Re: Main caps for X block?
[Re: AndyF]
#3087282
10/18/22 08:53 PM
10/18/22 08:53 PM
Posts: 20,169 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The X block that we have in the shop has a busted front main cap. Replacements don't seem to be available from the usual places for the front cap. Anyone know if main caps are available for the X block? I think member Rocket is always selling main caps on here and Abodiesonly
[Re: AndyF]
#3087285
10/18/22 09:00 PM
10/18/22 09:00 PM
Posts: 1,756 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I don't know if these could be used, but I do have a set of the MP 4-bolt main caps here.
Was thinking of using them on my stroker W2 build, but it being a factory block there just wasn't enough meat in the webbing to dig into, so I just kept these in the box for when the time is "right" and I finally have a stout block available to build with.
If these might work, PM me and I can send you more info....not sure if this is an emergency type thing or not, either way, if nothing else pans out there is that option!
[Re: AndyF]
#3087286
10/18/22 09:12 PM
10/18/22 09:12 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
The X block that we have in the shop has a busted front main cap. Replacements don't seem to be available from the usual places for the front cap. Anyone know if main caps are available for the X block? Is the block 2 bolt or 4 bolt? They came either way, if you are looking for all the caps
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3087295
10/18/22 09:28 PM
10/18/22 09:28 PM
Posts: 3,021 NY
B1duster
NY
[Re: pittsburghracer]
#3087317
10/18/22 10:34 PM
10/18/22 10:34 PM
Posts: 31,017 Oregon
AndyF
The X block that we have in the shop has a busted front main cap. Replacements don't seem to be available from the usual places for the front cap. Anyone know if main caps are available for the X block? I think member Rocket is always selling main caps on here and Abodiesonly Yeah I've seen his posts over the years but not recently. I'll PM him to see if he has anything left. We did find that Pro Gram makes a HD front main cap for the 340 block but they are out of stock for who knows how long.
[Re: AndyF]
#3087328
10/18/22 11:03 PM
10/18/22 11:03 PM
Posts: 11,550 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
2 bolt? I would think a 318 or 340 cap could be made to work just touching up the line bore.. I don't think the caps were anything special. Just the block casting beefed up.
[Re: B1duster]
#3087426
10/19/22 10:12 AM
10/19/22 10:12 AM
Posts: 4,457 Washington
madscientist
Washington
Call Kent Ritter. He has billet caps and may have some OE caps laying around.
If it’s in the budget you should just buy a full set of his billet caps and be done with it.
[Re: madscientist]
#3087716
10/20/22 09:09 AM
10/20/22 09:09 AM
Posts: 656 Florida
CJD AUTOMOTIVE
I've got a set of ductile iron caps off an R3, 360 main I think, if you want them.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
