cal track? #3087665
10/20/22 01:31 AM
10/20/22 01:31 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
with the cal track bars is the pinion snubber used ?
did not see any info in the instructions ?
thank you !
Re: cal track? [Re: calrobb2000] #3087667
10/20/22 02:54 AM
10/20/22 02:54 AM
CA
crackedback Offline
crackedback  Offline
CA
No
Re: cal track? [Re: calrobb2000] #3087668
10/20/22 02:59 AM
10/20/22 02:59 AM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
When I installed mine, I removed the snubber. So far, so good after at least a dozen 1/4 mile passes and 4,000+ street miles drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: cal track? [Re: metallicareload] #3087722
10/20/22 09:31 AM
10/20/22 09:31 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Absolutely not!
'63 Dodge 330
11.19 @ 121 mph
Re: cal track? [Re: calrobb2000] #3087760
10/20/22 11:27 AM
10/20/22 11:27 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by calrobb2000
hi
thank you !
For best results...NO snubber and dont use a mopar SS spring or multi leaf spring. Use the caltrac split monos
....BAD A$$ STREET CAR.....
Re: cal track? [Re: n20mstr] #3087782
10/20/22 12:37 PM
10/20/22 12:37 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I agree. I run -1" split mono leafs with Caltracs moved inboard to frame rails.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: cal track? [Re: n20mstr] #3087793
10/20/22 01:09 PM
10/20/22 01:09 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
This......
"Any fool can know. The point is to understand"
- A. Einstein
Re: cal track? [Re: n20mstr] #3087839
10/20/22 03:14 PM
10/20/22 03:14 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
hi
thank you !
Yep, Cal-Tracs and SS springs do NOT play well together! DAMHIK.
'63 Dodge 330
11.19 @ 121 mph
Re: cal track? [Re: GY3] #3087841
10/20/22 03:18 PM
10/20/22 03:18 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I bought caltracs for mine as well and have already removed the snubber. Going to try to use the original floppy C body rear springs that used to be propped up with air shocks, and remove the segment clamps I have on them. If that doesn't work I'll buy the split monos as well.
Re: cal track? [Re: Blusmbl] #3088012
10/21/22 10:06 AM
10/21/22 10:06 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
Don't waste your time. Just get the monoleafs...
Re: cal track? [Re: Uncle Barry] #3088149
10/21/22 07:33 PM
10/21/22 07:33 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Thanks, it sounds like some people can make them work, but on old springs it might/probably will bend the springs and then I'm buying the monoleafs anyway.
Re: cal track? [Re: Blusmbl] #3088204
10/21/22 11:29 PM
10/21/22 11:29 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Cal tracs with split monos. Yep they work great
