roller cam, torrington bearing ,and cam button
#3086569
10/16/22 04:41 PM
10/16/22 04:41 PM
Posts: 1,032 illinois
bigblk66_coronet
illinois
So im building a 512 stroker and decided to go with a roller cam seeing as nobody seems to be able to make a hydraulic flat tappet cam last anymore. What a fringin night mare. I knew very little about roller cams and what was involved in making one work. what is with this stupid cam button? i got one from 440 source and it was way too long. so we took 100 thou off of it. not sure if it was too much or not yet. Then i bolt the timing chain on with arp bolts and the bolts hit the cover! So we took the washers off and it seems to clear now. we discovered the difference is the one with the torrington bearing sticks out farther....[censored]. anyone else run into this problem? this is supposed to be the way to go? been nothing but a nightmare trying to figure this out. anyone run into this before and how did you deal with it? like i said this roller cam stuff is all new to me.
66 Dodge Coronet 500
440w/727
11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust
Best ET. 12.38 @110 in street trim
Re: roller cam, torrington bearing ,and cam button
[Re: bigblk66_coronet]
#3086570
10/16/22 04:42 PM
10/16/22 04:42 PM
bigblk66_coronet
illinois
more pics of what im dealing with
440w/727
#3086572
10/16/22 04:44 PM
10/16/22 04:44 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
on mine I had to grind down the head of bolts with no washers & use a nylon button & grind it down to fit, also the bolts had to be regular hex head bolts
[Re: CSK]
#3086574
10/16/22 04:51 PM
10/16/22 04:51 PM
bigblk66_coronet
illinois
ok thanks.....this just makes no sense to me at all. everything ive read says everyone had to grind down or turn down the button....i mean wth kind of nonsense is that! how did you figure out you were at the right size on the button?
440w/727
#3086583
10/16/22 05:31 PM
10/16/22 05:31 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
ok thanks.....this just makes no sense to me at all. everything ive read says everyone had to grind down or turn down the button....i mean wth kind of nonsense is that! how did you figure out you were at the right size on the button? I used clay on the button to check fit but haing it hit the cover with no gasket on may work then use the gasket.
[Re: Uberpube]
#3086584
10/16/22 05:33 PM
10/16/22 05:33 PM
bigblk66_coronet
illinois
im relieved to know its not just me thats having this issue. In this day and age this is the best they can come up with?.....come on!
440w/727
#3086595
10/16/22 06:15 PM
10/16/22 06:15 PM
Posts: 31,086 Oregon
AndyF
I've been making billet timing chain covers and matching cam buttons for 20 years to solve this problem. https://arengineering.com/
[Re: AndyF]
#3086596
10/16/22 06:18 PM
10/16/22 06:18 PM
bigblk66_coronet
illinois
oh really? so if i buy you stuff this will solve my issues?
440w/727
[Re: jwb123]
#3086610
10/16/22 06:53 PM
10/16/22 06:53 PM
Clanton
northern,Ohio,USA
I seldom get one of the bearing thrust buttons to fit a mopar. I usually just use aluminum bar stock, and turn one myself in the lathe, and I use button head allen bolts, I don't think the heads of the bolts will clear the cover in your pictures. If everything is good with the valve train, there is not a lot of force against the cam button anyway. I have also used the white nylon cam buttons as well, and usually even those have to be trimmed. I thought I was the only 1 to use button head bolts on the cam.I just file the outside edge of the head by .030" all the way around and no problem with the button clearence.
#3086624
10/16/22 07:56 PM
10/16/22 07:56 PM
Posts: 1,236 Fairview Tennessee
SV_MOPARS
Fairview Tennessee
im relieved to know its not just me thats having this issue. In this day and age this is the best they can come up with?.....come on! i will ditto that, im in the same boat.
[Re: SV_MOPARS]
#3086625
10/16/22 08:07 PM
10/16/22 08:07 PM
bigblk66_coronet
illinois
you too huh? very frustrating. Are you on fb?
440w/727
#3086688
10/16/22 10:51 PM
10/16/22 10:51 PM
Posts: 8,916 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I thought I was the only 1 to use button head bolts on the cam.I just file the outside edge of the head by .030" all the way around and no problem with the button clearence. I use button head bolts as well and have no problems with clearance. I use a roller cam button like yours but actually have to shim it out to get the endplay. down. I'm using a cast cover that someone produced a number of years ago. Awesome piece but they seem to have only made a limited run.
#3086748
10/17/22 09:25 AM
10/17/22 09:25 AM
Posts: 2,937 A shed in England
Tig
A shed in England
I can remember going through all this too, I ended up grinding the 3 hex bolt heads and using a nylon button on a stock type (chrome) timing cover, as others have done. I always worried when I changed timing cover gaskets as some are thicker or thinner than the original set up one but it never seemed to cause any issue. I used an old stock timing cover with a hole in the appropriate place and a dial gauge to measure the play, this was a long long time ago and I can't remember the figure we were shooting for. If you go to a Jesel belt drive you can set up the play / clearance much more accurately as they are supplied with a selection of shims IIRC. They are expensive but worth it in my opinion. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
#3086751
10/17/22 09:42 AM
10/17/22 09:42 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
im relieved to know its not just me thats having this issue. In this day and age this is the best they can come up with?.....come on! The only issue is you thinking it's supposed to be a drop in, cam buttons have to be fit to to the parts you have. Did you use a gasket when doing your fit tests? You also might want to add a spacer behind the water pump to firm up the cover because it's going to flex. Andy F's cover setup is a nice piece but you are still going to have to fit it, which will be easier with his stuff.
[Re: JohnRR]
#3086781
10/17/22 10:34 AM
10/17/22 10:34 AM
Posts: 4,705 Wichita
GY3
Wichita
Comp cams nylon thrust button is easy to carve to the right size and just takes a few minutes. The current one has been in my engine for over 6 years. I used arp hardware and didn't have any issues with hitting the cover. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: JohnRR]
#3086808
10/17/22 11:16 AM
10/17/22 11:16 AM
AndyF
im relieved to know its not just me thats having this issue. In this day and age this is the best they can come up with?.....come on! The only issue is you thinking it's supposed to be a drop in, cam buttons have to be fit to to the parts you have. Did you use a gasket when doing your fit tests? You also might want to add a spacer behind the water pump to firm up the cover because it's going to flex. Andy F's cover setup is a nice piece but you are still going to have to fit it, which will be easier with his stuff. Typically the only fitting required with my cover and button is selecting the correct timing cover gasket. Superformance used to make several different gaskets so I kept a selection of each on hand. Only takes a few minutes to mock it up, measure the end play and then select the correct gasket to get the end play in the correct range. We build engines all the time with that setup.
