that the neutral safety switch plug I think that's what it is was unplugged well it keeps coming unplugged How can I make it stay plugged in. Help. Thanks in advance
Re: Transsmision [Re: LKB] #3090560
10/30/22 10:00 PM
10/30/22 10:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
not familiar with the newer stuff but their is usually a lock of some sort that engages when plugged in. You can usually find the connectors at napa or online. Would be helpful if you research and find the correct name application. only other option would be a bit of plastic adhesive wink
might also try a Ram forum beer
Re: Transsmision [Re: TJP] #3090561
10/30/22 10:10 PM
10/30/22 10:10 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
Rockauto has one. Part number is ACDELCO PT2139 Check it out
Re: Transsmision [Re: moparjo68] #3090706
10/31/22 01:49 PM
10/31/22 01:49 PM
moparx Offline
moparx  Offline
going for a "WAG" here..........
doesn't the neutral safety switch look and act like the old 727/904 switches ? three wires, center wire is ground for the starter relay, while the two outer wires complete the reverse light circuit ? [all contacting through the rooster comb of the valve body]
then, there is the other connector[s] that control the overdrive and lockup, as well as the governor function in the electronically controlled [RE] transmissions ?
beer
Re: Transsmision [Re: moparx] #3090734
10/31/22 02:47 PM
10/31/22 02:47 PM
A727Tflite Offline
A727Tflite  Offline
beer
The N/S is an input to the TCM/PCM.
When it doesn’t “see” the N/S it can cause loss of OD, other issues.
Re: Transsmision [Re: A727Tflite] #3091371
11/03/22 11:56 AM
11/03/22 11:56 AM
moparx Offline
moparx  Offline
beer
this is just on the RE's ? shruggy
beer
Re: Transsmision [Re: moparx] #3091376
11/03/22 12:09 PM
11/03/22 12:09 PM
A727Tflite Offline
A727Tflite  Offline
beer
beer
No, RH needs to see the N/S for O/D and L/U.
The1,2,3 shift occurs purely by hydraulics but O/D and L/U is electronic over hydraulic.
Re: Transsmision [Re: LKB] #3091449
11/03/22 04:31 PM
11/03/22 04:31 PM
IMGTX Offline
IMGTX  Offline
I have had that problem.
There is a small lip inside the connector that helps grip the switch. Often the connectors get hard and it takes a lot of force to get the lip to slide onto the switch.
Usually if you can force it a little harder it will snap and stick onto the switch. Not always but often it will work.
I have used a prybar and the back of a socket to force them on.
Hope it helps
