Consistency of ARP rod bolt length
#3089132
10/25/22 03:01 PM
10/25/22 03:01 PM
Posts: 7,521 Minnesota
Hemi_Joel
Minnesota
https://www.enginelabs.com/news/what-i-learned-today-with-jeff-smith-reverse-rod-bolt-stretch-tech/This article says you can look up the ARP part number for a rod bolt, get the length, and measure it on an already assembled engine to determine if it has the proper stretch/torque. I have not found the lengths to be sufficiently consistent. Even on one set of rods they vary enuff that I have reset the length gauge from one bolt to the next. What have you found for length consistency?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Consistency of ARP rod bolt length
[Re: Hemi_Joel]
#3089133
10/25/22 03:04 PM
10/25/22 03:04 PM
Posts: 10,049 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I have found this not to be the case on rods that come with ARP bolts. Some are the same, some 2-3-6 thousands off using the same tool in the article.
Possibly a NEW package of un used bolts from ARP might show different. Bit I do not know.
That article does not seem to be correct if they claim all bolts are the same from the start.
STOP POTATO HATE!
[Re: Hemi_Joel]
#3089151
10/25/22 05:02 PM
10/25/22 05:02 PM
Posts: 88 IL
83hurstguy
IL
The last two engines with ARP 2000 rod bolts (Molnar rods) had around 0.006 variance, so the gauge was different on nearly every bolt.
I feel like the wording is vague, and don't think Jeff Smith was actually suggesting measuring the bolts without loosening and measuring the change. The way I read the article, you take a baseline measurement, loosen the bolt, recheck the length to calculate change and that will tell you if they were torqued correctly or not. Odds are if 1-2 rod bolts are correct, you don't have to check all 16. I pasted the paragraph below for quick reference. He didn't say look up the length as much as look up the original stretch requirements... I actually challenge that approach from a different angle because ARP typically defers required rod bolt stretch to the rod manufacturers.
This technique can also be used to check the veracity of an engine that you may not know the history of. If the rod bolts are from ARP, you can look up the part number and then search for the online instructions on the ARP website to find the original stretch numbers and compare these numbers to what you see on the actual bolts. You may be surprised at what you find, since many engine builders do not use rod bolt stretch when torquing the rod bolts.
[Re: dvw]
#3089215
10/25/22 10:07 PM
10/25/22 10:07 PM
Posts: 1,266 New York, USA
Chargerfan68
New York, USA
In my experience none of the bolts are close. You need to check them individually. Doug Exactly my experience as well. Measure individually…..it is definitely important and worth it to do it. Next rebuild, it could prevent a potential bomb.
[Re: Hemi_Joel]
#3089421
10/26/22 03:44 PM
10/26/22 03:44 PM
Posts: 16,936 NC
440Jim
NC
What have you found for length consistency? Recent set of rods with ARP bolts. 1.7590 1.7615 1.7550 1.7571 1.7630 1.7605 1.7628 1.7626 1.7588 1.7567 1.7556 1.7594 1.7592 1.7574 1.7630 1.7588
[Re: 440Jim]
#3089542
10/27/22 12:11 AM
10/27/22 12:11 AM
Hemi_Joel
Minnesota
It would be SO nice if they would precision grind the length. Then we could set the gauge once.
I've been using an angle gauge, then check the length. The angle gauge is pain when the motor is already installed.
[Re: Hemi_Joel]
#3089549
10/27/22 01:13 AM
10/27/22 01:13 AM
Posts: 43,719 Bend,OR USA
Cab_Burge
I try to write down the torque needed for each bolt to get it to stretch to the middle of recommended lengths, IE.0057 to .0062 shoot for .0059 to .0060. I do this on the bench with the rods in a rod vice, one bolt at a time If i was smart I would remove all the bolts and measure the free lengths and then match them up in the rods so both bolts are the same length to start with Instead of doing one at a time starting with no torque and setting the gauge each time on every bolt I had one Molnar bolt overstretch at 55 Ft. lbs. to start with, all the rest needed 68 Ft lbs. to get anywhere near close the minimum stretch
[Re: Cab_Burge]
#3090091
10/29/22 12:25 AM
10/29/22 12:25 AM
Posts: 1,793 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
...I had one Molnar bolt overstretch at 55 Ft. lbs. to start with, all the rest needed 68 Ft lbs. to get anywhere near close the minimum stretch Same here, I record each bolt, before & after, went through 3 "warm-up" cycles before I did the final install. Having said that, Eagle recommended 75 ft-lbs for 0.0064-0.0068 stretch on my H-beam rods with ARP S2000 bolts...I went up to 85 ft-lbs and that only got me to about 0.0055, take a look at the attachment tracker.
