Differential gasket for dana axle #3090094
10/29/22 12:45 AM
10/29/22 12:45 AM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
Hi. Have been looking at rockauto and autozone for a differential gasket for the 99 dodge ram 2500 p/u with a dana/spicer 70 rear axle and 10.50 ring gear. The inspection plate has 10 bolt holes. My question is: rockauto lists differential gaskets for the dana 70 axle and the dana 70U axle. Too confusing. I have no idea which to purchase for this vehicle. Any help appreciated!
Re: Differential gasket for dana axle [Re: moparjo68] #3090096
10/29/22 01:18 AM
10/29/22 01:18 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’m sure you’re aware those were sealed with RTV from the factory right?
Re: Differential gasket for dana axle [Re: moparjo68] #3090139
10/29/22 09:31 AM
10/29/22 09:31 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Interesting question. Aren't those gaskets only like 3 or 4 dollars a piece? shruggy
But the right RTV is a better choice.
Master, again and still
Re: Differential gasket for dana axle [Re: DaveRS23] #3090144
10/29/22 09:50 AM
10/29/22 09:50 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Look up the dana 60, The 70 uses the same one. This is from the dana parts manual...
34687 Gasket - Carrier Cover
38615 RTV Silicone Sealant
Re: Differential gasket for dana axle [Re: J_BODY] #3090164
10/29/22 11:48 AM
10/29/22 11:48 AM
How would I know if its RTV sealed if i'd never taken one apart. They don't teach you anything useful like this in school.
Re: Differential gasket for dana axle [Re: moparjo68] #3090187
10/29/22 12:44 PM
10/29/22 12:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That is why you should have a FSM.
Re: Differential gasket for dana axle [Re: moparjo68] #3090195
10/29/22 01:31 PM
10/29/22 01:31 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well now you know! I prefer the Mopar gray for this task. Your rear is also coded “DSA”(noted from your build sheet post) limited slip, so be sure to add friction modifier when servicing.
Re: Differential gasket for dana axle [Re: J_BODY] #3090246
10/29/22 04:21 PM
10/29/22 04:21 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Be sure to check the gear lube bottle, when I put a tru-trac in my 9.25, I was surprised at how many brands have friction modifier already added.
Re: Differential gasket for dana axle [Re: moparjo68] #3090280
10/29/22 06:35 PM
10/29/22 06:35 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
The 2 really good gaskets I have used are the Superformance and the Lube-Locker. Both gaskets are non wicking and they don't leak. Used Superformance on my own re-builds and my Savoy for about 3 years now with zero leaks. I used a Lube-Locker on my buddies drag car and it also works nice too.
I hate cleaning sealer from surfaces when I can get a nice clean release from a good gasket twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Differential gasket for dana axle [Re: fourgearsavoy] #3090321
10/29/22 08:55 PM
10/29/22 08:55 PM
I like what Im reading about LubeLocker gaskets. I notice its offered for the Dana 60. Will the Dana 60 also fit the Dana 70 as the picture looks identical to what I need?
Re: Differential gasket for dana axle [Re: moparjo68] #3090347
10/29/22 10:17 PM
10/29/22 10:17 PM
Rittman Ohio
Rittman Ohio
[quote=moparjo68]I like what Im reading about LubeLocker gaskets. I notice its offered for the Dana 60. Will the Dana 60 also fit the Dana 70 as the picture looks identical to what I need? [/quote
They are listed as the same gasket and I have some gasket packages marked 60-70 use. I have a cast Ultimate 60 cover and I suggest a cast cover when using a gasket. Sometimes sealer will work better with a stock type steel cover though. I have used the Lube Locker with a stamped cover though and I think it's still sealed I haven't heard any complaints from the owner of the car.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Differential gasket for dana axle [Re: moparjo68] #3090440
10/30/22 11:45 AM
10/30/22 11:45 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I used the premium NAPA gasket with cork/rubber composite & thin steel in the center. And Permatex black goop. Never leaked a drop.
Re: Differential gasket for dana axle [Re: moparjo68] #3090789
10/31/22 05:55 PM
10/31/22 05:55 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
25 years ago when I was working at the IH dealer, Dana was subbing RTV for paper gaskets.
1981 Dodge D150 360 auto
Re: Differential gasket for dana axle [Re: moparjo68] #3090837
10/31/22 10:11 PM
10/31/22 10:11 PM
Dana Corp gaskets work good up scope twocents
