Re: 72 inner fender on late 71 Cuda / Barracuda
[Re: 71redcuda]
#3081060
09/27/22 09:34 AM
09/27/22 09:34 AM
Posts: 3,001 Long Island, NY
shakerjoe
Long Island, NY
Looks like a 5 for the month there Nicklas, my spd 526 does not have a 72 inner fender as you posted…
[Re: shakerjoe]
#3081117
09/27/22 12:23 PM
09/27/22 12:23 PM
Posts: 1,552 Sweden
71redcuda
Sweden
Looks like a 5 for the month there Nicklas, my spd 526 does not have a 72 inner fender as you posted… Thanks for the input. /Nicklas
[Re: 71redcuda]
#3081300
09/27/22 10:33 PM
09/27/22 10:33 PM
Posts: 203 Alabama
David1971
Alabama
I have two 1971 Barracudas (BH). The SP dates are 115 and 625. Both inner fenders are the originals and the same.
David
Edited: 09-28-2022
Well damn! I am sorry Nicklas. I took another look tonight and they are indeed different. The SPD 115 GK6 and SPD 625. My apologies to all for my mistake.
[Re: 71redcuda]
#3081601
09/29/22 12:47 AM
09/29/22 12:47 AM
Posts: 203 Alabama
David1971
Alabama
I have edited my original reply. My late June FC7 Barracuda has the bulge but no weld nut. The January GK6 has no bulge
[Re: larry4406]
#3081602
09/29/22 12:47 AM
09/29/22 12:47 AM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
Educate me
Does the bulge and weld nut define '72 and later inner fenders?
What does the 70-71 versions look like? yes, the HUMP & weld-nut are required for the '72+ model year battery hold down - the HUMP showed up ~June '71 & the HUMP & weld-nut showed up ~July '71 on (1971) e-body production
[Re: 6bblgt]
#3081709
09/29/22 03:13 PM
09/29/22 03:13 PM
Posts: 1,552 Sweden
71redcuda
Sweden
Educate me
What does the 70-71 versions look like? yes, the HUMP & weld-nut are required for the '72+ model year battery hold down - the HUMP showed up ~June '71 & the HUMP & weld-nut showed up ~July '71 on (1971) e-body production Thank you! Good info.
[Re: A727Tflite]
#3092739
11/09/22 02:05 AM
11/09/22 02:05 AM
Posts: 5,118 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
My June build 1971 Challenger has the 1971 Inner fender that has no welded in nut. Never seen a 1971 E Body with a 1972 Inner Fender and I have looked at many mid May build E Bodies to the end of production to see what was going on then. My SPD is May 24 but my door stick in June. Cudas with the same or near May 24 SPD have a May Door Sticker. Also Challengers have the three nuts to hold the fenders and Cudas have the studs with near SPDs. The trunk floor on my Challenger has the 1972 Version and the Tach is not the same as my Cuda that has a Nov.5 1970 SPD. Lots of little things were Changed over the last four months of production in 1971 but I have not seen the 1972 Inner on an 1971 E Body.
1971 HEMI E BODY REGISTRY
