Strange temperature gauge issue #3086628
10/16/22 08:14 PM
10/16/22 08:14 PM
Star Idaho
67vertman Offline OP
Star Idaho
79 Dodge D150, 360 CI
Temperature gauge works fine, that is until you turn the lights on. Then the gauge will climb, some times it will peg others times it it goes to three quarters. Now for even more strange, when you turn the dimmer switch up, you can watch the gauge climb, turn it down the gauge will drop. Turn the lights off the gauge works normal. Truck is not over heating. I believe it is a faulty dimmer switch, but it turn the lights off and on fine and controls the dash lights. shruggy
Has anyone run into this issue? potential causes and fixes???
My Monster are real!
Living within your means makes life pretty easy.
Re: Strange temperature gauge issue [Re: 67vertman] #3086648
10/16/22 08:54 PM
10/16/22 08:54 PM
Guitar Jones Offline
Its a ground issue, been there done that.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Strange temperature gauge issue [Re: Guitar Jones] #3086675
10/16/22 10:08 PM
10/16/22 10:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up iagree
Re: Strange temperature gauge issue [Re: Guitar Jones] #3086689
10/16/22 10:52 PM
10/16/22 10:52 PM
Star Idaho
Star Idaho
Ground to what GJ! in the dimmer switch it self, or the temp gauge? They both work.
Re: Strange temperature gauge issue [Re: 67vertman] #3086694
10/16/22 11:08 PM
10/16/22 11:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Cluster to dash that grounds through the screws holding it in?
Re: Strange temperature gauge issue [Re: 67vertman] #3086704
10/17/22 12:46 AM
10/17/22 12:46 AM
It could be any multitude of places. As these trucks age contact points between body panels get corroded and lose continuity, ground points themselves do the same. It's time to find and clean to bare metal every ground point on the truck. If that doesn't fix it then running new ground wires from body panels to the frame or directly to the battery is the next step.
Re: Strange temperature gauge issue [Re: Guitar Jones] #3086753
10/17/22 09:47 AM
10/17/22 09:47 AM
Star Idaho
Star Idaho
Thanks guys! I guess I have some investigation to do. dakota
Re: Strange temperature gauge issue [Re: 67vertman] #3086775
10/17/22 10:22 AM
10/17/22 10:22 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I installed a set of Cyberdyne aftermarket gauges in my 70 when it was built...no issues until a few years later when I installed the stereo system...
When the volume was turned up the water temp would peg and the oil pressure would drop...
A ground wire from the gauges ran to the engine and not just the dash frame cured the problem...
...FAFO...
Re: Strange temperature gauge issue [Re: skicker] #3086805
10/17/22 11:07 AM
10/17/22 11:07 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Sounds like your IVR is acting up. If you think it is a ground problem, a lot of the later IVR's have a tab on the case that does is not connected to anything. I'd run a test wire from this tab to a good gorund and see if it makes a difference.
IVR
Re: Strange temperature gauge issue [Re: skicker] #3086806
10/17/22 11:07 AM
10/17/22 11:07 AM
moparx Offline
moparx  Offline
grounds are funny things. can't have too many of them, and the connecting points must be clean and tight.
they can also cause hair loss on the top of ones head from chasing them to find the one that is causing the problem[s] you are having. i have no hair on the top of my head. biggrin
beer
Re: Strange temperature gauge issue [Re: moparx] #3086813
10/17/22 11:23 AM
10/17/22 11:23 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Dial-a-temp ! Who knew ?
Sounds like it's time to pull the cluster & clean up whatever's creating the feedback.
Might as well look at the bulkhead connections and grounds, too.
Re: Strange temperature gauge issue [Re: moparx] #3086878
10/17/22 03:03 PM
10/17/22 03:03 PM
Star Idaho
Star Idaho
beer
grin Yes, chasing electoral issues will leave a man bald!
Re: Strange temperature gauge issue [Re: topside] #3086879
10/17/22 03:05 PM
10/17/22 03:05 PM
Star Idaho
Star Idaho
It is pretty strange to watch, I will have to take a video of it!
Yea, I see some work in my future! rant
Re: Strange temperature gauge issue [Re: 67vertman] #3086996
10/17/22 09:59 PM
10/17/22 09:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If you can establish a grounding point on the printed circuit film ( usually under one of more screws) running a wire from one of thes points to the dash frame is a quick fix. most of the time tightening the screws (cluster mounting included) will do the trick beer
Re: Strange temperature gauge issue [Re: TJP] #3087007
10/17/22 10:31 PM
10/17/22 10:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
As I recall that dash has a ground wire. Look at the dimmer switch for a ground wire that should be on one of the screws. I think it is white in color. A FSM will show it. I know for sure the 77 had it and I think it stayed that way through 1980.
Re: Strange temperature gauge issue [Re: TJP] #3087008
10/17/22 10:32 PM
10/17/22 10:32 PM
Star Idaho
Star Idaho
Thanks for the "Tip" up
Re: Strange temperature gauge issue [Re: 67vertman] #3087555
10/19/22 06:10 PM
10/19/22 06:10 PM
Star Idaho
Star Idaho
All right, an update after some investigation.
I pulled the instrument cluster and cleaned all the contact points that I could access, I found one burned out bulb, emergency brake light. I also checked the bulkhead connector, it was tight with no loose wires.
The issues was better, but still there. As I was putting the ground back on the battery, I told myself to check all the ground to vehicle connection, the very first one was battery to engine. At first it look good, but I decided to pull it off and clean the surfaces. Upon loosing the bolt just a little, the cable fell off. The end connector was broken in two places. I put a new end connector on. I found one other body ground from body to transmission with a bad end as well. Cleaned all other grounds I could find, I fixed a bunch of wiring connections from previous owners, trailer brakes (wired with Romex wire), stereo and trailer plug that were only held together with twist ends and electrical tape! flame realcrazy
For now the issues has gone away and the seat belt indicator buzzer has decide to work, but will probably get unplugged soon. work
Thanks for all the help! up
Re: Strange temperature gauge issue [Re: 67vertman] #3087563
10/19/22 06:31 PM
10/19/22 06:31 PM
See I told ya! laugh2
Re: Strange temperature gauge issue [Re: 67vertman] #3087633
10/19/22 09:51 PM
10/19/22 09:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks for the update beer
Re: Strange temperature gauge issue [Re: TJP] #3087815
10/20/22 02:21 PM
10/20/22 02:21 PM
moparx Offline
moparx  Offline
how much hair did you loose from the top of your head finding these culprits ? biggrin
glad to hear you have had success in repairing your issues. up
beer
