Adjustable Ladder bars #3085589
10/12/22 09:30 PM
10/12/22 09:30 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
I've been researching ladder bar designs, has anyone used the Chassis Engineering Outlaw ladder bar?
https://www.chassisengineering.com/product/c-e3606-outlaw-adjustable-ladder-bar-pair/
I have always liked the Quarter Max design, which has be "re-interpretted" by companies like TRZ.
Just getting some ideas whilst I plan my build
Cheers
Alan Jones
Re: Adjustable Ladder bars [Re: LA360] #3085634
10/13/22 12:35 AM
10/13/22 12:35 AM
How long are those bars on that kit?
My old foot brake Duster had a set of 32.0 inch long ladder bars with only three holes in the body cross member that the ladder bars hooked up to, Leaf spring car with floaters also, that car ran the quickest and fastest in the bottom hole shruggyI think it had 3 way adjustable Completion Engineering rear shocks, 70/30, 80/20 and 90/10. Way better choices today up
Looking back now I had a lot of fun with that car and made some money with it also boogie
Re: Adjustable Ladder bars [Re: Cab_Burge] #3085677
10/13/22 07:05 AM
10/13/22 07:05 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
They seem to have a few nice advantages. Being the upper bar adjusts pinion angle, there is a greater range of travel before bind. (though I've never had any trouble with my std style lower bar adjustment) The axle brackets are beefy surrounding the entire tube. Numerous shock attaching locations for ride height. The fact that the bars can bolt to the housing at two different locations means absolutely nothing. It makes zero difference where the ladder bar is attached to the housing. I've used these for years. Never an issue. The 36" were chosen for my intended power level and wheelbase. 32" may be better with less power and a short wheelbase.
Doug
https://swracecars.com/product/ladder-bars-36-double-adjustable-with-moly-rod-ends/
Re: Adjustable Ladder bars [Re: LA360] #3085706
10/13/22 09:41 AM
10/13/22 09:41 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have seen a lot of ladder bar cars work really well, and some not so good. Thing is once it is welded under the car you have limited adjustability. If you spring for the extra money and do a 4-link you can adjust for about anything, including down the road when you make upgrades like a bigger engine, lighten up the car etc. etc.
Re: Adjustable Ladder bars [Re: jwb123] #3085717
10/13/22 10:09 AM
10/13/22 10:09 AM
PA
moparacer Offline
moparacer  Offline
PA
Quote
Most of the time ladder bars need some downward angle in them to try and take away some antisquat and hit. Those short bars probably especially so.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Adjustable Ladder bars [Re: moparacer] #3085735
10/13/22 11:22 AM
10/13/22 11:22 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have used the RJ stuff a number of times and always been happy with them. FWIW the Vette is a ladder bar car as well and has a traditional adjustable bar and they seem to work ok..1.09 60' on a 29.5x10.5 with and NA SB. We do have wrap around brackets on them
Re: Adjustable Ladder bars [Re: Al_Alguire] #3085835
10/13/22 09:20 PM
10/13/22 09:20 PM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
check out Kevin Wilsons videos on anti squat, instant center , purcentage of rise. Theres also a form you can print when you scale the car. great info!
https://www.youtube.com/watch?v=mmjieeSov4Q
Re: Adjustable Ladder bars [Re: Al_Alguire] #3085844
10/13/22 09:40 PM
10/13/22 09:40 PM
LA360 Offline OP
LA360  Offline OP
Just out of curiousity Al, what style of shock are you running on Ryan's car? I am assuming a 4 way adjustable of some kind?
Alan Jones
Re: Adjustable Ladder bars [Re: LA360] #3085975
10/14/22 01:21 PM
10/14/22 01:21 PM
moparx Offline
moparx  Offline
i have a "stoopid old man" question about the rod ends on ladder bars.
i know the front heims need to rotate when the bolt is tightened, therefor the best nylon [?] lined joint should be used.
however, can the heims on the rear end brackets be solid, as they do not rotate, or should they be rotational ones like the front in case there is some deflection/twist in the rear housing ?
the reason for asking, i have seen setups both ways, some used as street/strip, some street only, some strip only.
i haven't heard of any failures, but then, i do not know what the maintenance/replacement interval is, nor the amount of passes/street miles they are run.
a big TIA to those way smarter than this old goof. up bow
beer
Re: Adjustable Ladder bars [Re: LA360] #3085980
10/14/22 01:33 PM
10/14/22 01:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nope. Its a double adjustable Penske. We are not allowed by NMCA to use any electronic or air adjustments down track.
Re: Adjustable Ladder bars [Re: Al_Alguire] #3085981
10/14/22 01:35 PM
10/14/22 01:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
All the rod ends should be the best quality Teflon lined ones you can afford in all three positions......I prefer FK made in America stuff personally.
Re: Adjustable Ladder bars [Re: Al_Alguire] #3085983
10/14/22 01:36 PM
10/14/22 01:36 PM
Chesterfield Twp. Mi.
John Burdine Offline
Is this on the M/T 3062s tire?
Re: Adjustable Ladder bars [Re: John Burdine] #3085988
10/14/22 01:49 PM
10/14/22 01:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My ladder bars use solid rod ends at the housing. No reason not to. Now a 4 link would be a different story. The ladder bars and housing should ideally be one complete stiff member with zero movement. As with anything, it does move around, but it's not intended. For the front buy the best you can get. And thread them in as far as possible. Only unthread them a turn or so to square up the housing.
Doug
Re: Adjustable Ladder bars [Re: John Burdine] #3085990
10/14/22 01:49 PM
10/14/22 01:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes sir it is with tubes and double beadlocks shock Seems to really like the tubes which we were stubborn about trying. Our best 60' W/O tubes as 1.15. But that was also with different shocks.
Re: Adjustable Ladder bars [Re: dvw] #3086000
10/14/22 02:11 PM
10/14/22 02:11 PM
moparx Offline
moparx  Offline
Doug
"All the rod ends should be the best quality Teflon lined ones you can afford in all three positions......I prefer FK made in America stuff personally." [Al Alguire]
i agree with both statements above. both suggest buying the best ends out there, as i do.
Doug says to use solid ends on the housing, while Al says to use the teflon lined ends. so i'm not sure what i will do. my "eternal project" [1933 dodge humpback panel truck] has the best quality FK lined ends on the front [3/4"] and the diagonal link [5/8"], while the rear link ends are solid. i also have the FK ends for the anti-roll bar links. [we are talking ladder bar setup here, 32" length, although the wheel base on this thing is 122"]
i am also of the opinion, any rod ends used [in any position] should have the maximum amount of the threads used [minimum threads showing] so as to be as strong as possible.
beer
Re: Adjustable Ladder bars [Re: Al_Alguire] #3086601
10/16/22 06:29 PM
10/16/22 06:29 PM
LA360 Offline OP
LA360  Offline OP
I think I have got Aurora or FK sitting there, I bought them quite a while ago and they've sat waiting for me to use them.
What size tubing are people using for their diagnonal link? A wishbone just seems needlessly heavy and complicated.
Alan Jones
Re: Adjustable Ladder bars [Re: LA360] #3086807
10/17/22 11:15 AM
10/17/22 11:15 AM
moparx Offline
moparx  Offline
i am using 1" diameter, 1/8" wall thickness DOM tube, with bungs for 5/8" rod ends.
beer
