Six pack center carb vent #3085150
10/11/22 03:08 PM
10/11/22 03:08 PM
Rochester NY
6pack67 Offline OP
6pack67  Offline OP
Rochester NY
Anyone know how the bowl vent is supposed to open? My linkage does not engage the vent lever. Pictures I’ve found on line look the same as mine.
Re: Six pack center carb vent [Re: 6pack67] #3085210
10/11/22 06:16 PM
10/11/22 06:16 PM
A727Tflite Offline
A727Tflite  Offline
First, loosen the screw that holds the pivot to he bowl and bring that bracket up against the raised lip, tighten the screw.
Then you may have to carefully bend the rod.
Re: Six pack center carb vent [Re: 6pack67] #3085213
10/11/22 06:30 PM
10/11/22 06:30 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I added a rubber sleeve, maybe a piece of vac line, to make the rod a larger diameter. Mine brand new from Holley was the same way.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Six pack center carb vent [Re: 6pack67] #3085219
10/11/22 07:10 PM
10/11/22 07:10 PM
That vent needs to open when the motor is shut off or idling a low engine RPM wrench up
Re: Six pack center carb vent [Re: 6pack67] #3085238
10/11/22 08:50 PM
10/11/22 08:50 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
first t you must open the choke plate and make sure you are not on fast idle cam and throttle blades closed .
then the vent arm should open the bowel vent at warm idle .
Re: Six pack center carb vent [Re: calrobb2000] #3085292
10/11/22 11:37 PM
10/11/22 11:37 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by calrobb2000
hi
Good catch, just noticed the choke is closed.
Re: Six pack center carb vent [Re: calrobb2000] #3085347
10/12/22 10:06 AM
10/12/22 10:06 AM
Rochester NY
6pack67 Offline OP
6pack67  Offline OP
Rochester NY
Good point. I did check again while making sure it was not on fast idle and the idle speed screw all the way out. Same result though
Re: Six pack center carb vent [Re: Cab_Burge] #3085348
10/12/22 10:07 AM
10/12/22 10:07 AM
Rochester NY
6pack67 Offline OP
6pack67  Offline OP
Rochester NY
Thanks. It helps to know how the vent is supposed to function.
Re: Six pack center carb vent [Re: A727Tflite] #3085351
10/12/22 10:19 AM
10/12/22 10:19 AM
Rochester NY
6pack67 Offline OP
6pack67  Offline OP
Rochester NY
So I tried Transman’s suggestion about loosening the pivot screw. With it loose the vent lever moves closer to the carb link but still doesn’t quite touch. Then in order to tighten the screw again it pulls back to the locating bosses. I’m thinking the next step will be to bend the rod or maybe add material as suggested. Seems like a weird design.
Re: Six pack center carb vent [Re: Cab_Burge] #3085360
10/12/22 10:38 AM
10/12/22 10:38 AM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
What sucks about this design is that a stuck needle/seat will fill your intake manifold area with fuel before you even know there's an issue, or if you're lucky enough to hook the vent to your valve cover breather, you can fill your crankcase with fuel. With the normal venting path, a stuck needle/seat will push fuel down the carb throat and cause the car to run like crap immediately so you can shut it off.
I had a freak occurrence with the car idling in the driveway, the needle and seat stuck on center carb, and it filled up the intake area with fuel before it started spilling over the back of the block to the ground and I saw it. Luckily no fire. After that, I capped the bowl vent tube and haven't had any hot starting issues.
Re: Six pack center carb vent [Re: 83hurstguy] #3085406
10/12/22 12:16 PM
10/12/22 12:16 PM
Rochester NY
6pack67 Offline OP
6pack67  Offline OP
Rochester NY
Hummm. So it sounds like if the vent doesn’t function at all it’s ok?
Re: Six pack center carb vent [Re: 6pack67] #3085411
10/12/22 12:22 PM
10/12/22 12:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Bending carb linkages is a necessary technique. You should read the FSM.
Re: Six pack center carb vent [Re: NITROUSN] #3085414
10/12/22 12:27 PM
10/12/22 12:27 PM
N
NITROUSN Offline
NITROUSN  Offline
N
From the FSM
Checking Bowl Vent Valve Clearance
To check the bowl vent valve clearance
adjustment, proceed as follows:
(1) With the throttle valves at curb idle, it should
be possible to insert a .015 in. gauge between bowl
vent valve plunger stem and operating rod, (Fig.
26).
(2) If an adjustment is necessary, bend rod to
change arc of contact with throttle lever
Re: Six pack center carb vent [Re: 6pack67] #3085415
10/12/22 12:27 PM
10/12/22 12:27 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
There's still a main vent inside the air cleaner that sticks up by the accelerator pump nozzle. The external bowl vent is supposed to keep the fuel vapors from going up the tube when the engine is off and laying in the intake manifold, leading to a richer (tougher) hot start. Considering there are two other carbs doing the same thing (and contributing to idle) without a bowl vent, I'm not sure why secondary venting the center carb matters so much.
Re: Six pack center carb vent [Re: 83hurstguy] #3085458
10/12/22 02:12 PM
10/12/22 02:12 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Mostly wrong. The external vent was mainly designed for emission vapors. Sending the vapors into the system and returning them to the tank.
Re: Six pack center carb vent [Re: NITROUSN] #3085463
10/12/22 02:21 PM
10/12/22 02:21 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
Since I'm "mostly wrong" please explain how the first iteration of this design (a plug on the top of the float bowl that vented to the engine compartment) did anything to capture emission vapors.
Re: Six pack center carb vent [Re: 83hurstguy] #3085467
10/12/22 02:26 PM
10/12/22 02:26 PM
N
NITROUSN Offline
NITROUSN  Offline
N
It did not capture vapors or was it intended to as it did not have that system. The carb in question here does have that system and does what it was intended to do.
Re: Six pack center carb vent [Re: 83hurstguy] #3085491
10/12/22 03:08 PM
10/12/22 03:08 PM
That bowl vent had a tube going to a canister filter that had lines going back to the fuel tank scope
Some of the early smog stuff wasn't so good whistling shruggy
Re: Six pack center carb vent [Re: Cab_Burge] #3085671
10/13/22 06:00 AM
10/13/22 06:00 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Carbs built after Jan 1, 1970 all generally have the same vent as the OP picture. It is correct that it was a design made for emissions control. Previous to Jan 1, they were not required. I’m sure it was an EPA thing. As to why it’s not working as it should direct from Holley, is a mystery. I restore six pack carbs now that Bill O has passed and have many carbs in the works right now. I’ve got some original carbs that are off of my AAR so I’ll inspect them when I go to the shop. I’ve done multiple sets of the early style bowl lately but I have a set in progress with the emission bowl so maybe I can check it out today. I did have a problem with the last emission bowl set and I used a new Holley vent arm. I had to bend it quite a bit to get it in the proper specs. I did not try and compare an original arm. Looks like I may have to do that. Be careful in bending that rod. It is made out of hard material and does not bend without a lot of force. You can mar the plating very easily, though.
Re: Six pack center carb vent [Re: fastmark] #3085702
10/13/22 09:29 AM
10/13/22 09:29 AM
N
NITROUSN Offline
NITROUSN  Offline
N
From the FSM
26).
