roller cam, torrington bearing ,and cam button #3086569
10/16/22 04:41 PM
10/16/22 04:41 PM
illinois
bigblk66_coronet Offline OP
illinois
So im building a 512 stroker and decided to go with a roller cam seeing as nobody seems to be able to make a hydraulic flat tappet cam last anymore. What a fringin night mare. I knew very little about roller cams and what was involved in making one work. what is with this stupid cam button? i got one from 440 source and it was way too long. so we took 100 thou off of it. not sure if it was too much or not yet. Then i bolt the timing chain on with arp bolts and the bolts hit the cover! So we took the washers off and it seems to clear now. we discovered the difference is the one with the torrington bearing sticks out farther....[censored]. anyone else run into this problem? this is supposed to be the way to go? been nothing but a nightmare trying to figure this out. anyone run into this before and how did you deal with it? like i said this roller cam stuff is all new to me.
311414275_5320615711401173_1649885696829174942_n.jpg311377249_769348704165201_8170794112719711395_n.jpg311051205_667191924722484_7685768280709780815_n.jpg310943443_1034310601299386_1128519456639710092_n.jpg
66 Dodge Coronet 500 440w/727 11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust Best ET. 12.38 @110 in street trim
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086570
10/16/22 04:42 PM
10/16/22 04:42 PM
illinois
illinois
more pics of what im dealing with
270072550_5686238881423225_6595072189910319640_n.jpg310943443_1034310601299386_1128519456639710092_n.jpg
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086572
10/16/22 04:44 PM
10/16/22 04:44 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
on mine I had to grind down the head of bolts with no washers & use a nylon button & grind it down to fit, also the bolts had to be regular hex head bolts
Re: roller cam, torrington bearing ,and cam button [Re: CSK] #3086574
10/16/22 04:51 PM
10/16/22 04:51 PM
illinois
illinois
ok thanks.....this just makes no sense to me at all. everything ive read says everyone had to grind down or turn down the button....i mean wth kind of nonsense is that! how did you figure out you were at the right size on the button?
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086582
10/16/22 05:29 PM
10/16/22 05:29 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I think I found my hand twin.
I used the nylon button and allen head cam gear bolts, and then I had to clearance the button in three spots for the bolt heads.The first set of bolts I bought for the cam gear stuck out too far like yours. The thrust clearance was a bit more work, hard to find a spec on timing cover gasket compression to do it one touch out of the box
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086583
10/16/22 05:31 PM
10/16/22 05:31 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I used clay on the button to check fit but haing it hit the cover with no gasket on may work then use the gasket.
Re: roller cam, torrington bearing ,and cam button [Re: Uberpube] #3086584
10/16/22 05:33 PM
10/16/22 05:33 PM
illinois
illinois
im relieved to know its not just me thats having this issue. In this day and age this is the best they can come up with?.....come on!
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086595
10/16/22 06:15 PM
10/16/22 06:15 PM
AndyF Offline
AndyF  Offline
I've been making billet timing chain covers and matching cam buttons for 20 years to solve this problem.
https://arengineering.com/
Re: roller cam, torrington bearing ,and cam button [Re: AndyF] #3086596
10/16/22 06:18 PM
10/16/22 06:18 PM
illinois
illinois
oh really?
so if i buy you stuff this will solve my issues?
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086599
10/16/22 06:25 PM
10/16/22 06:25 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I seldom get one of the bearing thrust buttons to fit a mopar. I usually just use aluminum bar stock, and turn one myself in the lathe, and I use button head allen bolts, I don't think the heads of the bolts will clear the cover in your pictures. If everything is good with the valve train, there is not a lot of force against the cam button anyway. I have also used the white nylon cam buttons as well, and usually even those have to be trimmed.
Re: roller cam, torrington bearing ,and cam button [Re: jwb123] #3086610
10/16/22 06:53 PM
10/16/22 06:53 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I thought I was the only 1 to use button head bolts on the cam.I just file the outside edge of the head by .030" all the way around and no problem with the button clearence.
Re: roller cam, torrington bearing ,and cam button [Re: Clanton] #3086622
10/16/22 07:37 PM
10/16/22 07:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I just went through this last week so it's fresh in my mind. I just used the cheap Comp cams plastic one and notched in 3 places for the bolts with a small sanding drum in a Dremel. I had the same issue with the ARP bolts touching the cover so I installed a thicker gasket from Superformance. Greg makes the timing cover gaskets in different thicknesses. I put my timing cover on and it just touches the button. So now I'm happy for an easy fix up
Gus beer
64 Plymouth Savoy
Dana 60
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086624
10/16/22 07:56 PM
10/16/22 07:56 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
i will ditto that, im in the same boat.
Re: roller cam, torrington bearing ,and cam button [Re: SV_MOPARS] #3086625
10/16/22 08:07 PM
10/16/22 08:07 PM
illinois
illinois
you too huh? very frustrating. Are you on fb?
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086688
10/16/22 10:51 PM
10/16/22 10:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
I use button head bolts as well and have no problems with clearance. I use a roller cam button like yours but actually have to shim it out to get the endplay. down. I'm using a cast cover that someone produced a number of years ago. Awesome piece but they seem to have only made a limited run.
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086707
10/17/22 01:51 AM
10/17/22 01:51 AM
What's up on showing two different cam gears confused
On the three bolt cam gear is there a spacer mounted on the front between the bolts and the gear?
I have 5 or 6 sets of Cloyes 3 bolt timing sets that have the wrong 3 bolt cam gear for BB Mopars puke shruggy work
I'll try and remember to take some pictures of them tomorrow in the day light and add them on here luck
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086748
10/17/22 09:25 AM
10/17/22 09:25 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I can remember going through all this too, I ended up grinding the 3 hex bolt heads and using a nylon button on a stock type (chrome) timing cover, as others have done. I always worried when I changed timing cover gaskets as some are thicker or thinner than the original set up one but it never seemed to cause any issue. I used an old stock timing cover with a hole in the appropriate place and a dial gauge to measure the play, this was a long long time ago and I can't remember the figure we were shooting for.
If you go to a Jesel belt drive you can set up the play / clearance much more accurately as they are supplied with a selection of shims IIRC. They are expensive but worth it in my opinion. twocents
Re: roller cam, torrington bearing ,and cam button [Re: bigblk66_coronet] #3086751
10/17/22 09:42 AM
10/17/22 09:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The only issue is you thinking it's supposed to be a drop in, cam buttons have to be fit to to the parts you have.
Did you use a gasket when doing your fit tests?
You also might want to add a spacer behind the water pump to firm up the cover because it's going to flex.
Andy F's cover setup is a nice piece but you are still going to have to fit it, which will be easier with his stuff.
Re: roller cam, torrington bearing ,and cam button [Re: JohnRR] #3086781
10/17/22 10:34 AM
10/17/22 10:34 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Comp cams nylon thrust button is easy to carve to the right size and just takes a few minutes.
The current one has been in my engine for over 6 years.
I used arp hardware and didn't have any issues with hitting the cover. shruggy
'63 Dodge 330
11.19 @ 121 mph
Re: roller cam, torrington bearing ,and cam button [Re: JohnRR] #3086808
10/17/22 11:16 AM
10/17/22 11:16 AM
AndyF Offline
AndyF  Offline
Typically the only fitting required with my cover and button is selecting the correct timing cover gasket. Superformance used to make several different gaskets so I kept a selection of each on hand. Only takes a few minutes to mock it up, measure the end play and then select the correct gasket to get the end play in the correct range. We build engines all the time with that setup.
