Roots Blower Guys.....Q-Boost Ref #3083506
10/05/22 10:12 AM
10/05/22 10:12 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So I acquired a 440 based blower motor....The plan is an 871 on E85 with carbs at the moment. But, if someone had a good deal on dual TorqueStorms, my mind could be changed....
So with that said, I plan on using the Magnaleak 500 I have, do I need a boost referenced regulator for the carbs?
Re: Roots Blower Guys.....Q-Boost Ref [Re: Dragula] #3083515
10/05/22 10:51 AM
10/05/22 10:51 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
I dont think you need to in that application as the carbs dont see positive pressure.
You may consider referencing the carbs to the intake to ensure power valve opening ? That would be my concern.
(I may have no idea what I'm talking about though.)
Re: Roots Blower Guys.....Q-Boost Ref [Re: Dragula] #3083535
10/05/22 12:15 PM
10/05/22 12:15 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: Roots Blower Guys.....Q-Boost Ref [Re: Dragula] #3083781
10/06/22 11:57 AM
10/06/22 11:57 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
No br regulator is needed but you can just not have it hooked up if it is br.
