Page 8 of 8 1 2 3 4 5 6 7 8
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3082883
10/03/22 02:43 PM
10/03/22 02:43 PM
wedges RULE up grin devil
Where is Hemi Joel whistling devil
Re: 563ci build specs, what will it make? [Re: Cab_Burge] #3082886
10/03/22 02:49 PM
10/03/22 02:49 PM
MN
JERICOGTX Offline OP
MN
Most likely goofing off... I'm sure he's making out his Christmas list to include Texas Roadhouse gift certificates, so he can pay up on yet another dinner bet, in 2023.
69 GTX 68 Road Runner
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3082888
10/03/22 02:51 PM
10/03/22 02:51 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Originally Posted by JERICOGTX
Picked up the block on Friday. Have only installed the crankshaft, and one piston. Need to cut the pistons down .005 or buy different head gaskets. Cutting the piston will be faster.
How close are they to the head?
Re: 563ci build specs, what will it make? [Re: INTMD8] #3082893
10/03/22 02:57 PM
10/03/22 02:57 PM
MN
MN
The piston was .011 above the deck, before this last mess. I have .051 Cometic gaskets. The piston now sits .014 above the deck. Too tight for my liking at this point.
Re: 563ci build specs, what will it make? [Re: Cab_Burge] #3082900
10/03/22 03:28 PM
10/03/22 03:28 PM
Minnesota
Hemi_Joel Online content
Hemi_Joel  Online Content
Minnesota
Now don't go dragging my good name into this plebian world of wedgery. Isn't a Buick a wedge? wink
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3082990
10/03/22 08:11 PM
10/03/22 08:11 PM
gregsdart Offline
gregsdart  Offline
I am counting on block growth as it warms to increase clearance the head. If we gain . 008 in clearance as it warms. All good. I am thinking I should do a test to make sure. Now to figure out how to heat the lock to about 160,' to find out for certain.
Re: 563ci build specs, what will it make? [Re: gregsdart] #3083095
10/04/22 06:18 AM
10/04/22 06:18 AM
MN
MN
I'd like to think the clearance would be fine with an Aluminum block, but I just am not willing to take any chances at this point. This engine has been 2 years plus in the making. No need to risk it.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3083098
10/04/22 06:40 AM
10/04/22 06:40 AM
tboomer Offline
tboomer  Offline
What are you shooting for clearance wise Jeff? Mine are .004 below the deck.... wave
Re: 563ci build specs, what will it make? [Re: gregsdart] #3083109
10/04/22 07:01 AM
10/04/22 07:01 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have seen some guys use a propane burner on a large pot of water that circulates water with the electric water pump. That was on an assembled engine though. I thought it was a pretty genius way to heat cycle and retorque stuff with the engine out of the car. Especially on the combo I saw it on, a twin turbo BBC that looked like a nuclear reactor under the hood with all the plumbing lol.
68 Barracuda Formula S 340
Re: 563ci build specs, what will it make? [Re: tboomer] #3083129
10/04/22 08:05 AM
10/04/22 08:05 AM
MN
MN
I want .040 piston to head clearance.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3083134
10/04/22 08:13 AM
10/04/22 08:13 AM
tboomer Offline
tboomer  Offline
Thanks!
Re: 563ci build specs, what will it make? [Re: Hemi_Joel] #3083136
10/04/22 08:32 AM
10/04/22 08:32 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Shots fired ! Shots fired ! laugh2 laugh2
Re: 563ci build specs, what will it make? [Re: tubtar] #3083142
10/04/22 08:53 AM
10/04/22 08:53 AM
MN
MN
It was proven 30+ years ago, in a magazine shootout, that a Buick is far superior to a HEMI anything. It predates the internet, so it MUST be true.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3083230
10/04/22 01:06 PM
10/04/22 01:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
.040" piston to head with an aluminum block is plenty conservative......
Re: 563ci build specs, what will it make? [Re: Al_Alguire] #3083241
10/04/22 01:39 PM
10/04/22 01:39 PM
MN
MN
Right now I'm around .035-.036. The piston has plenty of rock in it. The highest point I saw was .028 above the deck.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3083472
10/05/22 08:15 AM
10/05/22 08:15 AM
gregsdart Offline
gregsdart  Offline
Since piston contact happens due to piston rock, (those with more experience chime in if I am missing something) the idea of shaving . 005 off at an angle on the closed side of the chamber might be a way to save a current combo? The angle could be measured with the piston cold in the block, and the actual cut may only extend three quarters of an inch in. JUST THINKEN, 🧐
Re: 563ci build specs, what will it make? [Re: gregsdart] #3083597
10/05/22 04:24 PM
10/05/22 04:24 PM
My old pump gas Duster stroker motor with Ross 22.0 CC dished pistons would touch the heads(knock the carbon off) on the cam side and motor mount sides at .035, but not at .040 clearance up shruggy
IHTHs wrench scope
Re: 563ci build specs, what will it make? [Re: gregsdart] #3083703
10/06/22 06:24 AM
10/06/22 06:24 AM
MN
MN
Probably more work to do it that way than it's worth? Fairly easy to just skim .005 off the top. Can I get away with less, while using an aluminum block? Probably, but since this is a bracket engine, and I really don't have the funds to be buying new pistons, once something does go wrong. I'll just adjust the old shoe polish on the window instead.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3083838
10/06/22 01:58 PM
10/06/22 01:58 PM
That is the best way to make it easy on you that I know of twocents
Re: 563ci build specs, what will it make? [Re: Cab_Burge] #3083877
10/06/22 04:42 PM
10/06/22 04:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If it were mine I would just send it as is....But I like living on the edge laugh2