[Re: moparx]
#3090889
11/01/22 07:58 AM
11/01/22 07:58 AM
Diplomat360
Windsor, ON, Canada
agreed Cab. i was wondering what the OP got for a measurement on the big end. [if he measured it as was described by the stretch and torque he mentioned] Sorry, I'm a little late with the follow-up to your question. Well, here is another table with the values. My process actually was to: 1) put the rod in the rod-vise, go through 4 bolt tightening cycles 2) put the rod & bearings in the rod-vise, go through 1 more cycle and measure the bearing ID All that goes into my table, which gives me an actual bearing clearance, as close to the operating conditions as possible (less heat, stretch, etc.). Not sure why I had missed the 'HOUSING' size recording for the rods...or it could be that I just tossed that on my whiteboard and missed recording it in my spreadsheet. All in all I got pretty consistent bearing clearance of 0.002 with a low spot of 0.0019 and a high of 0.0023, but given how tiny that difference is I was happy with the results.
[Re: moparx]
#3091052
11/02/22 12:57 AM
11/02/22 12:57 AM
Hemi_Joel
Minnesota
agreed Cab. i was wondering what the OP got for a measurement on the big end. [if he measured it as was described by the stretch and torque he mentioned] I haven't used torque for so long, I can't remember any measurements. I use an angle gauge, then measure stretch. The big ends check fine. If it takes more torque to achieve proper stretch on any given bolt, it shouldn't affect the big end distortion. Stretch is an indicator of clamping force. If the stretch is within spec, the clamping force should be equal regardless of how much torque it took to achieve it. Variations in the rolling of the threads during manufacturing can affect torque requirements.
[Re: Hemi_Joel]
#3091054
11/02/22 01:38 AM
11/02/22 01:38 AM
Cab_Burge
I measured the ARP 2000 rod bolt stretch on a set of Scat 7.100 long rods with the Mopar big end today, I had to call Scat to try and get their recommended stretch and torque recommendations on thses bolt( 1.800 under head bolt length, 7/16 bolt diameter. No luck so i called the machine shop that I had pin fit these rods to the wrist pins in the pistons I'm going to use and had them check the rods for roundness and fit on the I.D for the rod bearings, they didn't return the instructions that came with those rods so I called then 2nd. They had to look and called me back and siad they didn't find the original sheet but looked on line at Scat site and came up with 70 Ft. lbs. with ARP lube and no longer than .0060 stretch. My message is I saw around .0032 rod bolt length variances on these rod bolts with no load, I torque them all to70 Ft. Lbs. and that stretched them between .0041 up to .0053 I'm thinking I will loosen several of them tomorrow and retorque them up to 75 Ft. lbs. and see if that helps getting them closer to .0057 up to .0060
[Re: Hemi_Joel]
#3091408
11/03/22 02:15 PM
11/03/22 02:15 PM
Posts: 20,235 north of coder
moparx
agreed Cab. i was wondering what the OP got for a measurement on the big end. [if he measured it as was described by the stretch and torque he mentioned] I haven't used torque for so long, I can't remember any measurements. I use an angle gauge, then measure stretch. The big ends check fine. If it takes more torque to achieve proper stretch on any given bolt, it shouldn't affect the big end distortion. Stretch is an indicator of clamping force. If the stretch is within spec, the clamping force should be equal regardless of how much torque it took to achieve it. Variations in the rolling of the threads during manufacturing can affect torque requirements. Cab : "I measured the ARP 2000 rod bolt stretch on a set of Scat 7.100 long rods with the Mopar big end today, I had to call Scat to try and get their recommended stretch and torque recommendations on thses bolt( 1.800 under head bolt length, 7/16 bolt diameter. No luck so i called the machine shop that I had pin fit these rods to the wrist pins in the pistons I'm going to use and had them check the rods for roundness and fit on the I.D for the rod bearings, they didn't return the instructions that came with those rods so I called then 2nd. They had to look and called me back and siad they didn't find the original sheet but looked on line at Scat site and came up with 70 Ft. lbs. with ARP lube and no longer than .0060 stretch. My message is I saw around .0032 rod bolt length variances on these rod bolts with no load, I torque them all to70 Ft. Lbs. and that stretched them between .0041 up to .0053 I'm thinking I will loosen several of them tomorrow and retorque them up to 75 Ft. lbs. and see if that helps getting them closer to .0057 up to .0060 "......Cab i think my old noodle is finally figuring this out. [torque plus stretch] i hope........ he!!, back in my junkyard days, when my partner [R.I.P. Bill. ] and i built engines, we didn't know any more than to mic the crank, measure the inside of the caps with bearings installed, then use plastigauge to double check when the bolts/nuts were tightened. we didn't even calibrate the torque wrenches we were using ! fast forward to today, [50 years ! ] it's a whole new science, so i haft'a learn new tricks, and unlearn my bad habits. thank you guys for being so patient with such a doofus as i have shown myself to be !
