72 inner fender on late 71 Cuda / Barracuda #3081031
09/27/22 06:13 AM
09/27/22 06:13 AM
Sweden
71redcuda Offline OP
Sweden
Hi,
Does anyone know if very late built 71 Cudas/Barracudas came
with 1972 inner fenders?
Nicklas
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: 71redcuda] #3081060
09/27/22 09:34 AM
09/27/22 09:34 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Looks like a 5 for the month there Nicklas, my spd 526 does not have a 72 inner fender as you posted…
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: shakerjoe] #3081065
09/27/22 09:56 AM
09/27/22 09:56 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
B body uses the same apron and I had a 72 RR built 8-71 and it had a 71 apron.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: shakerjoe] #3081117
09/27/22 12:23 PM
09/27/22 12:23 PM
Sweden
Sweden
Thanks for the input.
/Nicklas
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: 71redcuda] #3081152
09/27/22 02:28 PM
09/27/22 02:28 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
here's a 622 SPD '71 Challenger w/dash cluster dated 165 1 (6/14/71) - it has the "HUMP" without the weld-nut scope
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: 71redcuda] #3081300
09/27/22 10:33 PM
09/27/22 10:33 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
I have two 1971 Barracudas (BH). The SP dates are 115 and 625. Both inner fenders are the originals and the same.
David
Edited: 09-28-2022
Well damn! I am sorry Nicklas. I took another look tonight and they are indeed different. The SPD 115 GK6 and SPD 625. My apologies to all for my mistake.
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: David1971] #3081325
09/28/22 05:41 AM
09/28/22 05:41 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Educate me
Does the bulge and weld nut define '72 and later inner fenders?
What does the 70-71 versions look like?
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: larry4406] #3081554
09/28/22 09:15 PM
09/28/22 09:15 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
72 has the battery retainer that screws into that nut I believe
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: 71redcuda] #3081601
09/29/22 12:47 AM
09/29/22 12:47 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
I have edited my original reply. My late June FC7 Barracuda has the bulge but no weld nut. The January GK6 has no bulge
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: larry4406] #3081602
09/29/22 12:47 AM
09/29/22 12:47 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Originally Posted by larry4406
Educate me
yes, the HUMP & weld-nut are required for the '72+ model year battery hold down - the HUMP showed up ~June '71 & the HUMP & weld-nut showed up ~July '71 on (1971) e-body production
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: 6bblgt] #3081652
09/29/22 11:23 AM
09/29/22 11:23 AM
Washington, MI
Ashsdad Offline
Whatever you call me, my wife has called me worse.
Ashsdad  Offline
Washington, MI
Great...now I have to go dig out the NOS inner fenders I was going to use on my 70 to make sure I've been holding on to the right parts for the last 40 years!
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: 6bblgt] #3081709
09/29/22 03:13 PM
09/29/22 03:13 PM
Sweden
Sweden
Educate me
Thank you! Good info.
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: 71redcuda] #3081717
09/29/22 04:00 PM
09/29/22 04:00 PM
A727Tflite Offline
A727Tflite  Offline
My 71 St. Louis built GTX has the hump.
Engine build date 3589 (5/26/1971)
Original trim panels dated 6/24/71.
SPD 5/26/1971
Door decal 6/71
Re: 72 inner fender on late 71 Cuda / Barracuda [Re: A727Tflite] #3092739
11/09/22 02:05 AM
11/09/22 02:05 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
My June build 1971 Challenger has the 1971 Inner fender that has no welded in nut. Never seen a 1971 E Body with a 1972 Inner Fender and I have looked at many mid May build E Bodies to the end of production to see what was going on then. My SPD is May 24 but my door stick in June. Cudas with the same or near May 24 SPD have a May Door Sticker. Also Challengers have the three nuts to hold the fenders and Cudas have the studs with near SPDs. The trunk floor on my Challenger has the 1972 Version and the Tach is not the same as my Cuda that has a Nov.5 1970 SPD. Lots of little things were Changed over the last four months of production in 1971 but I have not seen the 1972 Inner on an 1971 E Body.
1971 HEMI E BODY REGISTRY
