2014 Ram 1500 5.7 overcharging issue. ECM? #3087858
10/20/22 04:30 PM
10/20/22 04:30 PM
md
mopars4ever Offline OP
md
Hey all. I replaced my battery the other day and I thought that was my only issue. Well it appears it is now overcharging as I noticed the dash gauge was over to the right more than usual. I checked it while running and the voltage was around 14.4-14.5 volts at idle. I didn`t check it at a higher engine speed. I also assume that was why the battery failed without warning. I did have a check engine light on after I put in the new battery, No codes prior. The code was Code P1DF3. I turned off the light and I haven`t had the light come back on yet. I checked online and thought maybe the alternator but it says the ECM controls the charging. Do I need to go to the dealer for the new ECM if it is bad or do I have any other options. I assume I can`t replace it myself as the computer would have to be programmed? Any help is appreciated.
Re: 2014 Ram 1500 5.7 overcharging issue. ECM? [Re: mopars4ever] #3087864
10/20/22 05:00 PM
10/20/22 05:00 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Those voltages aren't out of line for a battery that needs charged. What was the date code on the new battery?
Re: 2014 Ram 1500 5.7 overcharging issue. ECM? [Re: Sniper] #3087872
10/20/22 05:36 PM
10/20/22 05:36 PM
md
md
I have to check the date. I have driven the truck for a couple days . Wouldn`t the battery have been charged by now.
OK, Went out and checked. The battery has padded cover that hides the sides of the battery. No date on top , just a small sticker that says Battery made in Spain? The resting voltage is 12.65
Re: 2014 Ram 1500 5.7 overcharging issue. ECM? [Re: mopars4ever] #3087875
10/20/22 05:50 PM
10/20/22 05:50 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
If it was overcharging it would also trip a fault code. The voltages you posted sitting and running are normal.
Re: 2014 Ram 1500 5.7 overcharging issue. ECM? [Re: NITROUSN] #3087877
10/20/22 05:58 PM
10/20/22 05:58 PM
md
md
OK, good to hear. No fault codes. I was noting the gauge and it usually sits almost dead center so I was worried when I saw it more to the right than usual.
Re: 2014 Ram 1500 5.7 overcharging issue. ECM? [Re: mopars4ever] #3087903
10/20/22 07:56 PM
10/20/22 07:56 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Don't always assume you got a good battery, have it checked... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: 2014 Ram 1500 5.7 overcharging issue. ECM? [Re: Rhinodart] #3087922
10/20/22 09:14 PM
10/20/22 09:14 PM
md
md
Good point. I will check it again after is sits for a few days.
