Re: sOLD engine paint and misc
[Re: HardcoreB]
#3081908
09/30/22 09:20 AM
09/30/22 09:20 AM
Posts: 10,038 MN
JERICOGTX
MN
They look good in factory colors. My 499 was black, and I grew tired of it.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3081911
09/30/22 09:21 AM
09/30/22 09:21 AM
Posts: 4,067 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
They look good in factory colors. My 499 was black, and I grew tired of it. Damnyou!
[Re: HardcoreB]
#3081920
09/30/22 09:48 AM
09/30/22 09:48 AM
HardcoreB
Shelby Twp. Mi
Reusing same cam from Bullet, but I've read it's not the best choice? I'm happy with it however, and very pleased with their service. This was a premeasured sketch, the actual NET is about .735" Used the PAC 1225 spring with about .07 from C/B and intakes are 2.25" Ti. Exh 1.81 SS I had it installed at 105.5ICL but it's now installed at 107. P-2-V is still pretty far away .140/I and .200/E if i recall correctly. Nothing fancy commonly available for rings so it got 1/16 1/16 and 3/16 but i set the oil around 12lbs. Motor bars over about 15ft lbs no seals, until you bolt it all together. Run ready WITHOUT spark plugs, it's about 75ft lbs!!!
[Re: HardcoreB]
#3081931
09/30/22 10:14 AM
09/30/22 10:14 AM
Posts: 47 S.E. Michigan
TruPerformance
S.E. Michigan
For me, any motor going in a 62-65 B-Body race car should be Race Hemi Orange. Just my opinion...
1963 Belvedere (mine) 1969 Roadrunner (wife's)
[Re: TruPerformance]
#3081937
09/30/22 10:37 AM
09/30/22 10:37 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I thought hard about making it orange too, but ultimately decided the Turqouise factory color on the green car would look best. I told HardcoreB if he wanted support for a black block, and tarnished aluminum heads/intake, he should go look for support on www.chevyguy.com. My build will keep the black valve covers, which I think are period correct to match the AFB's that will top it all off. But heads/intake/block will all go green. Still deciding if motor plate will be Aluminum/Black/Turqouise. Getting pretty excited about the build, this has been WELL WELL engineered by HardcoreB. Lots of thought put into the pieces chosen, layout on the plate, etc.... Used pipe max to guide the design. FED is almost there, intake is getting close to having it's extensive modifications done, etc... I have a LOT of weight out of the car. New front wheels/tires, 10gal less fuel, rear seat out, light front brakes, 170lbs of turbo/street car stuff out, etc... At the end of the day it's looking to be ~250lbs lighter depending on how much more the Big Block weighs than the Small Block. It's looking good enough I'm adding bars to finally cert below 9.99, which the turbo combo never had.
[Re: bobby66]
#3081989
09/30/22 12:55 PM
09/30/22 12:55 PM
Posts: 4,688 On the parachute mount
n20mstr
I say Black block...but im not a show car guy......
In the end i think turquoise would really go well with the color of the car....but again im not a show car guy at all. Fast first, flashy second....LOL
....BAD A$$ STREET CAR.....
[Re: HardcoreB]
#3081992
09/30/22 01:01 PM
09/30/22 01:01 PM
Posts: 16,928 NC
440Jim
NC
Some updates rebuilding the 485" for Dizuster. This is your chance to inform Scott that the engine needs to remain BLACK as he wants it painted OEM bluegreen.. The bottom line is the owner gets the final word... But, I like the aluminum and black color combo. Aluminum parts stay aluminum color (intake, heads, water pump housing, timing cover, etc.) and other parts get painted black (block if iron, valve covers, etc.). My only advice to Dizuster is that the engine color (blue/green) and car color might look strange if the exact same color isn't used.
[Re: HardcoreB]
#3082000
09/30/22 01:30 PM
09/30/22 01:30 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Black supposedly allows more heat to radiate from the block but it might also allow more heat from the headers into the block. Lighter colors such as the Mopar turquoise or orange brighten up the engine compartment making it easier to see what you are working on or fluid leaks. The only engine color that I ever thought looked hideous was an eye burning bright lime green engine in a blue Fox body Mustang Since your not building a 1400 HP normally aspirated Prostock engine I vote give it some color. And oh I definitely agree that new bare aluminum looks good but older dull corroded aluminum is just ugly. Paint the heads, intake, valve covers, etc..
[Re: GomangoCuda]
#3082023
09/30/22 03:33 PM
09/30/22 03:33 PM
Posts: 16,928 NC
440Jim
NC
Since your not building a 1400 HP normally aspirated Prostock engine I vote give it some color. And oh I definitely agree that new bare aluminum looks good but older dull corroded aluminum is just ugly. Paint the heads, intake, valve covers, etc.. I agree discolored bare aluminum looks bad. That is why I clear coated my intake manifold and water pump housing. If I had a guy to clear coat my block with automotive clear, I would have done it.
[Re: 440Jim]
#3082066
09/30/22 08:07 PM
09/30/22 08:07 PM
GomangoCuda
I like clean aluminum. Dirty, discolored, corroded aluminum not so much. What clear do you use that doesn't yellow from heat and withstands gasoline spillage and cleaners?
[Re: dvw]
#3082126
10/01/22 07:34 AM
10/01/22 07:34 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Since the only motor that was orange in the year was a 413 max then the terqous would be more period correct...
JAKES AUTOMOTIVE
