Does this look sketchy to you? #3087651
10/19/22 11:53 PM
10/19/22 11:53 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
A guy devised this to level the camper because the fridge needs to be level. I think it's too much stress on the driveline. Maybe if he used chocks to hold it, then put it in park it would be better. What do you think?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Does this look sketchy to you? [Re: Hemi_Joel] #3087654
10/20/22 12:15 AM
10/20/22 12:15 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Not sure I see where the stress on the driveline is. The truck thinks it is on level ground. Almost looks like you could leave it in neutral and it would just sit there. shruggy
Re: Does this look sketchy to you? [Re: Ramrod39] #3087655
10/20/22 12:17 AM
10/20/22 12:17 AM
Minnesota
Minnesota
It looks to me like the ramps are very steep, More that the driveway behind the rear wheels. So it would be trying very hats to roll down the ramps.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Does this look sketchy to you? [Re: Hemi_Joel] #3087656
10/20/22 12:21 AM
10/20/22 12:21 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
As long as the ramps don't slide it looks OK to me. shruggy
Re: Does this look sketchy to you? [Re: Hemi_Joel] #3087659
10/20/22 12:42 AM
10/20/22 12:42 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
No because at the same time the truck would have to be trying to roll UP the driveway, hill or incline grade. The truck as stated doesn't know where it is only gravity and "the shadow knows" wink
Re: Does this look sketchy to you? [Re: Hemi_Joel] #3087700
10/20/22 08:08 AM
10/20/22 08:08 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
First thought would be about “chocks”
Rear wheels should be chocked.
Front ramps should be redesigned so that the wheel can descend into a dip of a few inches for security, and the underside of the ramps should be “grippy” with a rubber like tread.
OSHA, MSHA or US Military would not consider that good engineering.
Re: Does this look sketchy to you? [Re: 360view] #3087707
10/20/22 08:25 AM
10/20/22 08:25 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The top board of the ramps should lay over the top of the vertical member. The wood should be in "shear" , not the bolts holding it together.
Re: Does this look sketchy to you? [Re: Hemi_Joel] #3087709
10/20/22 08:36 AM
10/20/22 08:36 AM
an8sec70cuda Offline
iagree I'd at least chock the rear wheels.
I also agree w/ kerndog on the ramp design. Not how I would have done it, but if it works...
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Does this look sketchy to you? [Re: an8sec70cuda] #3087712
10/20/22 08:56 AM
10/20/22 08:56 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only stress is on the front suspension - pushing up at about a 30 degree angle. But no more stress than hitting a pothole would cause. The ramps must be fixed to the driveway 'cause there's no way you'd drive the truck up those otherwise. I sure wouldn't crawl under the truck like that though !!!
Re: Does this look sketchy to you? [Re: Kern Dog] #3087718
10/20/22 09:21 AM
10/20/22 09:21 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I'm no engineer, but that's the same thought I had. The way those ramps are built look like a disaster waiting to happen (to me).
Re: Does this look sketchy to you? [Re: Fat_Mike] #3087726
10/20/22 09:38 AM
10/20/22 09:38 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
It's hard to tell in the picture but I think it's designed that way already. He just has the outer 2 vertical members running past to sandwich everything together. The inner ramps that are supporting the weight are sitting on top of the verticals. But it's hard to be 100% without a better picture.
Re: Does this look sketchy to you? [Re: burdar] #3087743
10/20/22 10:21 AM
10/20/22 10:21 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If it was a Cummins truck it would crush those puny ramps... runaway
JB Rhinehart, Realist
A-Body's RULE!
Re: Does this look sketchy to you? [Re: Rhinodart] #3087757
10/20/22 11:15 AM
10/20/22 11:15 AM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Does the fridge not work because of the propane?
Re: Does this look sketchy to you? [Re: Dart 500] #3087762
10/20/22 11:36 AM
10/20/22 11:36 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yes, they need to remain level.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Does this look sketchy to you? [Re: BloFish] #3087803
10/20/22 01:59 PM
10/20/22 01:59 PM
moparx Online content
moparx  Online Content
maybe it's just me, but i would have made those ramps out of steel, welded together, with rubber gripper strips bolted to the bottom.
definitely chock the rear wheels, and if that would be a semi-permanent parking spot, i would think seriously about sinking some anchoring points in the driveway [front and rear] to chain the truck fast so it couldn't possibly move in either direction while up in the air.
of course that's just me thinking.
your mileage will vary.
beer
Re: Does this look sketchy to you? [Re: BloFish] #3087820
10/20/22 02:34 PM
10/20/22 02:34 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
It doesn't matter if the refrigerator is level unless you're using it, right?
Are they planning to live in that or something?
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: Does this look sketchy to you? [Re: Hemi_Joel] #3087847
10/20/22 03:31 PM
10/20/22 03:31 PM
I think putting the parking brake on real hard before putting the tranny into park should work okay work shruggy
Re: Does this look sketchy to you? [Re: Cab_Burge] #3087861
10/20/22 04:44 PM
10/20/22 04:44 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
It looks like a great thought experiment. If the truck in the photo was in neutral with no brake applied, which way would it roll? Or would it stay stationary?
Re: Does this look sketchy to you? [Re: Hemi_Joel] #3087869
10/20/22 05:27 PM
10/20/22 05:27 PM
o
ChryCoGuy Offline
ChryCoGuy  Offline
o
Seems like a lot of trouble to go through for a refrigerator (not to mention the potential for disaster). I probably would have just found a way to level the fridge, or just put my cold stuff in the fridge inside the house... work
Re: Does this look sketchy to you? [Re: ChryCoGuy] #3087870
10/20/22 05:30 PM
10/20/22 05:30 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
iagree up
