Temperature control cable? #3088503
10/23/22 09:37 AM
10/23/22 09:37 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
I’m in the process of restoring my grandads 74 model D100, the heater temp control cable froze up years ago and since then the only way to control cabin temp was to open the hood and adjust the temp control valve by hand. I’ve bounced around the web and the usual vendors and can’t seem to locate one…anybody got any leads as to who might have one??? Thanks in advance up
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Temperature control cable? [Re: RapidusMaximus] #3088531
10/23/22 12:29 PM
10/23/22 12:29 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
fpb shows w/a/c- 28909041
temp cable w/o a/c- 3635277
heater/def cable- 2884730
which do you need. i had some nos ones last year, not sure if i still have them but will have to look in 3 different places.
Re: Temperature control cable? [Re: trw1982] #3088538
10/23/22 12:52 PM
10/23/22 12:52 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
If you find out the length of your cable you might also be able to use a reproduction one for a B or E Body application. The other choice is if you have a lawnmower shop they might be able to make one as well.
Re: Temperature control cable? [Re: trw1982] #3088568
10/23/22 03:02 PM
10/23/22 03:02 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Well if it's the 2884730 here's a NOS one
https://www.ebay.com/itm/394115789874?
Facts are stubborn things.
Re: Temperature control cable? [Re: RapidusMaximus] #3088572
10/23/22 03:05 PM
10/23/22 03:05 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
couple guys on the Dodge FB group say take your old cable to a motorcycle shop and they can make you one to fit.
1981 Dodge D150 360 auto
Re: Temperature control cable? [Re: basketcase] #3088860
10/24/22 02:44 PM
10/24/22 02:44 PM
moparx Offline
moparx  Offline
a good bicycle shop could make one as well.
please let us know how you make out with this quest.
beer
Re: Temperature control cable? [Re: moparx] #3088889
10/24/22 04:31 PM
10/24/22 04:31 PM
Weatherford, Texas
Weatherford, Texas
Will do, restoring this truck is turning into an adventure, a few years ago I found the old temp control cable Ty wrapped under the dash and was going to try and repair and reinstall it, couldn’t find the hole in the firewall where t was supposed to pass through and I ended up giving up…now that I have all the sheet metal off the front of the truck I figured out why (lol) somewhere in this trucks past somebody ran the antenna cable through the temp control cable hole instead of the hole designed for the antenna cable that is behind the passenger door jamb… work
Meanwhile, I’m taking everyone’s suggestions to thought on fixing the temp control issue while I wait on engine parts up
1968 Plymouth GTX
Re: Temperature control cable? [Re: RapidusMaximus] #3089193
10/25/22 08:37 PM
10/25/22 08:37 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
this is from my factory parts book.
Re: Temperature control cable? [Re: trw1982] #3089269
10/26/22 07:33 AM
10/26/22 07:33 AM
Weatherford, Texas
Weatherford, Texas
Thanks trw, appreciate it, now if I can just find one…
1968 Plymouth GTX
Re: Temperature control cable? [Re: RapidusMaximus] #3089453
10/26/22 05:50 PM
10/26/22 05:50 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
