Removing glove box lock #3082932
10/03/22 05:29 PM
10/03/22 05:29 PM
A727Tflite Offline OP
Key MIA, how does one remove the lock w/o the key.
Re: Removing glove box lock [Re: A727Tflite] #3082950
10/03/22 06:54 PM
10/03/22 06:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What car ?
Is the glovebox locked shut ?
Re: Removing glove box lock [Re: topside] #3082957
10/03/22 07:17 PM
10/03/22 07:17 PM
Originally Posted by topside
What car ?
71 B Body, not locked. Just lost the key.
Re: Removing glove box lock [Re: A727Tflite] #3083028
10/03/22 08:42 PM
10/03/22 08:42 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
I do believe that on many, or all, you need the key to remove it all the way out.
Re: Removing glove box lock [Re: PhillyRag] #3083070
10/03/22 11:23 PM
10/03/22 11:23 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I recall people using a paperclip on these to get them out. Search found this;
https://board.moparts.org/ubbthread...emoving-key-cylinder-from-glove-box.html
Re: Removing glove box lock [Re: Neil] #3083153
10/04/22 09:16 AM
10/04/22 09:16 AM
Thanks. I experienced all of the negatives too. I’ll try the paper clip next.
Re: Removing glove box lock [Re: A727Tflite] #3083181
10/04/22 10:41 AM
10/04/22 10:41 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
It is pretty easy to stick a flat screwdriver into the chrome knob and give it a slight pry to the side. The knob will pop off allowing you to remove it. Re-install using a vice and a socket to press it on. Done this many times with success.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Removing glove box lock [Re: 70gtx440dana] #3083247
10/04/22 01:58 PM
10/04/22 01:58 PM
Once the chrome knob is removed you are saying the lock assy. can then be removed from the glove box door?
Re: Removing glove box lock [Re: A727Tflite] #3083276
10/04/22 03:57 PM
10/04/22 03:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
A no key glove box lock, don't know if this is any help?
Mike
Re: Removing glove box lock [Re: A727Tflite] #3083300
10/04/22 04:45 PM
10/04/22 04:45 PM
Lansing, MI
Lansing, MI
Yes....just take out the two screws from rear of lock.
Re: Removing glove box lock [Re: 70gtx440dana] #3083360
10/04/22 07:20 PM
10/04/22 07:20 PM
VA
dragon slayer Offline
VA
That video is good. I had to do this, but was so long ago forgot exactly, but I do remember dropping the first latch and pulling out partially, then systematicity depressing the others one by one until I had it out. If you have access to the mopar key kit you can figure out your key number, and set it to the trunk key with the appropriate pins from the kit. Best done on a bench with the door on the bench with good light and some pins/picks to work the latches down.
Re: Removing glove box lock [Re: 70gtx440dana] #3087816
10/20/22 02:24 PM
10/20/22 02:24 PM
usa
ShaneHobbs Offline
ShaneHobbs  Offline
usa
The best way is to contact a mobile locksmithto take it out and install the new glove box lock.
Re: Removing glove box lock [Re: ShaneHobbs] #3087950
10/20/22 11:22 PM
10/20/22 11:22 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Probably cost more them just drill out & buy a new replacement.
Re: Removing glove box lock [Re: PhillyRag] #3087962
10/21/22 02:42 AM
10/21/22 02:42 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Should be able to get it apart using the video.
