Main caps for X block? #3087277
10/18/22 08:44 PM
10/18/22 08:44 PM
AndyF Offline OP
AndyF  Offline OP
The X block that we have in the shop has a busted front main cap. Replacements don't seem to be available from the usual places for the front cap. Anyone know if main caps are available for the X block?
Re: Main caps for X block? [Re: AndyF] #3087282
10/18/22 08:53 PM
10/18/22 08:53 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I think member Rocket is always selling main caps on here and Abodiesonly
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Main caps for X block? [Re: AndyF] #3087285
10/18/22 09:00 PM
10/18/22 09:00 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I don't know if these could be used, but I do have a set of the MP 4-bolt main caps here.
Was thinking of using them on my stroker W2 build, but it being a factory block there just wasn't enough meat in the webbing to dig into, so I just kept these in the box for when the time is "right" and I finally have a stout block available to build with.
If these might work, PM me and I can send you more info....not sure if this is an emergency type thing or not, either way, if nothing else pans out there is that option!
Re: Main caps for X block? [Re: AndyF] #3087286
10/18/22 09:12 PM
10/18/22 09:12 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Is the block 2 bolt or 4 bolt? They came either way, if you are looking for all the caps
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Main caps for X block? [Re: B3422W5] #3087295
10/18/22 09:28 PM
10/18/22 09:28 PM
NY
B1duster Offline
B1duster  Offline
NY
Re: Main caps for X block? [Re: pittsburghracer] #3087317
10/18/22 10:34 PM
10/18/22 10:34 PM
AndyF Offline OP
AndyF  Offline OP
Yeah I've seen his posts over the years but not recently. I'll PM him to see if he has anything left.
We did find that Pro Gram makes a HD front main cap for the 340 block but they are out of stock for who knows how long.
Re: Main caps for X block? [Re: AndyF] #3087328
10/18/22 11:03 PM
10/18/22 11:03 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
2 bolt? I would think a 318 or 340 cap could be made to work just touching up the line bore.. I don't think the caps were anything special. Just the block casting beefed up.
Re: Main caps for X block? [Re: AndyF] #3087338
10/18/22 11:29 PM
10/18/22 11:29 PM
NY
B1duster Offline
B1duster  Offline
NY
P4007249
I believe this is the part number for a single cap, 1,2, or 4
https://www.canadamoparparts.ca/oem-parts/mopar-m-brg-cap-p4007249
Less than $5 if this is for real
Re: Main caps for X block? [Re: B1duster] #3087426
10/19/22 10:12 AM
10/19/22 10:12 AM
Washington
madscientist Offline
Washington
Call Kent Ritter. He has billet caps and may have some OE caps laying around.
If it’s in the budget you should just buy a full set of his billet caps and be done with it.
Re: Main caps for X block? [Re: madscientist] #3087716
10/20/22 09:09 AM
10/20/22 09:09 AM
CJD AUTOMOTIVE Offline
I've got a set of ductile iron caps off an R3, 360 main I think, if you want them.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Main caps for X block? [Re: CJD AUTOMOTIVE] #3087900
10/20/22 07:39 PM
10/20/22 07:39 PM
NH, USA
toddinNH Offline
Egghead
toddinNH  Offline
Egghead
NH, USA
If you do Facebook you might find something in the w7- 8- 9 headed motors Facebook group as they have some R/x blocks and parts on occasion. [NOT ADVOCATING FOR THIS OPTION]
Re: Main caps for X block? [Re: toddinNH] #3087955
10/21/22 12:44 AM
10/21/22 12:44 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I thought the 2 bolt X Blocks used the same as a regular 340.
My X block has been together for a long time.
So watching here to see.
Rocket has some listed at Abodies or did a few weeks ago 4 bolt ones.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
