Re: LOST 2 IN FLORIDA [Re: TJP] #3081894
09/30/22 08:17 AM
09/30/22 08:17 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
If the ocean side didn't have another garage door but a solid wall, would the outcome be the same . And if the lift was secured better and deeper into the concrete,would that of held it better..would like to see how the lifts held up.
Re: LOST 2 IN FLORIDA [Re: AARCONV] #3082227
10/01/22 01:36 PM
10/01/22 01:36 PM
moparx Offline
moparx  Offline
wonder what happened to the two that were under the lifts ?
beer
Re: LOST 2 IN FLORIDA [Re: moparx] #3082262
10/01/22 02:57 PM
10/01/22 02:57 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Here's the owner talking about it:
https://youtu.be/Kbf2LfBlqis
Re: LOST 2 IN FLORIDA [Re: autoxcuda] #3082270
10/01/22 03:16 PM
10/01/22 03:16 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by autoxcuda
I notice the house to the left seems to be built on pilings. And front door to house one right seems like second floor.
And the livable dwelling of the house the wing cars were in is elevated too
The codes in the Florida hurricane flood zones now require the living space to be elevated. I think it is 12 or 14 ft now. The space underneath can be enclosed, but the walls have to be designed to wash out so that the force of the moving water doesn't knock the structure over. Also you can't put your electric service panel in the lower area and you can't have any openings into the sanitary sewer. So the ground level is supposed to be considered a disposable, temporary space for garage or recreation room or something that could disappear in a hurricane.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: LOST 2 IN FLORIDA [Re: Hemi_Joel] #3082382
10/01/22 10:39 PM
10/01/22 10:39 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Guess he stayed put and didn't want to "leave" his cars!
NOW his cars will be "leaving" him.
Re: LOST 2 IN FLORIDA [Re: PhillyRag] #3082563
10/02/22 08:20 PM
10/02/22 08:20 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
That's a 12 Million dollar home. Fixing those will likely be small potatos for that owner.
Re: LOST 2 IN FLORIDA [Re: PhillyRag] #3084502
10/09/22 11:05 AM
10/09/22 11:05 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Yeah.....leaving to go to a restoration shop and get fixed good as new. I'd say the dude has the money to do it out of his pocket and not even file insurance.
Re: LOST 2 IN FLORIDA [Re: JDMopar] #3085619
10/12/22 11:10 PM
10/12/22 11:10 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
WAG that the storage rack was not properly connected with substantial anchor bolts and maybe no footing to retain anchorage.
Storm surge and tidal action worked debris through the garage doors and acted as battering ram on the uprights. There is no sheer designed into the straight legs and with the weight of two cars up high repeated back and forth tidal action may have worked it to failure.
It would be interesting to know how high the surge was there and to have a look at the steel members, the fasteners, the garage doors (were they simple plywood to enclose a balloon foundation to locate home above flood level) and also the attachment to the slab (that appears to still be in place).
It does suxx, I've had to leave our home on several instances with sprinklers running as wildfires approached. Fortunately left no vehicles behind and never had a loss.
Re: LOST 2 IN FLORIDA [Re: srt] #3085622
10/12/22 11:20 PM
10/12/22 11:20 PM
AndyF Offline
AndyF  Offline
Storage racks were not designed for tidal forces but would be a simple upgrade. Bet the owner fixes the problem this time. There are a lot of situations where guys could add a lot of strength to their racks by fastening them together or to the walls. Doesn't take much, just some steel straps or angles and then they'll ride out an earthquake or flood.
Re: LOST 2 IN FLORIDA [Re: AndyF] #3085637
10/13/22 01:04 AM
10/13/22 01:04 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Properly sized members, plates and fasteners supplemented by gussets and proper footings would be a good start..
Bolting it to the structure introduces a new situation that could be properly designed. Certainly owner knew the risk of leaving them behind.
I've looked at different lifts and "racks" The budget models generally are not steel shapes, rather fabricated or bent shapes.
