Edel. Thunder series AVS tip in stumble
#308366
05/05/09 07:30 AM
05/05/09 07:30 AM
Posts: 193 Nebraska
no318
Nebraska
I am working on a fresh mild 440 in a 69 Coronet RT 4 speed. It has a new Thunder Series AVS 800cfm carb. It performs super except for a very slight tip in bog or pop back throught the carb. (lean?) under VERY light acceleration at about 1000RPM. Moderate throttle or harder it is not there. It is NOT the secondaries.
I have the accel pump in the closest (rich) hole. I have richened it one jet and about as far as I can with metering rods on the low speed side. I have the springs in it to move the metering rod sooner (pink). It has helped, but I cannot completely eliminate the sag. Any ideas?
THANKS.
Re: Edel. Thunder series AVS tip in stumble
[Re: RapidRobert]
#308368
05/05/09 08:51 AM
05/05/09 08:51 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
IIRC the natural colored springs are the stiffest. I'd switch to those.
[Re: Crizila]
#308371
05/05/09 11:16 AM
05/05/09 11:16 AM
Posts: 3,893 Oregon
hooziewhatsit
On Edelbrocks site in the troubleshooting section, they mention a slight bog at just off idle was caused by having the Idle Mixture Screws not set quite right.
Probably something about the transition from idle to primary jets isn't right.
[Re: hooziewhatsit]
#308372
05/05/09 11:29 AM
05/05/09 11:29 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'd check the initial timing, the idle speed, and the mixture screws as mentionned. Not sure where you are interms of rods, but if youcan get the same full throttle (3rd step on the rod) size with a slightly smaller 2nd step, that might help too.
