Edel. Thunder series AVS tip in stumble #308366
05/05/09 07:30 AM
05/05/09 07:30 AM
Nebraska
N
no318 Offline OP
no318  Offline OP
N
Nebraska
I am working on a fresh mild 440 in a 69 Coronet RT 4 speed. It has a new Thunder Series AVS 800cfm carb. It performs super except for a very slight tip in bog or pop back throught the carb. (lean?) under VERY light acceleration at about 1000RPM. Moderate throttle or harder it is not there. It is NOT the secondaries.
I have the accel pump in the closest (rich) hole. I have richened it one jet and about as far as I can with metering rods on the low speed side. I have the springs in it to move the metering rod sooner (pink). It has helped, but I cannot completely eliminate the sag. Any ideas?
THANKS.
Re: Edel. Thunder series AVS tip in stumble [Re: no318] #308367
05/05/09 08:20 AM
05/05/09 08:20 AM
Any ideas?
bump your initial up 5 degrees
Re: Edel. Thunder series AVS tip in stumble [Re: RapidRobert] #308368
05/05/09 08:51 AM
05/05/09 08:51 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
IIRC the natural colored springs are the stiffest. I'd switch to those.
2017 Grand Cherokee Overland
Re: Edel. Thunder series AVS tip in stumble [Re: patrick] #308369
05/05/09 09:03 AM
05/05/09 09:03 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
There are also different pump shot nozzles available,though I'm not sure what size comes in teh 800cfm carb.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Edel. Thunder series AVS tip in stumble [Re: GoodysGotaCuda] #308370
05/05/09 11:13 AM
05/05/09 11:13 AM
Az
Crizila Offline
Crizila  Offline
Az
Raise the float level.
Fastest 300
Re: Edel. Thunder series AVS tip in stumble [Re: Crizila] #308371
05/05/09 11:16 AM
05/05/09 11:16 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
On Edelbrocks site in the troubleshooting section, they mention a slight bog at just off idle was caused by having the Idle Mixture Screws not set quite right.
Probably something about the transition from idle to primary jets isn't right.
Re: Edel. Thunder series AVS tip in stumble [Re: hooziewhatsit] #308372
05/05/09 11:29 AM
05/05/09 11:29 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'd check the initial timing, the idle speed, and the mixture screws as mentionned. Not sure where you are interms of rods, but if youcan get the same full throttle (3rd step on the rod) size with a slightly smaller 2nd step, that might help too.
Re: Edel. Thunder series AVS tip in stumble [Re: moper] #308373
05/05/09 01:02 PM
05/05/09 01:02 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You'll want at least 13 degrees initial timing. When I ran a 650 AVS on a stock 340 I had to jet it up a lot and put on a bigger accelerator pump nozzle to get rid of the bog:
http://store.summitracing.com/partdetail...mp;autoview=sku
Re: Edel. Thunder series AVS tip in stumble [Re: 69Cuda340S] #308374
05/05/09 01:34 PM
05/05/09 01:34 PM
germany
440sat72 Offline
440sat72  Offline
germany
i did all the mentioned above and had the same problem with my eddy thunder AVS and the TQ i switched to later. only thing that cured that off idle hseitation was goind from a mechanical to an electrical fuel pump. that caused other problems, but the hesitation went away ...
