3 speed wiper question #3080720
09/26/22 05:35 AM
09/26/22 05:35 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I have a customer who is needing a three or variable speed wiper motor for his 70 Cuda. He does not need the correct 077, per say, he just needs one that will work. It is my understanding that a rebuilder can change the mechanical workings of a b or c body motor and “ Index” it for an ebody. I know there are several guys on here that restore wiper motors that should be able to help me out. I may have enough parts to get him a complete system but I may need some pieces so I’ll place an add in the parts wanted section when I get an inventory of what I need. Thanks in advance.
Re: 3 speed wiper question [Re: fastmark] #3080746
09/26/22 09:08 AM
09/26/22 09:08 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
The big difference (I think) is the "park" function. On b-bodies the park position is just at the bottom of the wiper sweep. But on E-bodies the park position drops the wipers down into the cowl to be hidden by the hood.
Re: 3 speed wiper question [Re: fastmark] #3080747
09/26/22 09:08 AM
09/26/22 09:08 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
One of my friends re-indexes (re-clocks) wiper motors all the time. How does he do it? Don't have a clue.
Re: 3 speed wiper question [Re: 6PakBee] #3080791
09/26/22 11:24 AM
09/26/22 11:24 AM
central il.
second 70 Offline
second 70  Offline
central il.
Re: 3 speed wiper question [Re: second 70] #3080797
09/26/22 11:51 AM
09/26/22 11:51 AM
VA
dragon slayer Offline
VA
Any three speed will work, the crank lever and fitting needs to be for the 70 Cuda, but could already be there with the linkage. Adjusting the park notch is easy.
Re: 3 speed wiper question [Re: dragon slayer] #3080843
09/26/22 02:17 PM
09/26/22 02:17 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks looking at all my 3 speed motors and a diagram I found, it looks easy to clock these for the correct application. I have a 72 up I can fix him up with but I’m not sure how the arm attaches to the crank pin the 70-71 uses a clip. How does the 72 up stay on?
Re: 3 speed wiper question [Re: fastmark] #3080921
09/26/22 06:37 PM
09/26/22 06:37 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
72 Crank and crank arm are 1 year only. They change again in 73 up and have black bakeolite switchs.
If you have the underhood linkage check part numbers or post a pic to see if you have 70-71 linkage or 72-74. I have parts the will make any combination work.
ns1aar.com
or PM
NS1AAR
Re: 3 speed wiper question [Re: ns1aar] #3081029
09/27/22 05:22 AM
09/27/22 05:22 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Ok, I’ll shoot you an email.
Re: 3 speed wiper question [Re: fastmark] #3083307
10/04/22 05:07 PM
10/04/22 05:07 PM
moparx Offline
moparx  Offline
in the february 2021 issue of Mopar action magazine, there is a tech article on wipers. [begins on page 58]
on page 60, there is a wiring diagram at the bottom of the page showing how to retro-fit a 2-speed wiper motor to a variable speed unit, using an e-bag item.
it states the item in question won't work on a 3-speed wiper motor, but as i don't have either here to test, i don't know how true it is. [and i still haven't figured out how to scan stuff on this new wind-hose 11 desk top i got early in the summer. down spank]
beer
